Take a normal analogue FM radio system (like the ones in a car). Now FM is defined as cos(Wct + k integral( f (t) dt ) ) and PM as cos(Wct + kf(t) ) Where f(t) is the signal. where k is a constant depending on the depth of modulation etc. Now it is known that broadcast 'FM' uses pre-emphasis at the transmitter (a 6dB/octave slope with break-frequencies of say 1kHz to 15kHz - not sure exactly on the frequencies here). A 6dB/Octave slope is differentiation over a certain frequency range (the pre-emphasis range). Surely this cancels out the integration in FM and it becomes PM. At the receiver a PLL or demodulator will ideally give d/dt [integral f(t) dt ] = f(t). ie rate of change of phase. However, at the receiver is a de-emphasis circuit which has a slope of -6dB/Octave which will cancel out the effect of the previous differentiation. Hence FM with pre and de-emphasis is surely PM over the necessary freq range and outside of this freq range it is true FM. F.
FM or PM?
Started by ●July 25, 2006
Reply by ●July 25, 20062006-07-25
sheepshaggerx@yahoo.co.uk wrote:> Take a normal analogue FM radio system (like the ones in a car). > > Now FM is defined as > > cos(Wct + k integral( f (t) dt ) ) > > and PM as > > cos(Wct + kf(t) ) > > Where f(t) is the signal. > > where k is a constant depending on the depth of modulation etc. > > Now it is known that broadcast 'FM' uses pre-emphasis at the > transmitter (a 6dB/octave slope with break-frequencies of say 1kHz to > 15kHz - not sure exactly on the frequencies here). > > A 6dB/Octave slope is differentiation over a certain frequency range > (the pre-emphasis range). > Surely this cancels out the integration in FM and it becomes PM. > > At the receiver a PLL or demodulator will ideally give d/dt [integral > f(t) dt ] = f(t). > ie rate of change of phase. > > However, at the receiver is a de-emphasis circuit which has a slope of > -6dB/Octave which will cancel out the effect of the previous > differentiation. Hence FM with pre and de-emphasis is surely PM over > the necessary freq range and outside of this freq range it is true FM.Go to the head of the class. Is there a question ? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
