PCI 64/66 fpga eval boards
Started by Unknown ●May 23, 2006
Folks,
After search the net for various eval boards, I haven't found the one
that I need and afford... that is so oxymoronic... nevertheless, I
figured I might try the community before making a decision.
I am looking for an FPGA proto board that sits on a 64/66 PCI on a ATX
motherboard.  Since we are on a budget we would like to stick with low
end devices such as Spartan 3 or Cyclone 2 with possibility to add more
FPGA modules as we need them.
I found one at http://www.4dsp.com/PCI.htm
Unfortunately, it seems that it has a 32/33 pci interface.
Any suggestions?
Thank you.
Best regards,
-Sanjay
Hi Sanjay,
I'm afraid I can't answer your question directly, but I can offer some
food for thought. Be very careful treading into 64/66 PCI territory.
The technology is new(ish), somewhat unproven, and mostly untested.
I've had experience with board vendors that flat out lie about the
64/66 capability of the boards or at least they never bothered to test
to see if it really worked.
Be sure you REALLY need that extra throughput. Good luck
MJ
Hi,
I do not get exactly what it is you are looking for ?
PCI TIM MotherBoard ?
Rgds,
John
<fpgabuilder-groups@yahoo.com> a &#4294967295;crit dans le message de
news:1148398325.753179.326230@38g2000cwa.googlegroups.com...
> Folks, > > After search the net for various eval boards, I haven't found the one > that I need and afford... that is so oxymoronic... nevertheless, I > figured I might try the community before making a decision. > > I am looking for an FPGA proto board that sits on a 64/66 PCI on a ATX > motherboard. Since we are on a budget we would like to stick with low > end devices such as Spartan 3 or Cyclone 2 with possibility to add more > FPGA modules as we need them. > > I found one at http://www.4dsp.com/PCI.htm > > Unfortunately, it seems that it has a 32/33 pci interface. > > Any suggestions? > > Thank you. > Best regards, > -Sanjay >
Hi again,
I have one of
http://www.hunteng.co.uk/legacy_products/hepc4.htm
plus a couple of TIM processing modules.
If ever this is what you are looking for.
Rgds,
John
John, MJ,
Thank you for the suggestions.  I am not sure what TIM stands for but
seems like some standard connector/interface for FPGA modules.  But
thats right, I am looking for a 64bit/66MHz card with fpgas.
I wanted to experiment with some interfaces and needed CPU to
communicate with the FPGAs over PCI.
BTW, I am surprised that 64/66 would still be new.  I used a 64/66 MHz
cPCI core in an FPGA about 3 years ago.  And as far as I can tell we
did not have any problems with the cPCI based processor boards.
Nevertheless, thanks for the heads up.
-sanjay
John Aderseen wrote:
> Hi again, > > I have one of > http://www.hunteng.co.uk/legacy_products/hepc4.htm > plus a couple of TIM processing modules. > If ever this is what you are looking for. > > Rgds, > John > > <fpgabuilder-groups@yahoo.com> a =E9crit dans le message de > news:1148398325.753179.326230@38g2000cwa.googlegroups.com... > > Folks, > > > > After search the net for various eval boards, I haven't found the one > > that I need and afford... that is so oxymoronic... nevertheless, I > > figured I might try the community before making a decision. > > > > I am looking for an FPGA proto board that sits on a 64/66 PCI on a ATX > > motherboard. Since we are on a budget we would like to stick with low > > end devices such as Spartan 3 or Cyclone 2 with possibility to add more > > FPGA modules as we need them. > > > > I found one at http://www.4dsp.com/PCI.htm > > > > Unfortunately, it seems that it has a 32/33 pci interface. > > > > Any suggestions? > > > > Thank you. > > Best regards, > > -Sanjay > >
On Wed, 24 May 2006 01:19:40 -0700, fpgabuilder wrote:
> > Thank you for the suggestions. I am not sure what TIM stands for but > seems like some standard connector/interface for FPGA modules.
Texas Instruments Module. See http://www.hunteng.co.uk/legacy_products/tim40.htm ~Dave~
In sci.electronics.design mljohnson00@yahoo.com wrote:
>Hi Sanjay,
>I'm afraid I can't answer your question directly, but I can offer some >food for thought. Be very careful treading into 64/66 PCI territory. >The technology is new(ish), somewhat unproven, and mostly untested. >I've had experience with board vendors that flat out lie about the >64/66 capability of the boards or at least they never bothered to test >to see if it really worked.
Isn't PCI 64/66 a dead end considering PCI-express these days ?
Isn't ISA a dead end considering PCI, yet it is still used !!!!
<pbdelete@spamnuke.ludd.luthdelete.se.invalid> a &#4294967295;crit dans le message de
news: 4474b0be$0$490$cc7c7865@news.luth.se...
> In sci.electronics.design mljohnson00@yahoo.com wrote: >>Hi Sanjay, > >>I'm afraid I can't answer your question directly, but I can offer some >>food for thought. Be very careful treading into 64/66 PCI territory. >>The technology is new(ish), somewhat unproven, and mostly untested. >>I've had experience with board vendors that flat out lie about the >>64/66 capability of the boards or at least they never bothered to test >>to see if it really worked. > >>Be sure you REALLY need that extra throughput. Good luck > > Isn't PCI 64/66 a dead end considering PCI-express these days ? >
In article <4474ba59$0$294$7a628cd7@news.club-internet.fr>,
John@nospam.com says...
> Isn't ISA a dead end considering PCI, yet it is still used !!!! >
ISA is still used because it's trivial to hack. PCI is anything but. -- Keith
On 23 May 2006 08:32:05 -0700, fpgabuilder-groups@yahoo.com wrote:
>Folks, > >After search the net for various eval boards, I haven't found the one >that I need and afford... that is so oxymoronic... nevertheless, I >figured I might try the community before making a decision. > >I am looking for an FPGA proto board that sits on a 64/66 PCI on a ATX >motherboard. Since we are on a budget we would like to stick with low >end devices such as Spartan 3 or Cyclone 2 with possibility to add more >FPGA modules as we need them. > >I found one at http://www.4dsp.com/PCI.htm > >Unfortunately, it seems that it has a 32/33 pci interface. > >Any suggestions? > >Thank you. >Best regards, >-Sanjay
Try this UK base company. We have used their products on PCI64. http://www.alpha-data.com/ --- Mark
