Dear comp.dsp, I am using the ADI 21364 EZKIT Lite with Visual DSP++. I want to implement some basic audio processing algorithms here in C. To start, there is a "Block Based TalkThru" example, wherein I am provided with a function which received a pointer to 1024 samples, which are "unsigned int" values. Now, pass through works properly, but even if I replace every sample with half of it's value, it starts "crackling". I have tried many things, like converting it to "int", extracting various buts etc. but in vain. If you have seen this example, could you please tell me how to extract the sample from the unsigned int? I could not fin this information on ADI's website, or the documentation. Thanks. Kumar
Using the Block Based TalkThru example in the Analog Devices 21364 EZ-KIT
Started by ●June 14, 2006
Reply by ●June 14, 20062006-06-14
kmap wrote:> To start, there is a "Block Based TalkThru" example, wherein I am > provided with a function which received a pointer to 1024 samples, > which are "unsigned int" values. Now, pass through works properly, but > even if I replace every sample with half of it's value, it starts > "crackling". I have tried many things, like converting it to "int", > extracting various buts etc. but in vain.Sorry for replying to my own post, but I got the answer here: http://www.dsprelated.com/groups/adsp/show/4624.php Kumar
