Hi, Can anyone point out about sub-band synthesis filter used in DAB systems ? I have the algorithm for sub-band analysis filter that is used in MPEG layer II encoder. But i am unable to understand how the reverse process is acheived with the same parameters as that in encoder. Thanks, Sunil
Started by ●June 30, 2004
Reply by ●June 30, 20042004-06-30
Sunil Shukla wrote:> Hi, > > Can anyone point out about sub-band synthesis filter used in DAB systems ? > I have the algorithm for sub-band analysis filter that is used in MPEG layer > II encoder. > But i am unable to understand how the reverse process is acheived with the > same parameters as that in encoder. > > Thanks, > Sunil > >I'm not sure about DAB or MPEG, but Crochiere & Rabiner's Multirate book has a good section on analysis/synthesis filters and polyphase implementation thereof. -- Mark
