Is there a way to take a 1d wavelet trans to get 2 bands (lpf and hpf) over a fixed BW (say 4KHz) if the sampling freq is greater (eg 20KHz)
Regarding wavelets
Started by ●May 10, 2006
Reply by ●May 11, 20062006-05-11
Sukrut wrote:> Is there a way to take a 1d wavelet trans to get 2 bands (lpf and hpf) > over a fixed BW (say 4KHz) if the sampling freq is greater (eg 20KHz)That's the point of wavelet filter banks. You apply them recursively to the lowpassed signals (approximations), leaving the highpassed signals (details).
thanks for the reply but, do we have to go about it recursively? can't we implement it in 1 step as in digital BPFs eg. an LPF for 0 to 2KHz and a BPF for 2 to 4KHz the pt is it takes up a lot of time to obtain many such filterbanks and, btw i am not taking abt wavelet compression, where the highpassed signals are ignored rather, they should be retained in order to get other filterbanks in the higher frequency region
Sukrut wrote:> thanks for the reply > but, do we have to go about it recursively? > can't we implement it in 1 step as in digital BPFs > eg. an LPF for 0 to 2KHz and a BPF for 2 to 4KHz > > the pt is it takes up a lot of time to obtain many such filterbanks > > and, btw i am not taking abt wavelet compression, > where the highpassed signals are ignored > rather, they should be retained in order to get other filterbanks in > the higher frequency regionPerhaps you're intrested in wavelet packets (google them up)? And yes, you don't have to perform wavelet transform recursively. -- Jani Huhtanen Tampere University of Technology, Pori
