hey guys, We can get the phase of a signal by performing the FFT (from the real and imaginary components) on the signal. If we perform hilbert transform on a signal it gives us analytical signal from which we can get the instantaneous phase of that signal. How the phase of a signal obtained by performing FFT differs from the phase obtained by using hilbert transform. Is there any differnce ? if yes, what is it? Thanks in advance, Rajan.
Differnce between the phase obtained by FFT and the hilbert transform
Started by ●June 1, 2006
Reply by ●June 1, 20062006-06-01
Rajan wrote:> hey guys, > We can get the phase of a signal by performing the FFT (from the real and > imaginary components) on the signal. If we perform hilbert transform on a > signal it gives us analytical signal from which we can get the > instantaneous phase of that signal. How the phase of a signal obtained by > performing FFT differs from the phase obtained by using hilbert transform. > Is there any differnce ? if yes, what is it? > > Thanks in advance, > Rajan.The HT gives phase vs time. The FFT gives phase vs frequency. John
Reply by ●June 2, 20062006-06-02
> >Rajan wrote: >> hey guys, >> We can get the phase of a signal by performing the FFT (from the realand>> imaginary components) on the signal. If we perform hilbert transform ona>> signal it gives us analytical signal from which we can get the >> instantaneous phase of that signal. How the phase of a signal obtainedby>> performing FFT differs from the phase obtained by using hilberttransform.>> Is there any differnce ? if yes, what is it? >> >> Thanks in advance, >> Rajan. > >The HT gives phase vs time. The FFT gives phase vs frequency. > >John > >John, Thanks for the reply, The "hilbert" function is available in MATLAB - i.e. "hilbert(xr,n)" which uses an n point FFT to compute the Hilbert transform. Does it give phase vs frequency ? or phase vs time?
Rajan wrote:> > > >Rajan wrote: > >> hey guys, > >> We can get the phase of a signal by performing the FFT (from the real > and > >> imaginary components) on the signal. If we perform hilbert transform on > a > >> signal it gives us analytical signal from which we can get the > >> instantaneous phase of that signal. How the phase of a signal obtained > by > >> performing FFT differs from the phase obtained by using hilbert > transform. > >> Is there any differnce ? if yes, what is it? > >> > >> Thanks in advance, > >> Rajan. > > > >The HT gives phase vs time. The FFT gives phase vs frequency. > > > >John > > > > > > > > John, Thanks for the reply, > The "hilbert" function is available in MATLAB - i.e. "hilbert(xr,n)" which > uses an n point FFT to compute the Hilbert transform. Does it give phase vs > frequency ? or phase vs time?It follows the FFT with an IFFT to go back to time domain. John
