OFDM, Homeplug - reduce IFFT butterflys
Started by Zeph80 May 16, 2006
I have a question concering Homeplug and OFDM.What if had to be able to
talk to Homeplug chips, BUT I needed very very low data rates like nothing
more than 800 bps. So since I have such low data rate needs, and would need
to work within the  Homeplug standard  but not use high MIPS and increase
my costs.If the standard allows me to null sub-carriers which it does,
would feeding those zeros to the IFFTs mean lower no of butterfly
computations.
Zeph80 wrote:
> I have a question concering Homeplug and OFDM.What if had to be able to > talk to Homeplug chips, BUT I needed very very low data rates like nothing > more than 800 bps. So since I have such low data rate needs, and would need > to work within the Homeplug standard but not use high MIPS and increase > my costs.If the standard allows me to null sub-carriers which it does, > would feeding those zeros to the IFFTs mean lower no of butterfly > computations. >
If you null out enough sub-carriers you could avoid doing the FFT altogether, although there probably aren't orders of magnitude MIPs to save. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
>Zeph80 wrote: > >> I have a question concering Homeplug and OFDM.What if had to be able
to
nothing
need
increase
>> my costs.If the standard allows me to null sub-carriers which it does, >> would feeding those zeros to the IFFTs mean lower no of butterfly >> computations. >> >If you null out enough sub-carriers you could avoid doing the FFT >altogether, although there probably aren't orders of magnitude MIPs to
save.
> >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com > >Posting from Google? See http://cfaj.freeshell.org/google/ > >"Applied Control Theory for Embedded Systems" came out in April. >See details at http://www.wescottdesign.com/actfes/actfes.html >
Do you have any suggestions that would allow me to reduce the MIPS, while working within the standard
