Hi I have to work on a received signal (COFDM signal, with several thousands of subcarriers), after a AWGN channel. I would like to reduce noise. First, bandpass filtering is done. Then, I have to reduce the in-band noise. Do you know some methods to do it? (I know for instance that the optimal Wiener filter can do that, but I don't how to build it with only an access to the noisy signal). Thank you in advance.
In band noise
Started by ●July 24, 2006
Reply by ●July 24, 20062006-07-24
thom skrev:> Hi > > I have to work on a received signal (COFDM signal, with several thousands > of subcarriers), after a AWGN channel. I would like to reduce noise. > First, bandpass filtering is done. Then, I have to reduce the in-band > noise. Do you know some methods to do it? (I know for instance that the > optimal Wiener filter can do that, but I don't how to build it with only > an access to the noisy signal).Do you have any knowledge of what would have been recieved on a noise-free chanel (I think the technical term is "codebook" but I am not sure; communication is not my strongest subject)? If so, would this knowledge help when designing the Wiener filter? Rune
