Hi, I have a question about channel coding. As I know, coding is used for improving system performance. At the same time, coding will result in lower spectral efficiency, except TCM. For higher modulation, the coding gain is useful only when its performance is better than that of lower order modultion without coding. Except TCM, other coding schemes are general of bandwidth expansion type. Even for pragmatic TCM(I, Q with separate Viterbi coding. For example, 2/3 rate in IEEE 802.16), I find the high order modulation with 2/3 pragmatic Viterbi code is worse than that of low order modulation without coding in a high dispersive channel, even with deep interleaving. This kind of coding is used only in relatively mild channel? In a paper(IEEE, trans. on communication, Vol.53, No.11, 2005, Optimized decision-feedback equalization for convolutional coding with reduced delay, Page 1859-1866), it gave an example on page 1865, Fig.8. It displayed an improved DFE with 8-PAM convolutional coding, whose coding rate is 1/3. The improvement is 1 or 2 dB. Although I did not do further simulation myself for that example, I suspect that the lower order modulation (for example, 4-PAM) will do much better than 8-PAM with 1/3 convolutional coding. Am I wrong? Please help me if you could. Thank you very much.
Question about coding for high order modulation
Started by ●July 3, 2006
Reply by ●July 4, 20062006-07-04
On 3 Jul 2006 19:07:50 -0700, "fl" <rxjwg98@gmail.com> wrote:>Hi, > >I have a question about channel coding. As I know, coding is used for >improving system performance. At the same time, coding will result in >lower spectral efficiency, except TCM.The presence of TCM doesn't have much to do with it, IMHO. Only the overall code rate and error performance is needed for this sort of analysis.> For higher modulation, the >coding gain is useful only when its performance is better than that of >lower order modultion without coding.Higher order modulation and higher rate coding provides improved spectral efficiency. This allows one to trade off SNR for throughput and reliability as the channel conditions change.> Except TCM, other coding schemes >are general of bandwidth expansion type. Even for pragmatic TCM(I, Q >with separate Viterbi coding. For example, 2/3 rate in IEEE 802.16), I >find the high order modulation with 2/3 pragmatic Viterbi code is worse >than that of low order modulation without coding in a high dispersive >channel, even with deep interleaving. This kind of coding is used only >in relatively mild channel?I'm not sure what you're saying, but if the spectral efficiencies are different than there is still likely a tradeoff to be made between the two schemes.>In a paper(IEEE, trans. on communication, Vol.53, No.11, 2005, >Optimized decision-feedback equalization for convolutional coding with >reduced delay, Page 1859-1866), it gave an example on page 1865, Fig.8. >It displayed an improved DFE with 8-PAM convolutional coding, whose >coding rate is 1/3. The improvement is 1 or 2 dB. Although I did not do >further simulation myself for that example, I suspect that the lower >order modulation (for example, 4-PAM) will do much better than 8-PAM >with 1/3 convolutional coding. Am I wrong? Please help me if you could.An easy way to see the tradeoffs is to plot throughput (or net spectral efficiency) vs SNR for each scheme together on the same plot. The outside trace of the overlapping curves is often called the "hull curve" of the ensemble of modulations and coding scheme (MCS) sets. Throughput increases with increasing SNR as one selects overlapping higher order modulations and code rates to continue up the curve. Any scheme that doesn't touch or contribute to the hull curve (i.e., lies completely inside it) isn't useful as the sets that do touch the curve provide better performance. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
