I am using TI's imaging libraries to do a 3x3 convolution. The documentation states the following "Cycles = 9 * cols/2 + 44 For cols = 256, cycles = 1196". I see a much higher cycle count (factor of 100 over) when I profile even the simplest use of this function on a DSK6416. Code : begin = clock (); IMG_conv_3x3 (in_data, out_data, cols, mask, shift); end = clock (); ------ (end-begin) = 100000. Overhead of calling clock() = 200 Any thoughts.... Thanks, Carl.
Convolution cycles
Started by ●July 7, 2006
Reply by ●July 7, 20062006-07-07
It had to do with the configuration.....>I am using TI's imaging libraries to do a 3x3 convolution. >The documentation states the following >"Cycles = 9 * cols/2 + 44 >For cols = 256, cycles = 1196". > >I see a much higher cycle count (factor of 100 over) when I profile even >the simplest use of this function on a DSK6416. > >Code : > begin = clock (); > IMG_conv_3x3 (in_data, out_data, cols, mask, shift); > end = clock (); >------ >(end-begin) = 100000. >Overhead of calling clock() = 200 > >Any thoughts.... > >Thanks, >Carl. > > > > > >
