Simple RtDx Question Regarding C6711DSK
Started by Barry June 28, 2004
Hi all,
I have been using HPI to communicate between my PC application and my
c6711DSK. As you know, there are problems with the API functions, and
I have some reliability problems as a result. Because of this, I was
thinking of using rtdx in addition to hpi, using rtdx to send
commands and hpi to transfer data.
The first question. Can I use rtdx without CCS?
If yes, then how do I go about loading a *.out file to my DSP via
rtdx as you would when using hpi. Are there api functions for this?
Thanks for your help,
Barry.
bg_ie@yahoo.com (Barry) wrote in message news:<731cea69.0406280813.4e6da436@posting.google.com>...
> Hi all, > > I have been using HPI to communicate between my PC application and my > c6711DSK. As you know, there are problems with the API functions, and > I have some reliability problems as a result. Because of this, I was > thinking of using rtdx in addition to hpi, using rtdx to send > commands and hpi to transfer data. > > The first question. Can I use rtdx without CCS? > > If yes, then how do I go about loading a *.out file to my DSP via > rtdx as you would when using hpi. Are there api functions for this? > > Thanks for your help, > > Barry.
Barry
To quickly answer your questions.  No you cannot use RTDX without CCS,
unless TI has changed this recently...
At one point, I designed a fairly reliable and extensible HPI interface for
the DSK.  It used two locations in the C6711 parameter RAM for read/write
flags and external memory (that the C6711 processor needed to CACHE clean)
for transmit/receive buffers.  I directly used the TI HPI drivers for the
host side.  Unfortunately, the host PC needed to poll the communications
flags because there is no PC-side interrupt in the TI drivers.
Unfortunately, I cannot give you the source due to company restrictions.  We
did successfully mate this interface (both PC host and DSP) to provide many
demos and transfer MBytes of data.
Regards
Jeff
"Barry" <bg_ie@yahoo.com> wrote in message
news:731cea69.0407020745.43b8ed54@posting.google.com...
> ^ > bg_ie@yahoo.com (Barry) wrote in message
> > Hi all, > > > > I have been using HPI to communicate between my PC application and my > > c6711DSK. As you know, there are problems with the API functions, and > > I have some reliability problems as a result. Because of this, I was > > thinking of using rtdx in addition to hpi, using rtdx to send > > commands and hpi to transfer data. > > > > The first question. Can I use rtdx without CCS? > > > > If yes, then how do I go about loading a *.out file to my DSP via > > rtdx as you would when using hpi. Are there api functions for this? > > > > Thanks for your help, > > > > Barry.
