one low pass IIR filter is implemented on a fixed-pointed DSP, say, TI C5402. The IIR filter itself is stable. IF the input to the filter is one constant value (DC signal ), eg, X input= 1000; so, afte the stabilization, the output from the IIR filter is also 1000? or some value less than 1000? Actually, I just wonder that the output will be less than 1000 because of the finite word length effects. I am a new comer, so help me. Thanks
a question on IIR low pass filter
Started by ●May 23, 2006
Reply by ●May 23, 20062006-05-23
Simon wrote:> one low pass IIR filter is implemented on a fixed-pointed DSP, > say, TI C5402. > > The IIR filter itself is stable. > IF the input to the filter is one constant value (DC signal ), > eg, X input= 1000; > > so, afte the stabilization, the output from the IIR filter is > also 1000? or some value less than 1000?If H(z) is the filter's transfer function, the ideal steady-state DC output is H(1) * 1000 which could be any finite value, in principle. I guess you're making the unstated assumption that H(1) = 1?> Actually, I just wonder that the output will be less than 1000 > because of the finite word length effects. I am a new comer, so > help me. ThanksFinite arithmetic effects can disturb the values of |H(z)| in either direction. Consider the possibility that coefficient quantization shifts a nominally stable high-Q pole right onto the unit circle. The same may happen to a zero, and in either case the shift may be inwards too. Martin -- Quidquid latine scriptum sit, altum viditur.
