Randy Yates wrote:> john wrote: > > [...] > > If the noise is complex, it will add vectorially (is that a word?) to > > the signal vector and move it off of +/- 180 degrees randomly, > > resulting in a noisy phase. There is no way I know of to obtain a > > noiseless phase estimate for a noisy phase. If the noise is purely real > > or imaginary, then maybe so. > > John, > > You caught my main error - that the noise is complex - but then (I > think) missed the wonderful conclusion: the noise doesn't matter. > > Starting with the equation > > E[z^2] = alpha^2 * e^{j * 2 *\phi} + E[n^2], > > let's examine E[n^2]: > > n^2 = (nx + j*ny) * (nx + j*ny) > = nx^2 - ny^2 + j * (nx * ny + ny * nx) > > and therefore > > E[n^2] = E[nx^2 - ny^2] + j * (E[nx * ny] + E[ny * nx]) > = E[nx^2] - E[ny^2] + j * (E[nx * ny] + E[ny * nx]) > = varx^2 - vary^2 + j * (E[nx * ny] + E[ny * nx]) > > If the complex noise is composed of two independent, > identically-distributed noise processes, then > > E[nx * ny] = E[nx]*E[ny] = 0 > > and varx^2 = vary^2, therefore > > E[n^2] = 0. > > --RandyThis proves that the estimator is unbiased. As you average more and more data, the noise contribution to the estimate tends to zero. John
Estimation of Carrier Phase Offset
Started by ●June 24, 2006
Reply by ●June 26, 20062006-06-26
john wrote:> [...] > This proves that the estimator is unbiased. As you average more and > more data, the noise contribution to the estimate tends to zero.True, and the previous estimator (assuming real noise) was not. That's kinda the point, although I omitted the academic label. --Randy
Randy Yates wrote:> john wrote: > > [...] > > This proves that the estimator is unbiased. As you average more and > > more data, the noise contribution to the estimate tends to zero. > > True, and the previous estimator (assuming real noise) was not. That's > kinda the point, although I omitted the academic label. > > --RandyI'm not sure what you mean by "noise doesn't matter". In a practical system the estimator will have a non-infinite signal to noise ratio, depending on the averaging time, noise power, and signal power. Those details typically do matter. John
john wrote:> Randy Yates wrote: > > john wrote: > > > [...] > > > This proves that the estimator is unbiased. As you average more and > > > more data, the noise contribution to the estimate tends to zero. > > > > True, and the previous estimator (assuming real noise) was not. That's > > kinda the point, although I omitted the academic label. > > > > --Randy > > I'm not sure what you mean by "noise doesn't matter".Hi John, What I mean is that, analytically, the noise doesn't matter. The more erudite way to put it is "the estimate is unbiased." Or more verbosely, (but equivalently) the difference between the actual phase and the expected value (expected value in the analytic sense, not in a practical, averaging sort of sense) of the phase estimate is zero.> In a practical system the estimator will have a non-infinite signal > to noise ratio, depending on the averaging time, noise power, and > signal power. Those details typically do matter.A final approach must work both in theory and practice. However, until you can get from here to there in the analytical, theoretical world, then practical considerations are irrelevent. --Randy
Reply by ●June 27, 20062006-06-27
>>>>> "Randy" == Randy Yates <yates@ieee.org> writes:Randy> john wrote: >> [...] >> If the noise is complex, it will add vectorially (is that a word?) to >> the signal vector and move it off of +/- 180 degrees randomly, >> resulting in a noisy phase. There is no way I know of to obtain a >> noiseless phase estimate for a noisy phase. If the noise is purely real >> or imaginary, then maybe so. Randy> John, Randy> You caught my main error - that the noise is complex - but then (I Randy> think) missed the wonderful conclusion: the noise doesn't matter. Randy> Starting with the equation Randy> E[z^2] = alpha^2 * e^{j * 2 *\phi} + E[n^2], Randy> let's examine E[n^2]: Randy> n^2 = (nx + j*ny) * (nx + j*ny) Randy> = nx^2 - ny^2 + j * (nx * ny + ny * nx) If n is complex, don't you really want E[|n|^2] instead of E[n^2]? Ray
Raymond Toy wrote:> >>>>> "Randy" == Randy Yates <yates@ieee.org> writes: > > Randy> john wrote: > >> [...] > >> If the noise is complex, it will add vectorially (is that a word?) to > >> the signal vector and move it off of +/- 180 degrees randomly, > >> resulting in a noisy phase. There is no way I know of to obtain a > >> noiseless phase estimate for a noisy phase. If the noise is purely real > >> or imaginary, then maybe so. > > Randy> John, > > Randy> You caught my main error - that the noise is complex - but then (I > Randy> think) missed the wonderful conclusion: the noise doesn't matter. > > Randy> Starting with the equation > > Randy> E[z^2] = alpha^2 * e^{j * 2 *\phi} + E[n^2], > > Randy> let's examine E[n^2]: > > Randy> n^2 = (nx + j*ny) * (nx + j*ny) > Randy> = nx^2 - ny^2 + j * (nx * ny + ny * nx) > > If n is complex, don't you really want E[|n|^2] instead of E[n^2]?Hi Ray, I don't think so. If, instead of straight-forward squaring, we multiply by the complex conjugate so that the noise term becomes |n|^2, then the term with the phase information cancels as well (e^{j*\phi} * e^{j*-\phi} = 1). --Randy
Reply by ●June 28, 20062006-06-28
>>>>> "Randy" == Randy Yates <yates@ieee.org> writes:Randy> Raymond Toy wrote: [snip] >> If n is complex, don't you really want E[|n|^2] instead of E[n^2]? Randy> Hi Ray, Randy> I don't think so. If, instead of straight-forward squaring, we multiply Randy> by the complex conjugate so that the noise term becomes |n|^2, then Randy> the term with the phase information cancels as well Randy> (e^{j*\phi} * e^{j*-\phi} = 1). Right. I was thinking of the wrong thing. Ray
