16-bit vs. 32-bit
Started by Christian Christmann June 22, 2006
Randy--
>> C->Compiler->.asm>Assembler->.obj(32 bit)->Compressor->.obj(some
portion
>> 16 bit) > >Bhooshaniyer, > >Is this true for "raw" assembly as well as linear assembly? I haven't >seen this "compression" mode for either in the v6.0.0 alpha >assembly language tools user's guide (SPRU186O). > >--Randy
I believe it applies to raw assembly as well as linear assembly along with C code. You may want to double check with "-mv6400+" on raw assembly, build, load and check the disassembly window for presense of _some_ 16 bit instructions in it. I did some playing around some time back and I remember that it was the case. For some reason, TI has not published some of these info publicly. Never the less check the following sections for some info: Please check section 7.1.5 of spru198i.pdf,section 3.9 of spru732b.pdf and section 2.2.2 of spru965a.pdf --Bhooshan
with
>C code. You may want to double check with "-mv6400+" on raw assembly, >build, load and check the disassembly window for presense of _some_ 16
bit
remember
>that it was the case. > >For some reason, TI has not published some of these info publicly. Never >the less check the following sections for some info:
>--Bhooshan
Thats a total of 5 "some"s in less than 10 sentences. No wonder native speakers think we are wierd! :-) --Bhooshan
bhooshaniyer wrote:
> Thats a total of 5 "some"s in less than 10 sentences. No wonder native > speakers think we are wierd! :-)
Is that last word supposed to be "weird", or "wired"? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry--
>bhooshaniyer wrote: > > ... > >> Thats a total of 5 "some"s in less than 10 sentences. No wonder native >> speakers think we are wierd! :-) > >Is that last word supposed to be "weird", or "wired"?
Point well made.:-) But pray, why should it not be wi_eerd? It sounds _more_ right with the emphasis of "ee" on the second syllable! Oh,well, what do I know! --Bhooshan
bhooshaniyer wrote:
> Jerry-- > >> bhooshaniyer wrote: >> >> ... >> >>> Thats a total of 5 "some"s in less than 10 sentences. No wonder native >>> speakers think we are wierd! :-) >> Is that last word supposed to be "weird", or "wired"? > > Point well made.:-) > > But pray, why should it not be wi_eerd? It sounds _more_ right with the > emphasis of "ee" on the second syllable! Oh,well, what do I know!
I don't know much about spelling rules (or phonics for that matter). A maxim of elementary-school teachers is "'I' before 'e' except after 'c', or when sounding like 'a', as in 'neighbor' and 'weigh'. I reiterate: their weird deities are unscientific. :-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> bhooshaniyer wrote: > > Jerry-- > > > >> bhooshaniyer wrote: > >> > >> ... > >> > >>> Thats a total of 5 "some"s in less than 10 sentences. No wonder native > >>> speakers think we are wierd! :-) > >> Is that last word supposed to be "weird", or "wired"? > > > > Point well made.:-) > > > > But pray, why should it not be wi_eerd? It sounds _more_ right with the > > emphasis of "ee" on the second syllable! Oh,well, what do I know! > > I don't know much about spelling rules (or phonics for that matter). A > maxim of elementary-school teachers is "'I' before 'e' except after 'c', > or when sounding like 'a', as in 'neighbor' and 'weigh'. > > I reiterate: their weird deities are unscientific. :-) > > Jerry > -- > Engineering is the art of making what you want from things you can get.
And even that's not sufficient. Ken
> =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
