Folks, Did I miss something in the last few years? Do they really have "infinite-precision" digital filters? This paper's abstract seems to say so. Please set me straight. --Randy From http://ieeexplore.ieee.org/xpls/abs_all.jsp?tp=&arnumber=1205815&isnumber=27140 An optimal entropy coding scheme for efficient implementation of pulse shaping FIR filters in digital receivers Vinod, A.P. Premkumar, A.B. Lai, E.M.-K. Sch. of Comput. Eng., Nanyang Technol. Univ., Singapore; This paper appears in: Circuits and Systems, 2003. ISCAS '03. Proceedings of the 2003 International Symposium on Publication Date: 25-28 May 2003 Volume: 4, On page(s): IV-229- IV-232 vol.4 ISSN: ISBN: 0-7803-7761-3 INSPEC Accession Number: 7762555 Digital Object Identifier: 10.1109/ISCAS.2003.1205815 Posted online: 2003-06-25 15:31:41.0 Abstract The most computationally intensive part of wide-band receivers is the IF processing block. Digital filtering is the main task in IF processing. Infinite precision filters require complicated digital circuits due to coefficient multiplication. This paper presents an efficient method to implement pulse shaping filters for a dual-mode GSM/W-CDMA receiver. We use an arithmetic scheme, known as pseudo floating-point (PFP) representation to encode the filter coefficients. By employing a span reduction technique, we show that the filters can be coded using an optimal entropy scheme employing PFP which requires only considerably fewer bits than conventional 24-bit and 16-bit fixed-point filters. Simulation results show that the magnitude responses of the filters coded in PFP meet the attenuation requirements of GSM/W-CDMA specifications.
Infinite-Precision Dgital Filters
Started by ●June 17, 2006
Reply by ●June 17, 20062006-06-17
Randy Yates wrote:> Folks, > > Did I miss something in the last few years? Do they really > have "infinite-precision" digital filters? This paper's > abstract seems to say so. Please set me straight.My very simple view is that a finite representation of a number (i.e. a finite number of bits or digits), necessarily implies that there is a finite number of states of that representation, and hence a finite number of... ehm... numbers. In this finite set of numbers, there must necessarily be at least one that is in some sense "the smallest", and hence we have finite precision. The consequence of all this, is that an infinte number of digits/bits is needed to obtain infinite precision. That's how I would argue against such a claim. But then, I'm but an engineer. Rune
Rune Allnor wrote:> > Randy Yates wrote: >> Folks, >> >> Did I miss something in the last few years? Do they really >> have "infinite-precision" digital filters? This paper's >> abstract seems to say so. Please set me straight. > > My very simple view is that a finite representation of a number > (i.e. a finite number of bits or digits), necessarily implies that > there is a finite number of states of that representation, and > hence a finite number of... ehm... numbers. > > In this finite set of numbers, there must necessarily be at least > one that is in some sense "the smallest", and hence we have > finite precision. > > The consequence of all this, is that an infinte number of > digits/bits is needed to obtain infinite precision. > > That's how I would argue against such a claim. But then, I'm > but an engineer. > > RuneIsn't any BIBO stable filter "infinite-precision", if they are implemented with integer coefficients and integer samples? "Infinite-precision" in the sense that the filter does not increase the quantization noise. Obviously such filter can be implemented with finite-number of bits. The loss in the precision happens before the filtering (i.e., in the sampling stage). -- Jani Huhtanen Tampere University of Technology, Pori
Randy Yates wrote:> Folks, > > Did I miss something in the last few years? Do they really > have "infinite-precision" digital filters? This paper's > abstract seems to say so. Please set me straight. > > --Randy > >...> Infinite precision filters require complicated digital > circuits due to coefficient multiplication.My guess is that they are alluring to the wide accumulator needed for FIRs (hinted at by the use of "pseudo-floating-point", whatever that is). Regards, Andor
Randy Yates wrote:> Folks, > > Did I miss something in the last few years? Do they really > have "infinite-precision" digital filters? This paper's > abstract seems to say so. Please set me straight. > > --Randy > > > From >http://ieeexplore.ieee.org/xpls/abs_all.jsp?tp=&arnumber=1205815&isnumber=27140>Heh, funny. They seem to refer to coefficients represented with floating point numbers as "infinite-precision". From the paper: "The infinite-precision filter, h(n), is generated by the raised cosine FIR filter design program provided by the MATLAB ?firrcos? function.". As far as I know, Matlab isn't really that good ;) @Andor: Pseudo floating-point is their representation for quantized numbers. They encode a value in two parts: shift (exponent) and span (mantissa). Basicly the shift tells how many bits the span has to be shifted to obtain the actual value. -- Jani Huhtanen Tampere University of Technology, Pori
Jani Huhtanen wrote: ...> http://ieeexplore.ieee.org/xpls/abs_all.jsp?tp=&arnumber=1205815&isnumber=27140 > > > > Heh, funny. They seem to refer to coefficients represented with floating > point numbers as "infinite-precision". From the paper: > "The infinite-precision filter, h(n), is generated by the > raised cosine FIR filter design program provided by the > MATLAB ?firrcos? function.". > > As far as I know, Matlab isn't really that good ;) > > @Andor: > Pseudo floating-point is their representation for quantized numbers. They > encode a value in two parts: shift (exponent) and span (mantissa).Now all the need is a sign bit, and they can drop the pseudo prefix. Guess I gave them too much credit in my first post. Sad.
Hi Jani, Thank you for making explicit this notion that was also floating around in my head. However..., the paper seems to imply that you can start with an *arbitrary* infinite-precision filter and then implement it with digital circuits. Are my language interpretation skills sliding, or is there statement, at a minimum, unclear? --Randy Jani Huhtanen wrote:> Rune Allnor wrote: > > > > > Randy Yates wrote: > >> Folks, > >> > >> Did I miss something in the last few years? Do they really > >> have "infinite-precision" digital filters? This paper's > >> abstract seems to say so. Please set me straight. > > > > My very simple view is that a finite representation of a number > > (i.e. a finite number of bits or digits), necessarily implies that > > there is a finite number of states of that representation, and > > hence a finite number of... ehm... numbers. > > > > In this finite set of numbers, there must necessarily be at least > > one that is in some sense "the smallest", and hence we have > > finite precision. > > > > The consequence of all this, is that an infinte number of > > digits/bits is needed to obtain infinite precision. > > > > That's how I would argue against such a claim. But then, I'm > > but an engineer. > > > > Rune > > Isn't any BIBO stable filter "infinite-precision", if they are implemented > with integer coefficients and integer samples? "Infinite-precision" in the > sense that the filter does not increase the quantization noise. Obviously > such filter can be implemented with finite-number of bits. The loss in the > precision happens before the filtering (i.e., in the sampling stage). > > -- > Jani Huhtanen > Tampere University of Technology, Pori
Reply by ●June 18, 20062006-06-18
Randy Yates wrote:> Hi Jani, > > Thank you for making explicit this notion that was > also floating around in my head. > > However..., the paper seems to imply that you can start > with an *arbitrary* infinite-precision filter and then > implement it with digital circuits.Yes it seems so. They also claim that Matlabs firrcos function can be used to create such infinite-precision coefficients :). So one just has to substitute 'infinite-precision' with 'floating-point' and all makes sense again.> --Randy-- Jani Huhtanen Tampere University of Technology, Pori
Andor wrote:> Jani Huhtanen wrote: > > ... > > http://ieeexplore.ieee.org/xpls/abs_all.jsp?tp=&arnumber=1205815&isnumber=27140 > > > > > > > Heh, funny. They seem to refer to coefficients represented with floating > > point numbers as "infinite-precision". From the paper: > > "The infinite-precision filter, h(n), is generated by the > > raised cosine FIR filter design program provided by the > > MATLAB ?firrcos? function.". > > > > As far as I know, Matlab isn't really that good ;) > > > > @Andor: > > Pseudo floating-point is their representation for quantized numbers. They > > encode a value in two parts: shift (exponent) and span (mantissa). > > Now all the need is a sign bit, and they can drop the pseudo prefix. > Guess I gave them too much credit in my first post. Sad.My first questoin is: are they refering to infinite precision of the DATA or infinite precision of the COEFFICIENTS of the filter? I thought that the correct application of dither gives you infinite precision of the DATA, at least thats what we have been telling the audio guys....:-) It appears the paper is refering to infinte precision of the coefficients? Correct? Mark
Mark wrote:> > Andor wrote: >> Jani Huhtanen wrote: >> >> ... >> >http://ieeexplore.ieee.org/xpls/abs_all.jsp?tp=&arnumber=1205815&isnumber=27140>> > > >> > >> > Heh, funny. They seem to refer to coefficients represented with >> > floating point numbers as "infinite-precision". From the paper: >> > "The infinite-precision filter, h(n), is generated by the >> > raised cosine FIR filter design program provided by the >> > MATLAB ?firrcos? function.". >> > >> > As far as I know, Matlab isn't really that good ;) >> > >> > @Andor: >> > Pseudo floating-point is their representation for quantized numbers. >> > They encode a value in two parts: shift (exponent) and span (mantissa). >> >> Now all the need is a sign bit, and they can drop the pseudo prefix. >> Guess I gave them too much credit in my first post. Sad. > > > My first questoin is: > > are they refering to infinite precision of the DATA or infinite > precision of the COEFFICIENTS of the filter? > > I thought that the correct application of dither gives you infinite > precision of the DATA, at least thats what we have been telling the > audio guys....:-)Could you elaborate this a bit? As I see it, quantized data cannot ever be infinite precision (in practice), however, transforms on quantized data may in some cases be infinite-precision.> > It appears the paper is refering to infinte precision of the > coefficients? Correct? > > MarkCorrect. -- Jani Huhtanen Tampere University of Technology, Pori
