Hi I am currently working on a project which involves determining the relationship between the the "bandwidth"(as my advisor puts it) and power consumption of an I/Q transmitter. The I/Q transmitter works as follows: In-Phase: Even bits of PN sequence ---> DAC ---> LPF --> multiply by cosine --> transmit Quad-Phase: Odd bits of PN sequence --> DAC --> LPF --> mult. by sine --> transmit The problem is that my advisor wants me to see how the power consumption changes as you change the bandwidth of the input data (the PN sequence). I have a power model and a power estimator worked out nicely for the transmitter itself. However, I dont know what he means by changing the bandwidth of the input data. Does it mean that I change the pattern of 1s and 0s or just increase/decrease the number of bits (resolution) of the PN sequence? Please help, I have come this far working hard on my simulator and I dont want to stop short just on something small I don't understand for the simulation itself. Thank You Mohammed Billoo
Digital bandwidth
Started by ●July 25, 2006
Reply by ●July 25, 20062006-07-25
billoo wrote:> Hi > > I am currently working on a project which involves determining the > relationship between the the "bandwidth"(as my advisor puts it) and > power consumption of an I/Q transmitter. The I/Q transmitter works as > follows: > > In-Phase: Even bits of PN sequence ---> DAC ---> LPF --> multiply by > cosine --> transmit > > Quad-Phase: Odd bits of PN sequence --> DAC --> LPF --> mult. by sine > --> transmit > > The problem is that my advisor wants me to see how the power > consumption changes as you change the bandwidth of the input data (the > PN sequence). I have a power model and a power estimator worked out > nicely for the transmitter itself. However, I dont know what he means > by changing the bandwidth of the input data. Does it mean that I change > the pattern of 1s and 0s or just increase/decrease the number of bits > (resolution) of the PN sequence? Please help, I have come this far > working hard on my simulator and I dont want to stop short just on > something small I don't understand for the simulation itself.I don't understand what you need. some people seem to feel that my asking questions is an attack, but my only other course is ignoring you. 1) Is there a reason you can't ask your adviser? 2) A DAC operation is usually performed on several bits at a time. If you are sending ones and zeros, what does the DAC operation consist of? 3) How is the PN sequence production related to the LPF bandwidth? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> billoo wrote: > > Hi > > > > I am currently working on a project which involves determining the > > relationship between the the "bandwidth"(as my advisor puts it) and > > power consumption of an I/Q transmitter. The I/Q transmitter works as > > follows: > > > > In-Phase: Even bits of PN sequence ---> DAC ---> LPF --> multiply by > > cosine --> transmit > > > > Quad-Phase: Odd bits of PN sequence --> DAC --> LPF --> mult. by sine > > --> transmit > > > > The problem is that my advisor wants me to see how the power > > consumption changes as you change the bandwidth of the input data (the > > PN sequence). I have a power model and a power estimator worked out > > nicely for the transmitter itself. However, I dont know what he means > > by changing the bandwidth of the input data. Does it mean that I change > > the pattern of 1s and 0s or just increase/decrease the number of bits > > (resolution) of the PN sequence? Please help, I have come this far > > working hard on my simulator and I dont want to stop short just on > > something small I don't understand for the simulation itself. > > I don't understand what you need. some people seem to feel that my > asking questions is an attack, but my only other course is ignoring you. > > 1) Is there a reason you can't ask your adviser? > > 2) A DAC operation is usually performed on several bits at a time. If > you are sending ones and zeros, what does the DAC operation consist of? > > 3) How is the PN sequence production related to the LPF bandwidth? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF 1) I have asked my pofessor and he is working on numerous projects and it takes him a while to reply to my emails and I saw that the groups generally respond quickly. 2) My project involves modelling the power consumption of the ZigBee CC2420 radio module. I modelled the DAC as an R-2R ladder which means that a 1 closes a circuit for a set of resistors to generate a particular output voltage and the 0 leaves the circuit open. 3) I am not concerned about the analag bandwidth but the digital bandwidth of the data stream going into the DAC. I want to graph the change in digital bandwidth from 0 to pi versus the power consumed by the analog component (since it is the most power hungry). So basically, I have the data stream of 1s and 0s coming out of the digital part of the circuit. I want to vary the bandwidth of the 1s and 0s and then see how the power consumed of the analog circuit changes. My question is what does the bandwidth of digital signal depend on (e.g. number of 1s and 0s, bit resolution)?=20 Thank You Mohammed Billoo
Mohammed, Jerry's questions are often more instructive than some answers. Some pupils of DSP object to being required to think. Students do it and then realize why mentor asked the question. If you are not a native English speaker [ or even if you are ] a study of the fine distinctions between "pupil" and "student" would be instructive. Jerry, ask away. The ignorant will be made wise and foolish will be offended. Editorial comment. *TOO many* "student bodies" are just a conglomeration of pupils. PS. I think Mohammed can be used as an example of "How to Ask a Question". billoo wrote:> Jerry Avins wrote: > >>billoo wrote: >> >>>Hi >>> >>>I am currently working on a project which involves determining the >>>relationship between the the "bandwidth"(as my advisor puts it) and >>>power consumption of an I/Q transmitter. The I/Q transmitter works as >>>follows: >>> >>>In-Phase: Even bits of PN sequence ---> DAC ---> LPF --> multiply by >>>cosine --> transmit >>> >>>Quad-Phase: Odd bits of PN sequence --> DAC --> LPF --> mult. by sine >>>--> transmit >>> >>>The problem is that my advisor wants me to see how the power >>>consumption changes as you change the bandwidth of the input data (the >>>PN sequence). I have a power model and a power estimator worked out >>>nicely for the transmitter itself. However, I dont know what he means >>>by changing the bandwidth of the input data. Does it mean that I change >>>the pattern of 1s and 0s or just increase/decrease the number of bits >>>(resolution) of the PN sequence? Please help, I have come this far >>>working hard on my simulator and I dont want to stop short just on >>>something small I don't understand for the simulation itself. >> >>I don't understand what you need. some people seem to feel that my >>asking questions is an attack, but my only other course is ignoring you. >> >>1) Is there a reason you can't ask your adviser? >> >>2) A DAC operation is usually performed on several bits at a time. If >>you are sending ones and zeros, what does the DAC operation consist of? >> >>3) How is the PN sequence production related to the LPF bandwidth? >> >>Jerry >>-- >>Engineering is the art of making what you want from things you can get. >>����������������������������������������������������������������������� > > > 1) I have asked my pofessor and he is working on numerous projects and > it takes him a while to reply to my emails and I saw that the groups > generally respond quickly. > > 2) My project involves modelling the power consumption of the ZigBee > CC2420 radio module. I modelled the DAC as an R-2R ladder which means > that a 1 closes a circuit for a set of resistors to generate a > particular output voltage and the 0 leaves the circuit open. > > 3) I am not concerned about the analag bandwidth but the digital > bandwidth of the data stream going into the DAC. I want to graph the > change in digital bandwidth from 0 to pi versus the power consumed by > the analog component (since it is the most power hungry). So basically, > I have the data stream of 1s and 0s coming out of the digital part of > the circuit. I want to vary the bandwidth of the 1s and 0s and then see > how the power consumed of the analog circuit changes. My question is > what does the bandwidth of digital signal depend on (e.g. number of 1s > and 0s, bit resolution)? > > Thank You > Mohammed Billoo >
billoo wrote:> Jerry Avins wrote: >> billoo wrote: >>> Hi >>> >>> I am currently working on a project which involves determining the >>> relationship between the the "bandwidth"(as my advisor puts it) and >>> power consumption of an I/Q transmitter. The I/Q transmitter works as >>> follows: >>> >>> In-Phase: Even bits of PN sequence ---> DAC ---> LPF --> multiply by >>> cosine --> transmit >>> >>> Quad-Phase: Odd bits of PN sequence --> DAC --> LPF --> mult. by sine >>> --> transmit >>> >>> The problem is that my advisor wants me to see how the power >>> consumption changes as you change the bandwidth of the input data (the >>> PN sequence). I have a power model and a power estimator worked out >>> nicely for the transmitter itself. However, I dont know what he means >>> by changing the bandwidth of the input data. Does it mean that I change >>> the pattern of 1s and 0s or just increase/decrease the number of bits >>> (resolution) of the PN sequence? Please help, I have come this far >>> working hard on my simulator and I dont want to stop short just on >>> something small I don't understand for the simulation itself. >> I don't understand what you need. some people seem to feel that my >> asking questions is an attack, but my only other course is ignoring you. >> >> 1) Is there a reason you can't ask your adviser? >> >> 2) A DAC operation is usually performed on several bits at a time. If >> you are sending ones and zeros, what does the DAC operation consist of? >> >> 3) How is the PN sequence production related to the LPF bandwidth? >> >> Jerry >> -- >> Engineering is the art of making what you want from things you can get. >> ����������������������������������������������������������������������� > > 1) I have asked my pofessor and he is working on numerous projects and > it takes him a while to reply to my emails and I saw that the groups > generally respond quickly. > > 2) My project involves modelling the power consumption of the ZigBee > CC2420 radio module. I modelled the DAC as an R-2R ladder which means > that a 1 closes a circuit for a set of resistors to generate a > particular output voltage and the 0 leaves the circuit open.Unless there is something decidedly peculiar about the transmitter module, it's power consumption is independent of the modulating waveform if it is FM or PM, and proportional to the duty cycle if it is AM. The duty cycle is not a function of bandwidth. PN sequences make good streams of random bits, but groups of N successive bits make poor random numbers, I suggest that you get your pseudo-random numbers some other way, say with a well designed linear congruential generator.> 3) I am not concerned about the analag bandwidth but the digital > bandwidth of the data stream going into the DAC. I want to graph the > change in digital bandwidth from 0 to pi versus the power consumed by > the analog component (since it is the most power hungry). So basically, > I have the data stream of 1s and 0s coming out of the digital part of > the circuit. I want to vary the bandwidth of the 1s and 0s and then see > how the power consumed of the analog circuit changes. My question is > what does the bandwidth of digital signal depend on (e.g. number of 1s > and 0s, bit resolution)?The bandwidth of a stream of random numbers is 1/2 the number-generation rate. Higher frequencies that you might imagine are present are aliased into that range or removed by the reconstruction filter that follows the DAC. (That's what the LPF is for. Properly designed, it passes no significant amount of any frequency higher than half the sample rate.) 4) Are you sure you understood what your professor asked you to do? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Richard Owlett wrote: ...> PS. I think Mohammed can be used as an example of "How to Ask a Question".I agree. Far too many posts here are examples of "How *Not* to Ask a Question". Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
billoo wrote:>My question is > what does the bandwidth of digital signal depend on (e.g. number of 1s > and 0s, bit resolution)?I think think the short answer is the bandwidth will be proportional to the number of 1's and 0's per unit time. -jim ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply by ●July 26, 20062006-07-26
Thank you people for your suggestions and answers, I really do appreciate the help. I think I have a sense of what I am actually doing now that I played around with it a bit in Matlab. The question that I was asking was I feel complete nonsense. I generated simple pulse trains of different combinations of 1s and 0s and just doing an FFT of them. There were very little differences in the frequency response (if any) of the different bit patterns (I tried extremes such as all 0s and only a single 1 vs. consecutively varying 1s and 0s). I realized maybe there would be a change in the frequency response if I modulated the PN sequence onto the carrier. I saw that there were significant differences in the frequency response as I tried different sequences. If I am still wrong in my reasoning or somebody has another perspective on the problem, please feel free! Another thing that I would like to clarify is that I am trying to model the power consumption of the individual blocks given in the transmitter part of the CC2420. Thank You Mohammed Billoo
Reply by ●July 30, 20062006-07-30
billoo wrote:> I am currently working on a project which involves determining the > relationship between the the "bandwidth"(as my advisor puts it) and > power consumption of an I/Q transmitter.This might not be related to your question, but I have always found the term "bandwidth" strange in describing digital signals. (Specifically, data that is not the result of digitizing an analog source.) It is often used to described as bits/second, even on a parallel bus. If one considers a modulated carrier being used to carry data, more bandwidth is required at a higher modulation frequency, which really is bandwidth, assuming that the modulation method is constant. Quoting bandwidth in bits per second, though, still seems wrong. Even more, a bandwidth in megabits/second is often written as Megahertz, even though the modulation method might not be one to one. (Or even one to two including both upper and lower sidebands.) (One description from some years ago included the bandwidth of a car full of computer tapes. That can be described in bits per second or bits/time/distance when it is moving, but there is no modulation, so a bandwidth seems wrong.) -- glen
glen herrmannsfeldt wrote:> billoo wrote: > > > > I am currently working on a project which involves determining the > > relationship between the the "bandwidth"(as my advisor puts it) and > > power consumption of an I/Q transmitter. > > This might not be related to your question, but I have always > found the term "bandwidth" strange in describing digital signals. > (Specifically, data that is not the result of digitizing an > analog source.) > > It is often used to described as bits/second, even on a parallel > bus. If one considers a modulated carrier being used to > carry data, more bandwidth is required at a higher modulation > frequency, which really is bandwidth, assuming that the > modulation method is constant. Quoting bandwidth in bits > per second, though, still seems wrong. Even more, a bandwidth > in megabits/second is often written as Megahertz, even though > the modulation method might not be one to one. (Or even one to > two including both upper and lower sidebands.) > > (One description from some years ago included the bandwidth > of a car full of computer tapes. That can be described > in bits per second or bits/time/distance when it is moving, > but there is no modulation, so a bandwidth seems wrong.) > > -- glenBandwidth is an often abused term, but that said, any time variant signal (i.e. not DC) has a bandwidth. There are numerous distinct uses of the term (although they are, of course, related ;) The raw (burst) bandwidth of some channel such as a memory bus or indeed any information channel, although then we can look at throughput, which is the effective bandwidth of the channel. This is closely tied to the available bandwidth of the medium (be it FR4, coax, free space or any other physical medium) which can limit the bandwidth of the signal being applied, with the attendant distortion of the signal. Another usage is that of the actual or required bandwidth of a signal and finds a lot of use in EMI/EMC discussions, antenna / filter design and the like. Being such a catch-all, it's important to get the context of the discussion. In this case, the OP is being asked the relationship of transmitter power to bandwidth, which really comes to a power density issue, and each modulation type has it's own envelope vs. bandwidth, which are always proportional (although the constant of proportionality varies widely for different techniques, of course). There's a huge amount to 'bandwidth', but as others have noted, the OP in this case at least asked the question the 'right way'. Cheers PeteS
