"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:a4nc625o402ab56f4qfgl64esjr9fbsq86@4ax.com...> On Sat, 13 May 2006 20:04:28 GMT, Oli Filth <catch@olifilth.co.uk> > wrote: > >>Mike Yarwood said the following on 12/05/2006 22:13: >>> "john" <johns@xetron.com> wrote in message >>> news:1147466593.329239.206570@j33g2000cwa.googlegroups.com... >>>> Mark wrote: >>>>> sorry that should be ENERGY per bit, instead of POWER per bit >>>>> Mark >>>> Thanks for your help. I should have clarified that I intend for the >>>> power *and bandwidth* of the RF signal to remain constant. >> >>That being the case, then for a given symbol rate and a given SNR, the >>Eb/No for QPSK will be half of that for BPSK, i.e. a 3dB drop. Looking >>at a BER vs. Eb/No plot for the two schemes, it's pretty clear that a >>3dB drop results in a considerable increase in BER. >> >>Bear in mind though, transmitting a set amount of data via QPSK will >>take half as long as via BPSK, so for a fixed power level, you're >>actually using half the energy overall. Therefore, in some senses, it >>would be a fairer "free lunch" comparison if you allowed QPSK to use >>twice as much power. > > Right, if the code rate doesn't change and the symbol rate doesn't > change and the transmit power doesn't change, then you lose 3dB of > energy per bit since you're transmitting twice as many bits with QPSK > than you are with BPSK. > > So you'll lose 3dB worth of performance since Eb is cut in half but No > stays the same. >But it might not be quite that bad, if you have to work with a particular Tx amplifier chain and meet fairly tight adjacent channel interference criteria then it's a choice between shaped BPSK and shaped QPSK and QPSK offers you more flexibility (like using offset QPSK) to get more energy per symbol out of your amplifier. Provided that your phase noise is o.k. you still might not see quite this 3dB difference. Best of luck - Mike
Is QPSK a free lunch?
Started by ●May 12, 2006
Reply by ●May 14, 20062006-05-14
"Mike Yarwood" <mpyarwood@btopenworld.com> wrote in message news:xvmdnYYdrKFatvrZRVnyhg@bt.com...> > But it might not be quite that bad, if you have to work with a particular > Tx amplifier chain and meet fairly tight adjacent channel interference > criteria then it's a choice between shaped BPSK and shaped QPSK and QPSK > offers you more flexibility (like using offset QPSK) to get more energy > per symbol out of your amplifier. Provided that your phase noise is o.k. > you still might not see quite this 3dB difference.Aren't there also constant envelope variants of QPSK that allow the use of more efficient saturating Class C PA's? If so, then I guess you can get some free lunch, but perhaps at the expense of other things. OMG, look who's cited here http://www.ieee802.org/16/tg1/phy/contrib/802161pc-00_11.pdf Cheers, Howard
Howard Long wrote:> "Mike Yarwood" <mpyarwood@btopenworld.com> wrote in message > news:xvmdnYYdrKFatvrZRVnyhg@bt.com... > >>But it might not be quite that bad, if you have to work with a particular >>Tx amplifier chain and meet fairly tight adjacent channel interference >>criteria then it's a choice between shaped BPSK and shaped QPSK and QPSK >>offers you more flexibility (like using offset QPSK) to get more energy >>per symbol out of your amplifier. Provided that your phase noise is o.k. >>you still might not see quite this 3dB difference. > > > Aren't there also constant envelope variants of QPSK that allow the use of > more efficient saturating Class C PA's? If so, then I guess you can get some > free lunch, but perhaps at the expense of other things. OMG, look who's > cited here http://www.ieee802.org/16/tg1/phy/contrib/802161pc-00_11.pdf > > Cheers, Howard > >Yes. MSK has lower sidebands and allows for 'exact' demodulation. GMSK is a variant of MSK that trades off some intersymbol interference for better sideband suppression, and is the modulation used in GSM phones. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●May 15, 20062006-05-15
john <johns@xetron.com> wrote:>So you are saying that by Gray Coding the constellation, I will get the >same BER for QPSK as BPSK, power and bandwidth being constant?A QPSK constellation does not really have enough points for grey-coding to apply. Steve
Steve Pope said the following on 15/05/2006 06:06:> john <johns@xetron.com> wrote: > >> So you are saying that by Gray Coding the constellation, I will get the >> same BER for QPSK as BPSK, power and bandwidth being constant? > > A QPSK constellation does not really have enough > points for grey-coding to apply.Eh? How about 00, 01, 11, 10? That looks like Gray coding to me. True, it's exactly the same as if you independently modulated I and Q with binary sources, but it's still Gray coding. Compare that to the "ordinal" labelling, 00, 01, 10, 11. -- Oli
Reply by ●May 16, 20062006-05-16
Oli Filth <catch@olifilth.co.uk> wrote:>Steve Pope said the following on 15/05/2006 06:06:>> john <johns@xetron.com> wrote:>> A QPSK constellation does not really have enough >> points for grey-coding to apply.>Eh? How about 00, 01, 11, 10? That looks like Gray coding to me. >True, it's exactly the same as if you independently modulated I and Q >with binary sources, but it's still Gray coding.>Compare that to the "ordinal" labelling, 00, 01, 10, 11.You're right, I was thinking of gray coding as having an independent axis encoding more than one bit with those bits gray-coded, but in this case you're gray-coding the phase which is just as valid. Steve
