I'm trying to implement something called the "Cascade Algorithm" which is based upon the Dilation Equation, used when needed to approximate a Wavelet Scaling function or mother function. Everything is well apart from a small snag, I've been studying for a while now and still have no idea how to implement it?!! it goes something like this; f(t) = c(0)f(2t) + c(1)f(2t - 1) + c(2)f(2t - 2) + c(3)f(2t - 3) where c(0) = 0.6830127 c(1) = 1.1830127 c(2) = 0.3169873 c(3) = -0.1830127 (daubechie co-efficents, 4-tap) I've tried many times on google for something that can explain this to me, without glossing over the initial stages of "how to prime" the algorithm, but with little luck. I think the recursion is confusing me a tad, it seems to say that to produce a low scale rendering of a wavelet, you need to know what the high scale version looks like first, which is odd considering what I've already researched seems to suggest that the low scale rendering is the start point for the high scale rendering!?!?! Could somebody explain it to me please, in a "cascade algorithm for dummies" type way? I'd be very greatful (once again!)
The Cascade Algorithm - Recursion, Wavelets
Started by ●July 25, 2006
Reply by ●July 25, 20062006-07-25
moosedude wrote:> > I'm trying to implement something called the "Cascade Algorithm" which is > based upon the Dilation Equation, used when needed to approximate a > Wavelet Scaling function or mother function. > > Everything is well apart from a small snag, I've been studying for a while > now and still have no idea how to implement it?!! > > it goes something like this; > > f(t) = c(0)f(2t) + c(1)f(2t - 1) + c(2)f(2t - 2) + c(3)f(2t - 3) > > where > c(0) = 0.6830127 > c(1) = 1.1830127 > c(2) = 0.3169873 > c(3) = -0.1830127 (daubechie co-efficents, 4-tap) >This functions is the dilation equation. IIRC, cascade algorithm employs similar filter structure as the fast wavelet transform. However, one runs the algorithm sort of backwards. Feed a unit impulse as the lowpass band (i.e., the approximation part) and zeros for other bands and run the reconstruction to N levels. When the N approaches infinity the discrete approximation should approach the actual scaling function.> I've tried many times on google for something that can explain this to me, > without glossing over the initial stages of "how to prime" the algorithm, > but with little luck. I think the recursion is confusing me a tad, it > seems to say that to produce a low scale rendering of a wavelet, you need > to know what the high scale version looks like first, which is odd > considering what I've already researched seems to suggest that the low > scale rendering is the start point for the high scale rendering!?!?! > > > Could somebody explain it to me please, in a "cascade algorithm for > dummies" type way? I'd be very greatful (once again!)You are familiar with the filter bank implementation? If not the above explanation might not make any sense. -- Jani Huhtanen Tampere University of Technology, Pori
Reply by ●July 28, 20062006-07-28
>moosedude wrote: > >> >> I'm trying to implement something called the "Cascade Algorithm" whichis>> based upon the Dilation Equation, used when needed to approximate a >> Wavelet Scaling function or mother function. >> >> Everything is well apart from a small snag, I've been studying for awhile>> now and still have no idea how to implement it?!! >> >> it goes something like this; >> >> f(t) = c(0)f(2t) + c(1)f(2t - 1) + c(2)f(2t - 2) + c(3)f(2t - 3) >> >> where >> c(0) = 0.6830127 >> c(1) = 1.1830127 >> c(2) = 0.3169873 >> c(3) = -0.1830127 (daubechie co-efficents, 4-tap) >> > >This functions is the dilation equation. IIRC, cascade algorithm employs >similar filter structure as the fast wavelet transform. However, oneruns>the algorithm sort of backwards. Feed a unit impulse as the lowpass band >(i.e., the approximation part) and zeros for other bands and run the >reconstruction to N levels. When the N approaches infinity the discrete >approximation should approach the actual scaling function. > >> I've tried many times on google for something that can explain this tome,>> without glossing over the initial stages of "how to prime" thealgorithm,>> but with little luck. I think the recursion is confusing me a tad, it >> seems to say that to produce a low scale rendering of a wavelet, youneed>> to know what the high scale version looks like first, which is odd >> considering what I've already researched seems to suggest that the low >> scale rendering is the start point for the high scale rendering!?!?! >> >> >> Could somebody explain it to me please, in a "cascade algorithm for >> dummies" type way? I'd be very greatful (once again!) > >You are familiar with the filter bank implementation? If not the above >explanation might not make any sense. > >-- >Jani Huhtanen >Tampere University of Technology, Pori >Thanks Jani for your reply, I am familiar with filter banks, but my interpretation of a filter bank is that the decomposition for a filter bank occurs with low & high pass filters, the further down the chain you go, the more refined the information on the original input, for each chain downsampling of 2 takes place until you can divide no further. Presumably a simular division takes place for each cascade of the algorithm? for a finer resolution you double your number of data points from the previous scale. But I don't understand how the (2t - n) bit could obtain the right values for refinement from the previous coarse scale? Unless the algorithm assumes you start with a fine resolution scale and starts the processes to get to the coarse resolution?!?!?!? I've done a bit more reading and have come across this java applet; http://cm.bell-labs.com/who/wim/cascade/ which implies that the starting input is a triangle structure, i.e. t0 = 0.0, t1 = 0.0, t2 = 1.0, t3 = 0.0 I've been tinkering with some C++ code with this as input but aren't getting the output I would expect at certain iterations. Is there any worked examples for a daub4 cascade at iteration 1, on the internet somewhere I can have a look at that would help me clarify a few points?
Reply by ●August 5, 20062006-08-05
moosedude wrote:>>moosedude wrote: >> >>> >>> I'm trying to implement something called the "Cascade Algorithm" which > is >>> based upon the Dilation Equation, used when needed to approximate a >>> Wavelet Scaling function or mother function. >>> >>> Everything is well apart from a small snag, I've been studying for a > while >>> now and still have no idea how to implement it?!! >>> >>> it goes something like this; >>> >>> f(t) = c(0)f(2t) + c(1)f(2t - 1) + c(2)f(2t - 2) + c(3)f(2t - 3) >>> >>> where >>> c(0) = 0.6830127 >>> c(1) = 1.1830127 >>> c(2) = 0.3169873 >>> c(3) = -0.1830127 (daubechie co-efficents, 4-tap) >>> >> >>This functions is the dilation equation. IIRC, cascade algorithm employs >>similar filter structure as the fast wavelet transform. However, one > runs >>the algorithm sort of backwards. Feed a unit impulse as the lowpass band >>(i.e., the approximation part) and zeros for other bands and run the >>reconstruction to N levels. When the N approaches infinity the discrete >>approximation should approach the actual scaling function. >> >>> I've tried many times on google for something that can explain this to > me, >>> without glossing over the initial stages of "how to prime" the > algorithm, >>> but with little luck. I think the recursion is confusing me a tad, it >>> seems to say that to produce a low scale rendering of a wavelet, you > need >>> to know what the high scale version looks like first, which is odd >>> considering what I've already researched seems to suggest that the low >>> scale rendering is the start point for the high scale rendering!?!?! >>> >>> >>> Could somebody explain it to me please, in a "cascade algorithm for >>> dummies" type way? I'd be very greatful (once again!) >> >>You are familiar with the filter bank implementation? If not the above >>explanation might not make any sense. >> >>-- >>Jani Huhtanen >>Tampere University of Technology, Pori >> > > > Thanks Jani for your reply, I am familiar with filter banks, but my > interpretation of a filter bank is that the decomposition for a filter > bank occurs with low & high pass filters, the further down the chain you > go, the more refined the information on the original input, for each chain > downsampling of 2 takes place until you can divide no further.In cascade algorithm you run the reconstruction band (not the decomposition band) and for scaling function you only run the lowpass branch of the dyadic tree. In order to retrieve the wavelet function, at the last branch, instead of filtering with the lowpass filter (i.e. scaling filter) you filter with the wavelet filter.> Is there any worked examples for a daub4 cascade at iteration 1, on the > internet somewhere I can have a look at that would help me clarify a few > points?Below is a simple matlab / octave function for cascade algorithm I did. I'm sure you can translate it to C++ easily ------------------------------------------------------ function [s,w] = cascade(n,cs,cw) s = cs; w = cw; x2(1:2:length(w)*2) = w; x2(2:2:end)=0; x(1:2:length(s)*2) = s; x(2:2:end)=0; for i = 1:n s = conv(x,cs); w = conv(x2,cs); x2(1:2:length(w)*2) = w; x2(2:2:end)=0; x(1:2:length(s)*2) = s; x(2:2:end)=0; end end ----------------------------------------------------------- If you have octave or matlab you can try it like this: %Filter coefficients for daub4 (h<->scaling, g<->wavelet) h = [1+sqrt(3) 3+sqrt(3) 3-sqrt(3) 1-sqrt(3)]/(4*sqrt(2)); g = [h(4) -h(3) h(2) -h(1)]; %Calculate 5 iterations of the cascade algorithm [s,w]=cascade(5,h,g); plot(s); %Plot scaling function plot(w); %Plot wavelet function NB. The code probably has some flaws, so be aware! -- Jani Huhtanen Tampere University of Technology, Pori
Reply by ●August 14, 20062006-08-14
>moosedude wrote: > >>>moosedude wrote: >>> >>>> >>>> I'm trying to implement something called the "Cascade Algorithm"which>> is >>>> based upon the Dilation Equation, used when needed to approximate a >>>> Wavelet Scaling function or mother function. >>>> >>>> Everything is well apart from a small snag, I've been studying for a >> while >>>> now and still have no idea how to implement it?!! >>>> >>>> it goes something like this; >>>> >>>> f(t) = c(0)f(2t) + c(1)f(2t - 1) + c(2)f(2t - 2) + c(3)f(2t - 3) >>>> >>>> where >>>> c(0) = 0.6830127 >>>> c(1) = 1.1830127 >>>> c(2) = 0.3169873 >>>> c(3) = -0.1830127 (daubechie co-efficents, 4-tap) >>>> >>> >>>This functions is the dilation equation. IIRC, cascade algorithmemploys>>>similar filter structure as the fast wavelet transform. However, one >> runs >>>the algorithm sort of backwards. Feed a unit impulse as the lowpassband>>>(i.e., the approximation part) and zeros for other bands and run the >>>reconstruction to N levels. When the N approaches infinity thediscrete>>>approximation should approach the actual scaling function. >>> >>>> I've tried many times on google for something that can explain thisto>> me, >>>> without glossing over the initial stages of "how to prime" the >> algorithm, >>>> but with little luck. I think the recursion is confusing me a tad,it>>>> seems to say that to produce a low scale rendering of a wavelet, you >> need >>>> to know what the high scale version looks like first, which is odd >>>> considering what I've already researched seems to suggest that thelow>>>> scale rendering is the start point for the high scale rendering!?!?! >>>> >>>> >>>> Could somebody explain it to me please, in a "cascade algorithm for >>>> dummies" type way? I'd be very greatful (once again!) >>> >>>You are familiar with the filter bank implementation? If not the above >>>explanation might not make any sense. >>> >>>-- >>>Jani Huhtanen >>>Tampere University of Technology, Pori >>> >> >> >> Thanks Jani for your reply, I am familiar with filter banks, but my >> interpretation of a filter bank is that the decomposition for a filter >> bank occurs with low & high pass filters, the further down the chainyou>> go, the more refined the information on the original input, for eachchain>> downsampling of 2 takes place until you can divide no further. > >In cascade algorithm you run the reconstruction band (not thedecomposition>band) and for scaling function you only run the lowpass branch of the >dyadic tree. In order to retrieve the wavelet function, at the lastbranch,>instead of filtering with the lowpass filter (i.e. scaling filter) you >filter with the wavelet filter. > >> Is there any worked examples for a daub4 cascade at iteration 1, onthe>> internet somewhere I can have a look at that would help me clarify afew>> points? > >Below is a simple matlab / octave function for cascade algorithm I did.I'm>sure you can translate it to C++ easily >------------------------------------------------------ >function [s,w] = cascade(n,cs,cw) > > s = cs; > w = cw; > x2(1:2:length(w)*2) = w; > x2(2:2:end)=0; > x(1:2:length(s)*2) = s; > x(2:2:end)=0; > > for i = 1:n > > s = conv(x,cs); > w = conv(x2,cs); > > x2(1:2:length(w)*2) = w; > x2(2:2:end)=0; > x(1:2:length(s)*2) = s; > x(2:2:end)=0; > > end > >end >----------------------------------------------------------- > >If you have octave or matlab you can try it like this: > >%Filter coefficients for daub4 (h<->scaling, g<->wavelet) >h = [1+sqrt(3) 3+sqrt(3) 3-sqrt(3) 1-sqrt(3)]/(4*sqrt(2)); >g = [h(4) -h(3) h(2) -h(1)]; > >%Calculate 5 iterations of the cascade algorithm >[s,w]=cascade(5,h,g); > >plot(s); %Plot scaling function >plot(w); %Plot wavelet function > > >NB. The code probably has some flaws, so be aware! > >-- >Jani Huhtanen >Tampere University of Technology, Pori >Thanks Jani for that code, it worked in octave without any bugs in it!! Your help has been very much appreciated and I just wanted to say a quick thankyou.
