Hi all, I have an integer PLL and DSP in my system, I want fine resolution (a fraction of the PLL step size). Is possible to just use the DSP to adjust the reference frequency instead of using a fractional-N PLL chip? Thanks Guang
Use DSP to implement fractional N PLL
Started by ●July 7, 2006
Reply by ●July 7, 20062006-07-07
ghlou wrote:> Hi all, > > I have an integer PLL and DSP in my system, I want fine resolution (a > fraction of the PLL step size). Is possible to just use the DSP to > adjust the reference frequency instead of using a fractional-N PLL chip?you can always have two simultaneous NCOs (Numerically Controlled Oscillator), one that is in the loop of a regular 1:1 PLL with your incoming signal and the other which is a "stub" controlled by the (fractionally scaled) control value of the PLL NCO.> ThanksFWIW, r b-j
Another way to "tweak" the frequency is to use a VCTCXO for a reference to your PLL and then control it with a DAC or a PWM. What do you mean by fine resolution? "ghlou" <rftengineering@rftechnology.com.au> wrote in message news:e8kt5v$4in$1@news-02.connect.com.au...> Hi all, > > I have an integer PLL and DSP in my system, I want fine resolution (a > fraction of the PLL step size). Is possible to just use the DSP to adjust > the reference frequency instead of using a fractional-N PLL chip? > > Thanks > Guang
