One thing that I noticed is that if you drag the magnitude DC bin up, it creates a DC offset on the Real input samples, as expected. What wasn't intuitive to me was that no matter what size I made the DC bin, the Real DC offset was the same apparent magnitude, rather than being scaling with magnitude. Upon a little further experimentation, it looks like there is some auto-scaling going on. "Stephan M. Bernsee" <spam@dspdimension.com> wrote in message news:42c34ef.0407010926.582a481d@posting.google.com...> Hmm, I'm not sure what you mean... you can click and drag the mouse > within these "lollipop" displays to change the curves... is that what > you're referring to? That's the whole point about the applet. Do you > find that in any way unclear? > > --smb > > Bernhard Holzmayer <holzmayer.bernhard@deadspam.com> wrote in message news: > > > > It took some time until I happened to find out that curves can be > > modified using the mouse pointer. > > > > I'd propose that you add a hint for newbies... > > > > Bernhard
FftLab Java Applet - Revisited
Started by ●June 30, 2004
Reply by ●July 1, 20042004-07-01
Stephan M. Bernsee wrote:> I've included a downloadable offline version on that page. > > --smb1st item. *THANK YOU* I'm a 'visual learner' and formal math leaves me lost ;{ 2nd item. (Here I may demonstrate my Java ignorance) Could you post the source code? (Would it be as useful as I might think?) [ Mr. Holzmayer's post seemed to imply source would be intrinsically available.] My immediate objective: Add option to 'Editing' drop down menu which would allow entering an analytic function rather than a freehand drawn approximation. My underlying objective: I am totally lost when considering 'windowing' and/or 'DFT Leakage' and/or etc. Rick Lyons , Jerry Avins, and others have spent much time trying to verbally explain things to me. An immediate partial goal. FORCE input samples ( top left sub-window ) to be an arbitrarily defined function. ( imaginary values == 0 ) A typical use would be to reproduce Figure 3-7/3-8 of _Understanding Digital Signal Processing_ 2nd Edition by R. Lyons ( and arbitrary variants) Have I expressed myself clearly?
Reply by ●July 2, 20042004-07-02
Stephan M. Bernsee wrote:> Hmm, I'm not sure what you mean... you can click and drag the > mouse within these "lollipop" displays to change the curves... is > that what you're referring to? That's the whole point about the > applet. Do you find that in any way unclear? > > --smbYes. It happened like this: At first glance, I noticed the selection gadgets on the bottom. Very little happened when I played with them. So I reckoned there must be more about it, and it just happened that I clicked into one of the drawings while 'draw' mode was active. I was stunned: the curve changed. Tried it again: oohh! There would have been good chance, that I wouldn't have tried to click into the curve canvases, because they look like 'display-only' elements which would not accept input. That's not obvious to a typical GUI user. I wouldn't have bothered. But I did, because you need to know, or you can't use the applet. Tiny note saying something like: "use mouse on curves" would help. Or, if you don't want to spoil the window by such a thing, a message box opening once in the beginning of the first session, might give some explanations... Bernhard
Thanks for the suggestions. I will put them on my list of to-do items for the page since I will require some time to implement them, and I don't have much spare time at the moment. Especially the playback option and the evaluation of expressions would make very nice additions. --smb
Ok, all valid points. I know that as the creator of something you usually know how to use it (obviously), but even so I figured it might be obvious - maybe because it was to me when I first came across Dave Hale's applet (who wrote the original version). At any rate, thanks for the feedback, I'll include a brief how-to on that page soon. --smb Bernhard Holzmayer <holzmayer.bernhard@deadspam.com> wrote in message news:<1402350.nzUpPJ8bNS@holzmayer.ifr.rt>...> Stephan M. Bernsee wrote: > > > Hmm, I'm not sure what you mean... you can click and drag the > > mouse within these "lollipop" displays to change the curves... is > > that what you're referring to? That's the whole point about the > > applet. Do you find that in any way unclear? > > > > --smb > > Yes. It happened like this: > At first glance, I noticed the selection gadgets on the bottom. > Very little happened when I played with them. > So I reckoned there must be more about it, and it just happened that > I clicked into one of the drawings while 'draw' mode was active. > I was stunned: the curve changed. > Tried it again: oohh! > > There would have been good chance, that I wouldn't have tried to > click into the curve canvases, because they look like > 'display-only' elements which would not accept input. > > That's not obvious to a typical GUI user. > I wouldn't have bothered. But I did, because you need to know, or > you can't use the applet. > > Tiny note saying something like: "use mouse on curves" would help. > Or, if you don't want to spoil the window by such a thing, > a message box opening once in the beginning of the first session, > might give some explanations... > > > Bernhard
