Hi everyone, I am looking for a trick to output 6 (binary) signals simultaneously from the C6711 DSK board to feed a RF circuit. To retrieve these signals from the board I would like to avoid any external module (daughter card or home made circuits) because we have a limited budget for a small demo. I know c6x Dsp's have GPIO registers that might be very useful but I don't how to make a connection between these registers and any external pins on the board. Does anyone know a simple workaround? I'll appreciate any help or suggestion. LB
Help needed with TI C6711 DSK
Started by ●June 25, 2004
Reply by ●June 25, 20042004-06-25
You can use three signal lines which are used to control leds (address 0x90080000) , but it's still not enough and there is no external header. Look at the schematics propably at the same addess You can control three other output signals. Sorry for my english. Grzegorz G. U�ytkownik "L. Bawr" <lba@step.polymtl.ca> napisa� w wiadomo�ci news:cbhobl$d95$1@zcars0v6.ca.nortel.com...> Hi everyone, > > I am looking for a trick to output 6 (binary) signals simultaneously from > the C6711 DSK board to feed a RF circuit. > To retrieve these signals from the board I would like to avoid anyexternal> module (daughter card or home made circuits) because we have a limited > budget for a small demo. > I know c6x Dsp's have GPIO registers that might be very useful but I don't > how to make a connection between these registers and any external pins on > the board. Does anyone know a simple workaround? > I'll appreciate any help or suggestion. > > LB > >
I've just looked at the schematic and I've seen at address where LED are three other unused test points , so You can use them with LED pins to control 6 output signals. Grzegorz G. U�ytkownik "L. Bawr" <lba@step.polymtl.ca> napisa� w wiadomo�ci news:cbhobl$d95$1@zcars0v6.ca.nortel.com...> Hi everyone, > > I am looking for a trick to output 6 (binary) signals simultaneously from > the C6711 DSK board to feed a RF circuit. > To retrieve these signals from the board I would like to avoid anyexternal> module (daughter card or home made circuits) because we have a limited > budget for a small demo. > I know c6x Dsp's have GPIO registers that might be very useful but I don't > how to make a connection between these registers and any external pins on > the board. Does anyone know a simple workaround? > I'll appreciate any help or suggestion. > > LB > >
L. Bawr wrote:> Hi everyone, > > I am looking for a trick to output 6 (binary) signals simultaneously from > the C6711 DSK board to feed a RF circuit. > To retrieve these signals from the board I would like to avoid any external > module (daughter card or home made circuits) because we have a limited > budget for a small demo. > I know c6x Dsp's have GPIO registers that might be very useful but I don't > how to make a connection between these registers and any external pins on > the board. Does anyone know a simple workaround? > I'll appreciate any help or suggestion. > > LB > >You're lucky, my C6711 (starterkit) doesn't have GPIO onboard (only for C&D versions)
I'm not very familiar with the 6711 DSK (I've got a 6713 DSK), but I think this is how you would do it: 1) The GPIO module is muxed with the HPI. You need to configure the board such that at startup it enables the GPIO rather than the HPI. Most likely there is a jumper or a switch on the board that will allow you to do this. Check the DSK's documentation. 2) Download the GPIO guide and the 6711 data sheet off the TI web site. 3) Find the addresses of the GPIO registers in the 6711 data sheet. 4) Use the GPIO User Guide to program the fields properly (i.e. to configure the bits as outputs and write to them). 5) I imagine there is a HPI/GPIO header on the board. Again look at the DSK documentation to see which pin corresponds to the GPIO signals. Brad "L. Bawr" <lba@step.polymtl.ca> wrote in message news:cbhobl$d95$1@zcars0v6.ca.nortel.com...> Hi everyone, > > I am looking for a trick to output 6 (binary) signals simultaneously from > the C6711 DSK board to feed a RF circuit. > To retrieve these signals from the board I would like to avoid anyexternal> module (daughter card or home made circuits) because we have a limited > budget for a small demo. > I know c6x Dsp's have GPIO registers that might be very useful but I don't > how to make a connection between these registers and any external pins on > the board. Does anyone know a simple workaround? > I'll appreciate any help or suggestion. > > LB > >
Reply by ●June 30, 20042004-06-30
ThanX for your help all. It was very helpful. LB "L. Bawr" <lba@step.polymtl.ca> wrote in message news:cbhobl$d95$1@zcars0v6.ca.nortel.com...> Hi everyone, > > I am looking for a trick to output 6 (binary) signals simultaneously from > the C6711 DSK board to feed a RF circuit. > To retrieve these signals from the board I would like to avoid anyexternal> module (daughter card or home made circuits) because we have a limited > budget for a small demo. > I know c6x Dsp's have GPIO registers that might be very useful but I don't > how to make a connection between these registers and any external pins on > the board. Does anyone know a simple workaround? > I'll appreciate any help or suggestion. > > LB > >
Reply by ●January 4, 20052005-01-04
Hi It would be nice if anybody could give me a link for the C6711 DSK schematic or if somebody can send it to me asap. Thanks Nithin Grzegorz G. wrote:> I've just looked at the schematic and I've seen at address where LEDare> three other unused test points , so You can use them with LED pins to > control 6 output signals. > > Grzegorz G. > > > U=BFytkownik "L. Bawr" <lba@step.polymtl.ca> napisa=B3 w wiadomo=B6ci > news:cbhobl$d95$1@zcars0v6.ca.nortel.com... > > Hi everyone, > > > > I am looking for a trick to output 6 (binary) signalssimultaneously from> > the C6711 DSK board to feed a RF circuit. > > To retrieve these signals from the board I would like to avoid any > external > > module (daughter card or home made circuits) because we have alimited> > budget for a small demo. > > I know c6x Dsp's have GPIO registers that might be very useful butI don't> > how to make a connection between these registers and any externalpins on> > the board. Does anyone know a simple workaround? > > I'll appreciate any help or suggestion. > > > > LB > > > >
