Hai! every one. This question is basic for DSP experts.I try to design digital butter worth filter(lowpass) in C.First I converted given digital specs to analog specs.after that i caluculated prewarped analog specs.I found order, cutoff frequency of analog butterworth filter.After that I used butterworth filter tables to find normalized denominator coefficients of analog filter.Now i tried to convert these analog filter coefficients to digital filter coefficients, using bilinear transfermation.I know that we need to replace 's' with 2/T*(z-1)/(z+1) to get equivalent digital filter. Here I have two problems. i>It's difficult to write C code, to get polynomial coefficients in z domain.So instead of like this,is there any other way of getting digital filter coefficients?(using poles....etc) ii>In analog filters, I used butterworth filter tables, instead of that can we caluculate directly protype denominator coefficients(cutoff frequency=1)? I don't have depth knowledge of DSP concepts.If any body knows answers to my questions, please let me know. Thank you. vyshali
Started by ●June 24, 2006
Reply by ●June 24, 20062006-06-24
vyshali wrote:> Hai! every one. > This question is basic for DSP experts.I try to design digital butter > worth filter(lowpass) in C.First I converted given digital specs to analog > specs.after that i caluculated prewarped analog specs.I found order, cutoff > frequency of analog butterworth filter.After that I used butterworth filter > tables to find normalized denominator coefficients of analog filter.Now i > tried to convert these analog filter coefficients to digital filter > coefficients, using bilinear transfermation.I know that we need to replace > 's' with 2/T*(z-1)/(z+1) to get equivalent digital filter. > Here I have two problems. > i>It's difficult to write C code, to get polynomial coefficients in z > domain.So instead of like this,is there any other way of getting digital > filter coefficients?(using poles....etc)Divide the filter into a casrcade of biquads, and transforme each biquad analytically.> ii>In analog filters, I used butterworth filter tables, instead of that > can we caluculate directly protype denominator coefficients(cutoff > frequency=1)?Yes. There is the book by Antoniou that takes you through all the steps.> I don't have depth knowledge of DSP concepts.If any body knows answers to > my questions, please let me know.You have done a lot already. Find the book by Antoniou and you'll reach your goal. Rune
