Downsampling after wavelet denoising
Started by gkn June 30, 2006
I am working on a time series which is sampled once every 10 minutes. I
found by inspection of the auto correlation function that the detail
coefficients indicates pure noise for more than 7 levels of wavelet (db10)
decomposition. So, I did 8 levels of wavelet decomposition and then set the
8 level detail coeff. to zero. I carried out the inverse transform, and now
I wonder how much I can downsample the series without loosing information?
Thanks
gkn wrote:
> I am working on a time series which is sampled once every 10 minutes. I > found by inspection of the auto correlation function that the detail > coefficients indicates pure noise for more than 7 levels of wavelet (db10) > decomposition. So, I did 8 levels of wavelet decomposition and then set the > 8 level detail coeff. to zero. I carried out the inverse transform, and now > I wonder how much I can downsample the series without loosing information? >
If I understand correctly, you've zeroed out the wavelet coefficients for basis functions having the shortest support. These represent (roughly) the frequency range from Pi/2 to Pi, so you could argue for downsampling by a factor of two. But the thing about wavelets is that the filters aren't perfect, so you're going to get some aliasing. To see how much, looking at the frequency response of the scaling filter for this particular wavelet. David L. Rick Hach Company Header address is bot bait! Humans may use the following address: davidDOTrickAThachDOTcomREMOVE
