Hello all, for the last month i was searching for 2D cross correlation code in C/C++ with no success. I also tried many times to use the 'mcc' function in matlab & convert the normxcorr2.m into C/C++ but it's issuing so many problems I'll spare you with. Can you direct me to a good source or advise me with a solution? Thanks in advance.
I need 2D cross correlation code
Started by ●May 21, 2006
Reply by ●May 21, 20062006-05-21
"projector" <liav.ezer@gmail.com> wrote in message news:D4idnQVZOMie9-3ZnZ2dnUVZ_vqdnZ2d@giganews.com...> Hello all, > > for the last month i was searching for 2D cross correlation code in C/C++ > with no success. > I also tried many times to use the 'mcc' function in matlab & convert the > normxcorr2.m into C/C++ but it's issuing so many problems I'll spare you > with. > > Can you direct me to a good source or advise me with a solution? > > Thanks in advance. > > >Well - you could do some research and write your own? Now that's a novel idea. M.P *** Posted via a free Usenet account from http://www.teranews.com ***
projector wrote:> Hello all, > > for the last month i was searching for 2D cross correlation code in C/C++ > with no success. > I also tried many times to use the 'mcc' function in matlab & convert the > normxcorr2.m into C/C++ but it's issuing so many problems I'll spare you > with. > > Can you direct me to a good source or advise me with a solution? > > Thanks in advance.Type the following into google: cross correlation c++ source code The first hit has source code for finding the 2-D cross-correlation. It is that easy!
