DSp/BIOs in CCS
Started by jayadevan May 31, 2006
Hi all...
I am jayadevan,a student from india.As part of my course curriculum i am
doing a project on image processing implemented using DSP/BIOS.
i have to read an image file in the raw file format.
but i dont know how to read a file in dsp/bios.
my c++ code is
FILE *fi;
fi=fopen("apple1.raw","rb");
this code segment is not working.it says FILE and f1 is undefined
jayadevan wrote:
> Hi all... > > I am jayadevan,a student from india.As part of my course curriculum i am > doing a project on image processing implemented using DSP/BIOS. > > i have to read an image file in the raw file format. > but i dont know how to read a file in dsp/bios. > > my c++ code is > FILE *fi; > fi=fopen("apple1.raw","rb"); > > this code segment is not working.it says FILE and f1 is undefined
The C/C++ implementation does not support all of the library functions, such as fopen(), that a common in a compiler platform for a PC due to resource limitations in typical embedded hardware. Since you are using CCS, consider using probe points to communicate between a PC and your application. I believe that you can also use RTDX, though I have never done so. The tutorials in CCS will provide you with examples of both methods.
Have you remembered to #include <stdio.h>? Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
"jayadevan" <jaggunitj@yahoo.co.uk> wrote:
>... i am >doing a project on image processing implemented using DSP/BIOS. >i have to read an image file in the raw file format. >but i dont know how to read a file in dsp/bios. > >my c++ code is >FILE *fi; >fi=fopen("apple1.raw","rb"); > >this code segment is not working.it says FILE and f1 is undefined
Read a file where? In a system running DSP/BIOS, or in the host system running CCS, used to develop DSP/BIOS applications. The former is impossible, DSP/BIOS does not support a file system. If you want to supply data from a file in the host PC to a DSP/BIOS application there are a few ways to do that. For a "one time/one data set only" exercise, you can embed the data file as an array of the appropriate type in your C or C++ code. If you want to change the data dynamically, or if the data set is to big to be embedded, you can read it into the system via hardware (does your target board have a serial port, SPI, USB, ethernet, etc.) or you can send it using a combination of DSP/BIOS features and CCS support. Read the documentation for Real Time Data eXchange, Probe points, etc. The examples supplied with CCS will be helpful.
