Hi, I wanna implement a low pass IIR filter in C2407 using the 24x Filter library. I am a new comer to this kind of implementation. /*After the initation:*/ { iir.dbuffer_ptr=dbuffer; iir.coeff_ptr=coeff; iir.qfmat=IIR_LPF_QFMAT; iir.nbiq=IIR_LPF_NBIQ; iir.isf=IIR_LPF_ISF; iir.init(&iir); } while(ADUPDATE) /*new adc coming*/ { iir.input=xn; /*new value into delay buffer*/ iir.calc(&iir); /*fir calculation*/ yn=(iir.output<<1); ADUPDATE=0; } I met some problem i can not explain. 1) If I directly set xn=100, I found yn is always be zero. 2) if I set xn=8005, then , yn=7896 set xn=2048, then, yn= 969 xn=4096, yn= 1968 xn=8182, yn= 4025 I remembered the FIR filter implementation i did yesterday, if I set xn=1000, then yn=1000.
using IIR filter library for C2000 DSP
Started by ●May 21, 2006
Reply by ●May 22, 20062006-05-22
