Hello, I have the book of Dr Rulph Chassaing on DSK 6713, along with its CD containg all the codes and support files. Now i am following the instructions of the book to start implementing the starting examples including "sine8_LED"and "sine_buff".I have included all the files and libraries and followed the settings as mentioned in the book. How ever when i try to build my project it creates three object files "sine8_buff.obj,c6713dskinit.obj and Vectors_intr.obj" and then there are 4 errors symbol _DSK6713_AIC23_codecControlhandle is defined multiple times symbol _DSK6713_AIC23_codecdatahandle is defined multiple times these errors occur once referring to the obj files c6713dskinit.obj and sine8_buff and then referring to c6713dskinit.obj and dsk6713_aic23opencodec.obj. Since i am just a beginner in this field i have completely no idea what is happening. So if any one knows the solution kindly tell me.It will be a great help for me.
Problem in implementing examples on C6713 by Rulph Chassaing
Started by ●July 12, 2006
Reply by ●July 13, 20062006-07-13
hassanjaleel wrote:> Hello, I have the book of Dr Rulph Chassaing on DSK 6713, along with its CD > containg all the codes and support files. Now i am following the > instructions of the book to start implementing the starting examples > including "sine8_LED"and "sine_buff".I have included all the files and > libraries and followed the settings as mentioned in the book. How ever > when i try to build my project it creates three object files > "sine8_buff.obj,c6713dskinit.obj and Vectors_intr.obj" and then there are > 4 errors > > symbol _DSK6713_AIC23_codecControlhandle is defined multiple times > > symbol _DSK6713_AIC23_codecdatahandle is defined multiple times > > these errors occur once referring to the obj files c6713dskinit.obj and > sine8_buff and then referring to c6713dskinit.obj and > dsk6713_aic23opencodec.obj. > > Since i am just a beginner in this field i have completely no idea what is > happening. So if any one knows the solution kindly tell me.It will be a > great help for me.I can't promise to solve your problem instantly, but since I am sitting in front of Code Composer and a 6713 DSK right now and have Rulph Chassaing's software here also ... What source files _exactly_ do you have in your project? You should have _only_ c6713dskinit.c, sine8_buf.c, and Vectors_intr.asm, as per figure 1.10 in the book. Are you using Code Composer version 3.1.0? I am using Rulph Chassaing's software with it (as opposed to CCS version 2) for the first time and in order to get the sine8_buf project to compile I've made changes in the Build Options and to the locations of some support files. That said, I haven't seen and can't replicate exactly the error you describe. If no-one else solves your problem soon, email me a copy of cc_build_Debug.log, and I'll have a look at it. Donald
