Oops...obviously I meant to say that the notch for the second harmonic should be at 100Hz. 'scuse the confusion.... Rick Lyons wrote:> On Mon, 05 Jun 2006 12:51:37 -0500, "gpdsoft" <gpdsoftware@yahoo.it> > wrote: > > >Hi, > >I have do write a procedure in Delphi that take an array of samples and > >filters it. > > > >The filter I've to do is Notch to cut out the 50Hz from my signal. > > > >My signal is sampled at 50Khz for a max of 250 millisec. > > > >Do you know where I can find the code or something similar to quickly > >implement this function in my software? > > > >Thnx a lot > > Hello gpdsoft, > > Implement a filter whose time-domain > expression is: > > y(n) = x(n) + Kx(n-1) + x(n-2). > > Variable y(n) is the filter's output, and variable > x(n) is the filter's input. > > The value for K is: > > K = -2cos(2*pi*fn/fs) > > where fn is 50 Hz, and fs is 50 kHz. > > Good Luck, > [-Rick-]
How to write a NotchFilter procedure
Started by ●June 5, 2006
Reply by ●June 7, 20062006-06-07
Reply by ●June 11, 20062006-06-11
Hi, I think I've resolved my problem... thnx to all for the help! This is the code I used to notch 50Hz from my signal (the code is in Delphi/pascal language) //CC is the array of samples to filter CutFreq:=50; //50Hz FS:=50000; //SampleRate 50KHz for n:=0 to CC.length-1 do begin cos50:=(cos(((2*pi)*CutFreq * n)/FS) ); sin50:=(sin(((2*pi)*CutFreq * n)/FS) ); I:=CC[n]* cos50; Q:=CC[n]* sin50; TotI:=TotI+(I); TotQ:=TotQ+(Q); end; for n:=0 to CC.Length-1 do begin cos50:=(cos(((2*pi)*CutFreq * n)/FS) ); sin50:=(sin(((2*pi)*CutFreq * n)/FS) ); Tone:=(2/OriginalSignal.length)*(TotI*cos50 + TotQ*sin50); CC[n]:=CC[n]-Tone; end; This code works well!
