I am now working on TI Dm642 evm and studying DDK. I have some problems with the video port driver. in mdBindDev, it calls mdControlChan, as follows, =================== static Int mdBindDev(Ptr *devp, Int devid, Ptr devParams) { Int portNum = devid; volatile Int i; volatile Int* base = (volatile Int *)portObjs[portNum].base; assert(portNum < _VP_PORT_CNT); base[_VP_VPCTL_OFFSET] = VP_VPCTL_VPRST_RESET << _VP_VPCTL_VPRST_SHIFT; for(i = 0; i < 100000; i ++); *devp = &portObjs[portNum]; return mdControlChan(&portObjs[portNum], VPORT_CMD_CONFIG_PORT, devParams); } ======================= but why in mdControlChan, we can typecast the (pointer to PortObj) to (pointer to _VPORT_ChanObj)? static Int mdControlChan(Ptr chanp, Uns cmd, Ptr args) { Int retVal = IOM_EBADMODE; _VPORT_ChanObj* chan = (_VPORT_ChanObj* )chanp; PortObj* port = &portObjs[chan->portNum]; .... ========================== Can anyone help me? I am really appreciate your help.
newcomer to TI DDK
Started by ●June 19, 2006
Reply by ●June 19, 20062006-06-19
hmq wrote:> > in mdBindDev, it calls mdControlChan, as follows,...> but why in mdControlChan, we can typecast the (pointer to PortObj) to > (pointer to _VPORT_ChanObj)?... Notice that in mdBindDev, the call to mdControlChan has VPORT_CMD_CONFIG_PORT as the second parameter. Looking at mdControlChan, the switch statement contains: ... case VPORT_CMD_CONFIG_PORT: retVal = _configPort(chanp, args); break; ... Now, looking at _configPort, we see that: static Int _configPort(Ptr portp, Ptr args) { PortObj* port = (PortObj *)portp; .... So, calling mdControlChan with VPORT_CMD_CONFIG_PORT is a special case. In this case, chanp is a pointer to a port (PortObj *), in all other cases it's a pointer to a channel (_VFVPORT_ChanObj*). Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
