Hi, I am attempting phase correlation between two sets of images: both are the same size, and are powers of two. The first contains an image in the top left hand corner; the rest of the image is black. The second contains the same image, offset by some amount; the rest of the screen is either gray or black. Using the numerical recipes approach here is my correlation method: void correl(float data1[], float data2[], unsigned long n, float ans[]) { unsigned long no2, i; float dum, *fft; fft=vector(1,n<<1); twofft(data1-1, data2-1, fft, ans-1, n); // fft data1 and data2 //data1, data2 and ans are zero indexed, so subtract one from the pointer // to the array header. no2=n>>1; for(i=1; i<=n+1; i+=2) { ans[i-1] = ((fft[i-1]*(dum=ans[i-1])) + (fft[i]*ans[i]))/no2; // Real part - ans[0], ans[2] etc. ans[i] = ((fft[i]*dum) - (fft[i-1]*ans[i]))/no2; // Imaginary part - ans[1], ans[3] etc. // Divide by the magnitude - this normalises the results: // see http://ise.stanford.edu/class/ee392j/projects/projects/liang_report.pdf double normalisation = sqrt(ans[i-1]*ans[i-1] + ans[i]*ans[i]); ans[i-1]/= normalisation; ans[i]/=normalisation; // So the FFT matrix to inverse FFT is "ans". } ans[1]=ans[n]; realft(ans-1,n,-1); free_vector(fft,1,n<<1); } One of the things I am not sure about, and would like to clarify, is the division by the modulus of the complex arrays (the "normalisation" variable above). I've read the various papers, including the stanford.edu one above, and the Phase Correlation page on Wikipedia, and this seems like the thing to do. But I'd just like a second opinion if possible. Also, the even indexed values of ans[] will be real. and the odd will be imaginary. Do I just use the real values? If so, this would give a solution set of size n/2 - which doesn't sound right! Best wishes Paul
Phase correlation
Started by ●July 6, 2006
Reply by ●July 6, 20062006-07-06
