Hi I have a custom 5502 board. I have been able to write code to it's SDRAM and execute form there. My problems (unexpectedly) are coming from flash. i can access it's flash when i burn my code in it and using flashburn i also compared the flash contents of my board versus the EVM5502 board and i found that they were the same. My GPIOs are always(before reset adn after reset i have hardwired them) in the following configuration GPIO[2..0]= 011 GPIO4,6,7 are all high So i am booting EMIF(parallel 16) from external clock and i am also going to use serial port 2 as Mcbsp only. The thing is even when i configure for BOOT mode from external 16 bit parallel EMIF i don't see my code running and the DSP does not draw any power like it does whne the same code i run in the internal memory from CCS. I wonder and i have no clue as to why a standalone program does not work even when the flash i can read and write to without any errors with flashburn. Is there anythign special that one has to be take care of when bringing up a board form external flash?? (I have the hold pin and teh rdy pin pulled high) Could the RESET for flash(that i have linked with the reste of the DSP, so that both DSP and FLASH come out of reset at the same time) be creating a problem does it have to be delayed or has to be faster than the DSP reset?? Another interesting thing about this problem. Once i have burnt code into the flash and i power cycle the board and try connecting with CCS I CAN NO LONGER connect to it. I get a error like Error Initialization OCS. RSET EMULATOR and all that. This error i understand comes when the XDS cannot reset the target board. To recover my board i have to change my jumper config GPIO[2...0] to 000 and the only can i connect and then i have to erase the flash and then only can i see my board doing everything else that it can do. Can someone suggest something? If there might be some things i must check to make sure the things are as what XDS expects when it is connected to a board on whcih the flash is running..... Thanks for reading. Rohit Does someone has any ideas on how this problem can be solved??? Rohit
EMIF(parallel 16) boot from flash on5502 giving problems
Started by ●June 28, 2006
