Hello, I was wondering if somebody could help me and explain some details for me a little bit, help would be greatfully appreciated; I'm studying this paper titled "Fast algorithms for Discrete and Continuous Wavelet Transform" by Olivier Rioul and Pierre Duhamel. I'm trying to implement a fast DWT/CWT algorithm based on this paper, it basically details a way of performing a fast DWT algorithm via an implementation based on a filterbank, it splits the input signal into odd and even parts and you perform a FFT on these parts, and multiply this with the resultant FFT with a low and high pass filter, then you reconstruct the output via an IFFT. I'm looking to implement a CWT from this basic DWT algorithm but I am having some trouble understanding how these high and low filters are constructed from my choosen Mother Wavelet, I think the gist of it is basically to approximate the Mother Wavelet via an interpolation function (such as a B-Spline) and from that a lowpass filter is created (and presumable from some basic DSP theroy I can construct a high pass filter from this???) but it doesn't explain it very well at all, could somebody point me in the right direction, expand a little further, or point me at a document which may help? Maybe somebody here has covered something simular? I'm looking to implement this with a Gabor Wavelet function, I've done some research which has initially pointed me at something called a Log Gabor function, which can be constructed in the frequency domain, which does sound like the kind of thing I would be looking for, but producing a high/low pass filter split per DWT cell seems a bit of a mystery to me..? I ought to point out I have no interest in reconstructing the original input signal from the CWT afterward, I understand that this may simplify the construction of the filters somewhat? (something to do with convergences?) I'm basically looking to implement a naive version first, that just works in C++, and I think I'm almost there with the exception of the construction of these filters - maybe I'm missing out on some basic DSP theory. Thankyou for your time!
wavelet filterbank - filter construction? highpass/lowpass
Started by ●June 5, 2006
