Hi guys, When I graph individual audio samples what's the best way to zoom out ? I can think of several methods but I'm not sure which will work best. Say I am zoomed out to level 8, meaning for every eight samples I plot one of them, I can simply ignore seven of them, I can average them, I can use the maximum value, and so on. What do you think ? Thanks, Robert A.
Graphing Audio Samples
Started by ●July 14, 2006
Reply by ●July 14, 20062006-07-14
Robert A. wrote:> Hi guys, > > When I graph individual audio samples what's the best way to zoom out ? I > can think of several methods but I'm not sure which will work best. > > Say I am zoomed out to level 8, meaning for every eight samples I plot one > of them, I can simply ignore seven of them, I can average them, I can use > the maximum value, and so on. > > What do you think ? > > Thanks, > Robert A.Robert, If you mean that at zoom level 8 you only have one horizontal pixel coordinate to represent 8 samples, then what I would do is plot all 8 samples at that same horizontal coordinate but using (possibly) multiple vertical coordinates. Averaging them, max value, etc., loses information that you probably don't want to lose. --Randy
"Robert A." <invalid@invalid.org> wrote in message news:YzQtg.851$F_6.335@fe12.lga...> Hi guys, > > When I graph individual audio samples what's the best way to zoom out ? I > can think of several methods but I'm not sure which will work best. > > Say I am zoomed out to level 8, meaning for every eight samples I plot one > of them, I can simply ignore seven of them, I can average them, I can use > the maximum value, and so on. > > What do you think ? > > Thanks, > Robert A.draw a vertical line from the min to the max of the y values works. Also, if the previous x pixel's values don't fall within the current min-max range then you can extend the current range until they do connect. That way you get a continuous looking waveform. This is all pretty common practice in graphical instruments (scopes, FFT analyzers, etc). Bob
Randy Yates wrote:> Robert A. wrote: >> Hi guys, >> >> When I graph individual audio samples what's the best way to zoom out ? I >> can think of several methods but I'm not sure which will work best. >> >> Say I am zoomed out to level 8, meaning for every eight samples I plot one >> of them, I can simply ignore seven of them, I can average them, I can use >> the maximum value, and so on. >> >> What do you think ? >> >> Thanks, >> Robert A. > > Robert, > > If you mean that at zoom level 8 you only have one > horizontal pixel coordinate to represent 8 samples, then what > I would do is plot all 8 samples at that same > horizontal coordinate but using (possibly) multiple > vertical coordinates. Averaging them, max value, > etc., loses information that you probably don't want > to lose.Information is lost in any case: sequence, with the way you describe. Plotting both max and min can be useful but noise prone. I guess it depends both on the data and on what the user wants to see. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
I have two thoughts: 1) Use a vertical bar for each point indicating the min and max sample value. This way you will let the user know that your decimating and he will be able to see min/max values. [Probably most accurate representation] 2) Apply a FIR filter to the signal that will remove potential aliasing images when you decimate. Example: if your decimating by 8 then design a lowpass filter that has a stopband at 0.5*fs/8 where 0.5fs = Nyquest of original signal. Michael Kreeger
Jerry Avins wrote:> Randy Yates wrote: > > Robert A. wrote: > >> Hi guys, > >> > >> When I graph individual audio samples what's the best way to zoom out ? I > >> can think of several methods but I'm not sure which will work best. > >> > >> Say I am zoomed out to level 8, meaning for every eight samples I plot one > >> of them, I can simply ignore seven of them, I can average them, I can use > >> the maximum value, and so on. > >> > >> What do you think ? > >> > >> Thanks, > >> Robert A. > > > > Robert, > > > > If you mean that at zoom level 8 you only have one > > horizontal pixel coordinate to represent 8 samples, then what > > I would do is plot all 8 samples at that same > > horizontal coordinate but using (possibly) multiple > > vertical coordinates. Averaging them, max value, > > etc., loses information that you probably don't want > > to lose. > > Information is lost in any case: sequence, with the way you describe.Hi Jerry, What you say is true - there MUST be some loss of information. What I meant was that averaging and min/max lose information that doesn't HAVE to be lost. --Randy
You lose a lot with a digital CRO. Undersampled waveforms are a featureless block of pixels. If there are sufficient samples to the horizontal pixel, it might be worth considering the use of color or brightness as pseudo z-axis info. When a 1MHz (fast) sine wave is displayed on an analog CRO which has its horizontal scan rate set to (slow) 1 milliSecond/division, the resulting solid envelope displayed has increasing brightness towards the top and bottom of the envelope due to the increased "dwell time" of the electron beam. From this you can make inferences about the waveform's slope at different voltages, even though you cannot examine the waveform directly. I often find these secondary effects to be informative. You can detect the onset of distortion in a complex waveform without having to twiddle the sweep rate up & back again to look at the expanded waveform. If some suitable parameter could be derived from the waveform and mapped to the z1 brightness axis (and maybe z2 == color axis??), some of the analog CRO subtlety and "feel" could be recaptured. A first-glance suggestion might be to make the v-line brightness inversely proportional to the difference between adjacent sample Y values to fake the analog effect above. After that, one might add the brightness of several overlapping v-lines (grossly under-sampled cycles) at the one h-pixel position to simulate multiple overlapped trace passes. The traces should be augmented only in the overlap zone. Normal precautions like limiting z value ranges & divide by zero avoidance would apply. Suggestions invited. They might get included in next years Tektronix if we are smart enough. So in ten years time when I can afford a new one it will be nice to use. Meantime we can all still use the feature in our screen-plot graphics stuff. Jim A.
Robert A. wrote:> Hi guys, > > When I graph individual audio samples what's the best way to zoom out ? I > can think of several methods but I'm not sure which will work best. > > Say I am zoomed out to level 8, meaning for every eight samples I plot one > of them, I can simply ignore seven of them, I can average them, I can use > the maximum value, and so on. > > What do you think ?Can you display grayscale? If so, then 2d anti-alias. Plot a vertical strip, where the grayscale density of that strip represents the local density of points per vertical bin when you zoom out horizontally. The vertical strip itself will represent a gray mini-histogram of the compressed signal. If you are limited in the depth of the grayscale, you can also add dither, sort-of-halftoning the signal density. If you can't display grayscale, then you can filter or display statistics. Averaging the points is a poor low pass filter. Min & max are probably poorer statistics than +s and -s std.deviations from the mean, unless the peak deviations from the mean (or low pass downsample point) is particularly informative in some way. If you can display color, then you can do some combination of the above, grayscale for signal density, one color for the low pass filtered signal, anothers color for +-1,2,3 std.deviation or min-max envelope. Dropping samples without suitable low-pass filtering will just produce a view of an aliased signal. IMHO. YMMV. -- Ron N. http://www.nicholson.com/rhn
