hi We are using the McBSP module to communicate to an FPGA To simulate this I will use 2 2812 DSK's constraints are External clock coming from FPGA is 4MHz. The hardware initialization capability shall initialize the McBSP module of the DSP to receive in slave mode and transmit in master mode.On transmitting/receiving MSb is shifted out/in from the FIFO�s which is the default McBSP setting The design constraints are 1) Transmission master, FIFO, 16-bit words, no interrupts, and external clock; 2) Receiving - slave, FIFO, 32 bit words, no interrupts, external clock. 3) FS signal is active High for MSb of each message and is coincident with the first data bit (i.e. RDATDLY and XDATDLY are 0) 4) FIFO limits: receiving 7 32-bit words sending 12 16-bit words It is unclear what value to put in bit FIELD FPER of McBsp Rewgister SRGR2 to generate a frame sync period] Have had no luck seeing any received data in FIFO Any help appreciated Settings are // sender #include "hw_mcbsp.h" #include "dsp2812_mcbsp.h" // Define the level of the FIFO 1-16 #define FIFO_LEVEL 7 #define WORD_SIZE 32 // Run atest in 32-bit mode // Prototype statements for functions found within this file. // Global data for this example unsigned int sdata1 = 0x000; // Sent Data unsigned int rdata1 = 0x000; // Recieved Data unsigned int sdata2 = 0x000; // Sent Data unsigned int rdata2 = 0x000; // Recieved Data unsigned int rdata1_point; unsigned int rdata2_point; unsigned int DCEMsg[16] = {0xE787,0,0x8000,0,0,0,0xC865,0,0,0,0,0,0,0,0xAAAA,0xAAAA}; void InitializeDCEMCBSP(void) { unsigned int i; McbspaRegs.MFFTX.all=0x0000; // McBSP FIFO recieve register bit definitions: McbspaRegs.MFFRX.all=0x001F; // McBSP FIFO control register bit definitions: McbspaRegs.MFFCT.all=0x0; McbspaRegs.MFFINT.all=0x0; McbspaRegs.MFFST.all=0x0; McbspaRegs.MFFTX.bit.MFFENA=1; // Enable FIFO McbspaRegs.MFFTX.bit.TXFIFO_RESET=1; // Enable Transmit channel McbspaRegs.MFFRX.bit.RXFIFO_RESET=1; // Enable Receive channel // SPCR2 control register bit definitions: McbspaRegs.SPCR2.all=0x0000; // SPCR1 control register bit definitions: #ifdef LOOP_BACK McbspaRegs.SPCR1.bit.DLB =1; //loopback #endif McbspaRegs.SPCR1.bit.CLKSTP =2; //Clock starts with rising edge // RCR2 control register bit definitions: McbspaRegs.RCR2.all=0x0; McbspaRegs.RCR2.bit.RFIG = 1; // Ignore extra FS McbspaRegs.RCR2.bit.RFRLEN2=0x6; // recieve 7 words McbspaRegs.XCR2.all=0x02; // Ignore Extra Tx Sync Pulse McbspaRegs.XCR2.bit.XRFRLEN2 = 11; //12 16 bit words in frame // SRGR1 control register bit definitions: // PCR control register bit definitions: McbspaRegs.XCR2.all=0x02; // Ignore Extra Tx Sync Pulse McbspaRegs.XCR1.all=0x0; // SRGR2 Sample rate generator control register bit definitions: McbspaRegs.SRGR2.all=0x2000; McbspaRegs.SRGR2.bit.FPER = 800; //FS every 2 mSec McbspaRegs.SRGR2.bit.CLKSM = 1; McbspaRegs.MCR2.all=0x0; McbspaRegs.MCR1.all=0x0; McbspaRegs.PCR.bit.CLKRM = 1; //1 CLKR is an output pin and is driven // by the internal sample rate generator. McbspaRegs.PCR.bit.CLKXM = 1; //1 CLK(R/X) is an output pin and is driven //by the internal sample rate generator. McbspaRegs.PCR.bit.FSXM = 1; //Frame synchronization generated internally by sample rate generator. FSR is // an output pin except when GSYNC = 1 in SRGR. McbspaRegs.SRGR1.bit.CLKGDV = 80; // .375 MHz McbspaRegs.RCR1.bit.RWDLEN1=5; // 32-bit word McbspaRegs.XCR1.bit.XWDLEN1=5; // 32-bit word McbspaRegs.XCR1.bit.XFRLEN1 = 7; // tx 8 32 bit words McbspaRegs.SPCR2.bit.XRST =1; // enable XRST/RRST McbspaRegs.SPCR1.bit.RRST=1; delay_loop(); McbspaRegs.SPCR2.all |=0x00C0; // Only enable FRST,GRST used after } // Step 5. User specific code, void test_DCE_mcbsp(void) { int i; for(i = 0; i < FIFO_LEVEL; i++) { DCE_mcbsp_xmit(DCEMsg[(i*2)+1],DCEMsg[i*2]); } } // Some Useful local functions void delay_loop() { long i; for (i = 0; i < 1000000; i++) {} } void DCE_mcbsp_xmit(int a, int b) { McbspaRegs.DXR2.all=b; McbspaRegs.DXR1.all=a; } // TITLE: DSP281x CE Receiver McBSP Simulator program. // #include "hw_mcbsp.h" #include "dsp2812_mcbsp.h" // Define the level of the FIFO 1-16 #define FIFO_LEVEL 8 #define WORD_SIZE 32 // Run a loopback test in 32-bit mode // Prototype statements for functions found within this file. void init_mcbsp_32bit(void); void CE_mcbsp_xmit(int a, int b); void test_mcbsp(void); void init_mcbsp_dcebit(); // Global data for this example unsigned int CEMsg[16] = {0xE787,0,0x8000,0,0,0,0xC865,0,0,0,0,0,0,0,0xAAAA,0xAAAA}; void InitializeCEMCBSP(void) { unsigned int i; GpioMuxRegs.GPFMUX.all=0x3f3f; // Select GPIOs to be McBSP pins McbspaRegs.MFFTX.all=0x0000; // McBSP FIFO recieve register bit definitions: McbspaRegs.MFFRX.all=0x001F; // McBSP FIFO control register bit definitions: McbspaRegs.MFFCT.all=0x0; McbspaRegs.MFFINT.all=0x0; McbspaRegs.MFFST.all=0x0; McbspaRegs.MFFTX.bit.MFFENA=1; // Enable FIFO McbspaRegs.MFFTX.bit.TXFIFO_RESET=1; // Enable Transmit channel McbspaRegs.MFFRX.bit.RXFIFO_RESET=1; // Enable Receive channel McbspaRegs.SPCR2.all=0x0000; // SPCR1 control register bit definitions: #ifdef LOOP_BACK McbspaRegs.SPCR1.bit.DLB =1; //loopback #endif McbspaRegs.SPCR1.bit.CLKSTP =2; //Clock starts with rising edge // RCR2 control register bit definitions: McbspaRegs.RCR2.all=0x0; // McbspaRegs.RCR1.all=0x0; McbspaRegs.RCR2.bit.RFRLEN2=0x6; // recieve 7 words McbspaRegs.RCR2.bit.RFIG = 1; // Ignore extra FS McbspaRegs.XCR2.all=0x02; // Ignore Extra Tx Sync Pulse McbspaRegs.XCR2.bit.XRFRLEN2 = 11; //12 16 bit words in frame // SRGR1 control register bit definitions: McbspaRegs.XCR2.all=0x02; // Ignore Extra Tx Sync Pulse McbspaRegs.XCR1.all=0x0; McbspaRegs.SRGR2.all=0x2000; McbspaRegs.SRGR2.bit.FPER = 800; //FS every 2 mSec McbspaRegs.SRGR2.bit.CLKSM = 1; McbspaRegs.MCR2.all=0x0; McbspaRegs.MCR1.all=0x0; McbspaRegs.PCR.all=0x00a00; McbspaRegs.SRGR1.bit.CLKGDV = 80; // .375 MHz McbspaRegs.RCR1.bit.RWDLEN1=5; // 32-bit word McbspaRegs.XCR1.bit.XWDLEN1=5; // 32-bit word McbspaRegs.XCR1.bit.XFRLEN1 = 7; // tx 8 32 bit word // McBSP Reset to enable McbspaRegs.SPCR2.bit.XRST =1; // enable XRST/RRST McbspaRegs.SPCR1.bit.RRST=1; delay_loop(); McbspaRegs.SPCR2.all |=0x00C0; // Only enable FRST,GRST used after } // Step 5. User specific code, void test_CE_mcbsp(void) { int i; for(i = 0; i < FIFO_LEVEL; i++) { CE_mcbsp_xmit(CEMsg[(i*2)+1],CEMsg[i*2]); } } void CE_mcbsp_xmit(int a, int b) { McbspaRegs.DXR2.all=b; McbspaRegs.DXR1.all=a; }
McBsp Problems
Started by ●June 5, 2006
