Suppose that I have a finite-length discrete-time signal that is not necessarily sampled on a uniform time grid. I will characterize this signal as a series of time-amplitude pairs with time = t_sub_k and amplitude = a_sub_k, where k is an integer from 1 to N that selects a particular time-amplitude pair. It is easy to take the DFT of this sequence even though the time grid may not be uniform. FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) Now suppose that I transpose the role of amplitude and time; that is, I form a new time-amplitude series that is related to the old series by; a2_sub_k = t_sub_k t2_sub_k = a_sub_k Then I proceed to take the DFT of this new series, producing a new function FT2(w). Given FT(w), is there ANYTHING I can say about FT2(w) that is "general" in nature and not tied to a specific time-amplitude series? In particular, I am investigating series that are sampled on a log time grid, where t_sub_k = log(k). Obviously if we start with a_sub_k = t_sub_k (for example, a uniformly sampled ramp signal) then the two DFT results are the same. But I am wondering if there are some classes of non-uniform time grids in conjunction with particular amplitude values that cause FT(w) and FT2(w) to have some relationship in terms of mapping poles and zeroes from one domain into the other. Any thoughts welcome! Bob Adams
Strange Discrete Fourier Transform question
Started by ●July 30, 2006
Reply by ●July 30, 20062006-07-30
robert.w.adams@verizon.net skrev:> Suppose that I have a finite-length discrete-time signal that is not > necessarily sampled on a uniform time grid. I will characterize this > signal as a series of time-amplitude pairs with time = t_sub_k and > amplitude = a_sub_k, where k is an integer from 1 to N that selects a > particular time-amplitude pair. > > It is easy to take the DFT of this sequence even though the time grid > may not be uniform. > > FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > Now suppose that I transpose the role of amplitude and time; that is, I > form a new time-amplitude series that is related to the old series by; > > a2_sub_k = t_sub_k > t2_sub_k = a_sub_k > > Then I proceed to take the DFT of this new series, producing a new > function FT2(w). > > Given FT(w), is there ANYTHING I can say about FT2(w) that is "general" > in nature and not tied to a specific time-amplitude series?Interchanging the time and amplitude destroys any hope of saying anything useful about the time series. For an example, choose x[n] = sin(2*pi*k*n/N) for some N, n = 0,...,N-1 and k < N/2. Try to do this "trick" of yours, and deduce any useful information about the original time series. Rune
<robert.w.adams@verizon.net> wrote in message news:1154260055.670375.100450@h48g2000cwc.googlegroups.com...> Suppose that I have a finite-length discrete-time signal that is not > necessarily sampled on a uniform time grid. I will characterize this > signal as a series of time-amplitude pairs with time = t_sub_k and > amplitude = a_sub_k, where k is an integer from 1 to N that selects a > particular time-amplitude pair. > > It is easy to take the DFT of this sequence even though the time grid > may not be uniform. > > FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > Now suppose that I transpose the role of amplitude and time; that is, I > form a new time-amplitude series that is related to the old series by; > > a2_sub_k = t_sub_k > t2_sub_k = a_sub_k > > Then I proceed to take the DFT of this new series, producing a new > function FT2(w). > > Given FT(w), is there ANYTHING I can say about FT2(w) that is "general" > in nature and not tied to a specific time-amplitude series? > > In particular, I am investigating series that are sampled on a log time > grid, where t_sub_k = log(k). > > Obviously if we start with a_sub_k = t_sub_k (for example, a uniformly > sampled ramp signal) then the two DFT results are the same. But I am > wondering if there are some classes of non-uniform time grids in > conjunction with particular amplitude values that cause FT(w) and > FT2(w) to have some relationship in terms of mapping poles and zeroes > from one domain into the other.Bob, You said a DFT was easy as: FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) where the values of t_sub_k are apparently ordered but arbitrary. I note that "w" isn't in any way discrete - ???? So, I think this isn't a DFT as we know it. Start with a DFT definition with N the number of samples T the temporal epoch, fs the sampling frequency T/N = 1/fs the temporal sample interval 1/T = fs/N the frequency sample interval And the DFT is: F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*(kT/N)] ;n=0,N-1 If you want to have arbitrary values of "w" then you have a continuous Fourier Transform of a discrete sequence: F(w) = sum k=1 to N a_sub_k*exp(-j*w*kT/N) which almost looks like what you have above. It's not discrete in frequency. Just to be clear. I don't see how that's "easy" to do using arrays of numbers in a computer - which seems to be where you're heading with this. Then, if you want to make the sample times arbitrary then you would have what we started with: F(w) = sum k=1 to N a_sub_k*exp(-j*w*t_sub_k) It's still not discrete in frequency - which is what you need to get a finite sequence. So, it's common to assume that the temporal sequence is periodic on T and the sum generating the transform is finite: If this is done you get something like: F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!! The problem with this formulation is that the temporal resolution hasn't been defined on a regular grid and that's necessary for the Fourier Transform to be periodic instead of just infinite. If it's infinite then this formulation can't be inverse transformed because it's incomplete - not all the information is there. Another "problem" to ponder here is that the times aren't (i.e. need not be) ordered - although in a Fourier Transform they are ordered. That must have some bearing, eh? You might arbitrarily assign a time grid for the samples that sufficiently captures the sample times on that grid. You might use 100 times the narrowest separation between samples with the idea that the other separations won't be too far off if forced onto the grid. This results in maybe 1000*N sample points in time (?) and you put the sample amplitudes on the nearest grid point in time. Now you can compute a DFT that's suitable (because you decided on the parameters) - albeit a fairly long one. OK. Now to switching between time and amplitude as you suggested: Note that f(t) in the Fourier Transform is ordered in time. Note that the values of t are unique. Note that amplitudes of signals or data generally aren't unique. That suggests flipping them results in a situation that doesn't fit the formulation. One is a set of values and the other is an index or scale. Really very different things. Fred
Bob, you always bring such hard questions here. robert.w.adams@verizon.net wrote:> Suppose that I have a finite-length discrete-time signal that is not > necessarily sampled on a uniform time grid. I will characterize this > signal as a series of time-amplitude pairs with time = t_sub_k and > amplitude = a_sub_k, where k is an integer from 1 to N that selects a > particular time-amplitude pair. > > It is easy to take the DFT of this sequence even though the time grid > may not be uniform. > > FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > Now suppose that I transpose the role of amplitude and time; that is, I > form a new time-amplitude series that is related to the old series by; > > a2_sub_k = t_sub_k > t2_sub_k = a_sub_k >okay, but now there is no hope of the t2_sub_k being increasing with k. before i hwas thinking that t_sub_k was a strictly increasing sequence.> Then I proceed to take the DFT of this new series, producing a new > function FT2(w). > > Given FT(w), is there ANYTHING I can say about FT2(w) that is "general" > in nature and not tied to a specific time-amplitude series? > > In particular, I am investigating series that are sampled on a log time > grid, where t_sub_k = log(k). > > Obviously if we start with a_sub_k = t_sub_k (for example, a uniformly > sampled ramp signal) then the two DFT results are the same. But I am > wondering if there are some classes of non-uniform time grids in > conjunction with particular amplitude values that cause FT(w) and > FT2(w) to have some relationship in terms of mapping poles and zeroes > from one domain into the other.(pain)> Any thoughts welcome!errrrg.... i;m an engunir. i kin spel. r b-j i s'pose if it was an easy question, you would know the answer.
Reply by ●July 31, 20062006-07-31
Fred Marshall wrote:> <robert.w.adams@verizon.net> wrote in message > news:1154260055.670375.100450@h48g2000cwc.googlegroups.com... > > Suppose that I have a finite-length discrete-time signal that is not > > necessarily sampled on a uniform time grid. I will characterize this > > signal as a series of time-amplitude pairs with time = t_sub_k and > > amplitude = a_sub_k, where k is an integer from 1 to N that selects a > > particular time-amplitude pair. > > > > It is easy to take the DFT of this sequence even though the time grid > > may not be uniform. > > > > FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > > > Now suppose that I transpose the role of amplitude and time; that is, I > > form a new time-amplitude series that is related to the old series by; > > > > a2_sub_k = t_sub_k > > t2_sub_k = a_sub_k > > > > Then I proceed to take the DFT of this new series, producing a new > > function FT2(w). > > > > Given FT(w), is there ANYTHING I can say about FT2(w) that is "general" > > in nature and not tied to a specific time-amplitude series? > > > > In particular, I am investigating series that are sampled on a log time > > grid, where t_sub_k = log(k). > > > > Obviously if we start with a_sub_k = t_sub_k (for example, a uniformly > > sampled ramp signal) then the two DFT results are the same. But I am > > wondering if there are some classes of non-uniform time grids in > > conjunction with particular amplitude values that cause FT(w) and > > FT2(w) to have some relationship in terms of mapping poles and zeroes > > from one domain into the other. > > Bob, > > You said a DFT was easy as: > > FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > where the values of t_sub_k are apparently ordered but arbitrary. > I note that "w" isn't in any way discrete - ???? > > So, I think this isn't a DFT as we know it. > > Start with a DFT definition with > N the number of samples > T the temporal epoch, > fs the sampling frequency > T/N = 1/fs the temporal sample interval > 1/T = fs/N the frequency sample interval > > And the DFT is: > > F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*(kT/N)] ;n=0,N-1 > > If you want to have arbitrary values of "w" then you have a continuous > Fourier Transform of a discrete sequence: > > F(w) = sum k=1 to N a_sub_k*exp(-j*w*kT/N) which almost looks like what > you have above. > > It's not discrete in frequency. Just to be clear. I don't see how that's > "easy" to do using arrays of numbers in a computer - which seems to be where > you're heading with this. > > Then, if you want to make the sample times arbitrary then you would have > what we started with: > > F(w) = sum k=1 to N a_sub_k*exp(-j*w*t_sub_k) > > It's still not discrete in frequency - which is what you need to get a > finite sequence. > > So, it's common to assume that the temporal sequence is periodic on T and > the sum generating the transform is finite: If this is done you get > something like: > > F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!! > > The problem with this formulation is that the temporal resolution hasn't > been defined on a regular grid and that's necessary for the Fourier > Transform to be periodic instead of just infinite. If it's infinite then > this formulation can't be inverse transformed because it's incomplete - not > all the information is there. > > Another "problem" to ponder here is that the times aren't (i.e. need not be) > ordered - although in a Fourier Transform they are ordered. That must have > some bearing, eh? > > You might arbitrarily assign a time grid for the samples that sufficiently > captures the sample times on that grid. You might use 100 times the > narrowest separation between samples with the idea that the other > separations won't be too far off if forced onto the grid. > This results in maybe 1000*N sample points in time (?) and you put the > sample amplitudes on the nearest grid point in time. > > Now you can compute a DFT that's suitable (because you decided on the > parameters) - albeit a fairly long one. > > OK. > > Now to switching between time and amplitude as you suggested: > > Note that f(t) in the Fourier Transform is ordered in time. > Note that the values of t are unique. > > Note that amplitudes of signals or data generally aren't unique. > That suggests flipping them results in a situation that doesn't fit the > formulation. > One is a set of values and the other is an index or scale. Really very > different things. > > FredFred Yes, you are correct that I should not have used the term DFT; I was thinking in terms of the Fourier Transform of impulsive time-domain finite-length sequences where the times are not uniformly distributed. Such signals have a continuous spectrum that does not repeat. I think I made the problem too general; without any restriction on the amplitude sequence, it's true that after you flip time and amplitude you would likely get nonsense. I am more interested in special cases. A trivial one is where you sample a linear ramp signal, in which case time and amplitude are the same at every point and therefore reversing them causes no change. But I think there are other cases where there are some interesting relationships before and after the time-amplitude switch. It would take a long time to explain why I am interested in this; I have developed an unhealthy obsession with solving the Reimann Hypothesis, and have transformed it into a signal-processing problem with log-time sampling (see my 2005 ISCAS paper for more detail). Regards Bob Adams
robert.w.adams@verizon.net wrote: ...> It would take a long time to explain why I am interested in this; I > have developed an unhealthy obsession with solving the Reimann > Hypothesis, and have transformed it into a signal-processing problem > with log-time sampling (see my 2005 ISCAS paper for more detail).Bob, is there a free place to get that ISCAS paper? might we bug you for a pdf if there is none? r b-j
Reply by ●August 7, 20062006-08-07
Fred Marshall wrote:> <robert.w.adams@verizon.net> wrote in message > news:1154260055.670375.100450@h48g2000cwc.googlegroups.com...>>Suppose that I have a finite-length discrete-time signal that is not >>necessarily sampled on a uniform time grid. I will characterize this >>signal as a series of time-amplitude pairs with time = t_sub_k and >>amplitude = a_sub_k, where k is an integer from 1 to N that selects a >>particular time-amplitude pair.>>It is easy to take the DFT of this sequence even though the time grid >>may not be uniform.>>FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k))(snip)> You said a DFT was easy as:> FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k))> where the values of t_sub_k are apparently ordered but arbitrary. > I note that "w" isn't in any way discrete - ????> So, I think this isn't a DFT as we know it.> Start with a DFT definition with > N the number of samples > T the temporal epoch, > fs the sampling frequency > T/N = 1/fs the temporal sample interval > 1/T = fs/N the frequency sample interval> And the DFT is:> F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*(kT/N)] ;n=0,N-1Well, it would have been easier if it was stated that the samples were of a periodic function. My claim for a finite duration series is that it can be assumed periodic with a period greater than or equal to the duration without loss of information. If one considers a Fourier integral with delta functions at the appropriate points, it seems to make some sense to me. It transforms N sample values into N frequency values. The question, then, is does the inverse transform, the sum of the frequency components evaluated at the original positions, give the original signal? (see below)> If you want to have arbitrary values of "w" then you have a continuous > Fourier Transform of a discrete sequence:> F(w) = sum k=1 to N a_sub_k*exp(-j*w*kT/N) which almost looks like what > you have above.> It's not discrete in frequency. Just to be clear. I don't see how that's > "easy" to do using arrays of numbers in a computer - which seems to be where > you're heading with this.> Then, if you want to make the sample times arbitrary then you would have > what we started with:> F(w) = sum k=1 to N a_sub_k*exp(-j*w*t_sub_k)> It's still not discrete in frequency - which is what you need to get a > finite sequence.> So, it's common to assume that the temporal sequence is periodic on T and > the sum generating the transform is finite: If this is done you get > something like:> F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!!> The problem with this formulation is that the temporal resolution hasn't > been defined on a regular grid and that's necessary for the Fourier > Transform to be periodic instead of just infinite. If it's infinite then > this formulation can't be inverse transformed because it's incomplete - not > all the information is there.I am not convinced. If I have N samples amplitudes taken at N times, I want the N frequency components such that when evaluated at the original N times I get the original N amplitudes. I am not sure yet that the OP's transform does that, and so far I think it doesn't. It is possible, though unlikely, that the transform is singular, such that it can't be inverted. It is more likely to be ill-conditioned, which will happen if too many data points are too close together. If the transform isn't singular then there is enough data. The aliasing rules aren't simple, though. You can have any N frequencies, not necessarily the first N harmonics (starting from zero). The nice thing about the Fourier series is that orthogonality makes the inverse easy. Without orthogonality one must compute the inverse of the transform matrix.> Another "problem" to ponder here is that the times aren't (i.e. need not be) > ordered - although in a Fourier Transform they are ordered. That must have > some bearing, eh?I don't think that matters much. It is just like exchanging rows or columns of a matrix which, if done right, doesn't affect the answer. Consider and N equations and N unknowns problem. The answer doesn't depend on the order I write the equations down. -- glen
Reply by ●August 8, 20062006-08-08
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message news:GbOdnc4e684Ae0rZnZ2dnUVZ_u-dnZ2d@comcast.com...> Fred Marshall wrote: >> <robert.w.adams@verizon.net> wrote in message >> news:1154260055.670375.100450@h48g2000cwc.googlegroups.com... > >>>Suppose that I have a finite-length discrete-time signal that is not >>>necessarily sampled on a uniform time grid. I will characterize this >>>signal as a series of time-amplitude pairs with time = t_sub_k and >>>amplitude = a_sub_k, where k is an integer from 1 to N that selects a >>>particular time-amplitude pair. > >>>It is easy to take the DFT of this sequence even though the time grid >>>may not be uniform. > >>>FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > > > (snip) > >> You said a DFT was easy as: > >> FT(w) = SUM k=1 to N (a_sub_k*exp(-j*w*t_sub_k)) > >> where the values of t_sub_k are apparently ordered but arbitrary. >> I note that "w" isn't in any way discrete - ???? > >> So, I think this isn't a DFT as we know it. > >> Start with a DFT definition with >> N the number of samples >> T the temporal epoch, >> fs the sampling frequency >> T/N = 1/fs the temporal sample interval >> 1/T = fs/N the frequency sample interval > >> And the DFT is: > >> F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*(kT/N)] ;n=0,N-1 > > Well, it would have been easier if it was stated that the samples > were of a periodic function. My claim for a finite duration > series is that it can be assumed periodic with a period greater > than or equal to the duration without loss of information. > > If one considers a Fourier integral with delta functions at > the appropriate points, it seems to make some sense to me. > > It transforms N sample values into N frequency values. > The question, then, is does the inverse transform, the sum > of the frequency components evaluated at the original positions, > give the original signal? (see below) > >> If you want to have arbitrary values of "w" then you have a continuous >> Fourier Transform of a discrete sequence: > >> F(w) = sum k=1 to N a_sub_k*exp(-j*w*kT/N) which almost looks like what >> you have above. > >> It's not discrete in frequency. Just to be clear. I don't see how >> that's "easy" to do using arrays of numbers in a computer - which seems >> to be where you're heading with this. > >> Then, if you want to make the sample times arbitrary then you would have >> what we started with: > >> F(w) = sum k=1 to N a_sub_k*exp(-j*w*t_sub_k) > >> It's still not discrete in frequency - which is what you need to get a >> finite sequence. > >> So, it's common to assume that the temporal sequence is periodic on T and >> the sum generating the transform is finite: If this is done you get >> something like: > >> F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!! > >> The problem with this formulation is that the temporal resolution hasn't >> been defined on a regular grid and that's necessary for the Fourier >> Transform to be periodic instead of just infinite. If it's infinite then >> this formulation can't be inverse transformed because it's incomplete - >> not all the information is there. > > I am not convinced. > > If I have N samples amplitudes taken at N times, I want the N frequency > components such that when evaluated at the original N times I get the > original N amplitudes. I am not sure yet that the OP's transform does > that, and so far I think it doesn't. > > It is possible, though unlikely, that the transform is singular, such > that it can't be inverted. It is more likely to be ill-conditioned, > which will happen if too many data points are too close together. > If the transform isn't singular then there is enough data. > The aliasing rules aren't simple, though. You can have any N frequencies, > not necessarily the first N harmonics (starting > from zero). > > The nice thing about the Fourier series is that orthogonality makes > the inverse easy. Without orthogonality one must compute the > inverse of the transform matrix. > >> Another "problem" to ponder here is that the times aren't (i.e. need not >> be) ordered - although in a Fourier Transform they are ordered. That >> must have some bearing, eh? > > I don't think that matters much. It is just like exchanging rows or > columns of a matrix which, if done right, doesn't affect the answer. > Consider and N equations and N unknowns problem. The answer doesn't > depend on the order I write the equations down. > > -- glenGlen, First:>"My claim for a finite duration > series is that it can be assumed periodic with a period greater > than or equal to the duration without loss of information."This was dealt with later..... at a point where it seemed to fit into the discussion. Second:>> F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!! > >> The problem with this formulation is that the temporal resolution hasn't >> been defined on a regular grid and that's necessary for the Fourier >> Transform to be periodic instead of just infinite. If it's infinite then >> this formulation can't be inverse transformed because it's incomplete - >> not all the information is there. > > "I am not convinced."You are not convinced about what aspect of the assertion? - Is it not correct that the temporal resolution hasn't been defined (by the OP) on a regular grid. It would be even more correct to say that there is *no* temporal resolution defined in this formulation. - Is it not correct that a regular grid of samples in time is necessary for the Fourier Transform to be periodic? You can pick whatever irreducible temporal resolution you like and whatever number of nonzero temporal samples you like - it's the temporal resolution that is tied to the frequency periodicity. - Is it not correct that the Fourier Transform is of infinite extent if there is *no* temporal period? For example, what if two samples are separated by 1 time unit and two samples are separated by pi time units. Then there is no common temporal division possible (in theory). In that case, the Fourier Transform is of infinite extent, no? - Is it not correct that a number of samples selected out of an infinite Fourier Transform (or computed as distinct points from the time domain) do not, in general, sufficiently define the frequency domain to support computing an inverse transform? Fred
Fred Marshall wrote: (snip of discussion of Fourier transform with non-uniform spaced sample points)> First:>>"My claim for a finite duration >>series is that it can be assumed periodic with a period greater >>than or equal to the duration without loss of information."> This was dealt with later..... at a point where it seemed to fit into the > discussion.> Second:>>>F(n*fs/N) = sum k=1 to N a_sub_k*exp[-j*(nfs/N)*t_sub_k] ;n=0,N-1 !!!>>>The problem with this formulation is that the temporal resolution hasn't >>>been defined on a regular grid and that's necessary for the Fourier >>>Transform to be periodic instead of just infinite. If it's infinite then >>>this formulation can't be inverse transformed because it's incomplete - >>>not all the information is there.>>"I am not convinced."> You are not convinced about what aspect of the assertion?> - Is it not correct that the temporal resolution hasn't been defined > (by the OP) on a regular grid. > It would be even more correct to say that there is *no* temporal resolution > defined in this formulation.More often discussed here is sampled data with non-uniform sampling, and the effect on the Nyquist frequency. In the case of the Fourier transform the boundary conditions are periodic by definition. For the given problem, then, the question should be what are the amplitudes of the appropriate frequency components. If you agree that the boundary conditions are periodic, then the temporal resolution pretty much depends on the period and the number of sample points, assuming the transform isn't singular. (You can't have two sample points at the same time, for example.)> - Is it not correct that a regular grid of samples in time is necessary for > the Fourier Transform to be periodic? You can pick whatever irreducible > temporal resolution you like and whatever number of nonzero temporal samples > you like - it's the temporal resolution that is tied to the frequency > periodicity.Resolution comes from the period and number of samples. If there is noise in the signal, it is better to have equally spaced points.> - Is it not correct that the Fourier Transform is of infinite extent if > there is *no* temporal period? For example, what if two samples are > separated by 1 time unit and two samples are separated by pi time units. > Then there is no common temporal division possible (in theory). In that > case, the Fourier Transform is of infinite extent, no?Maybe it shouldn't be called a Fourier transform anymore, but consider sample points spaced [ 1, pi, 1, pi, 1, pi , etc.] A signal could have a period of pi+1. As for the OP's question, any period longer than the extent of the data should work.> - Is it not correct that a number of samples selected out of an infinite > Fourier Transform (or computed as distinct points from the time domain) do > not, in general, sufficiently define the frequency domain to support > computing an inverse transform?Well, this gets back to sampling theory itself. If it can be represented with a finite number of uniformly space points, it should also work with a finite number of non-uniformly spaced points. I don't believe that the OP's transform is correct, though. Consider the N point DFT as a NxN matrix that when multiplied by an N point vector generates an N point transform. The inverse of the transform is the inverse of the matrix. For the usual DFT, the matrix and its inverse are simple to compute. For non-uniform points, one desires the transform matrix that is the inverse of the transform that, given the sample points and component amplitudes gives the sample data. The two are not simply related the way the DFT and IDFT are. -- glen
glen herrmannsfeldt wrote:> Fred Marshall wrote:...>> - Is it not correct that a number of samples selected out of an >> infinite Fourier Transform (or computed as distinct points from the >> time domain) do not, in general, sufficiently define the frequency >> domain to support computing an inverse transform? > > Well, this gets back to sampling theory itself. If it can be > represented with a finite number of uniformly space points, it should > also work with a finite number of non-uniformly spaced points.Surely not *any* amount of non-uniformity. This gets back to a previous discussion of this topic. Speech uniformly sampled for a minute at 8 KHz amounts to 480,000 samples; that many are generated in less than a second by a .5 MHz sampler. Does anyone suppose that a whole minute of speech can be reproduced from second's worth of samples? With enough processing power and ram, one could then reproduce an hour's worth of information from samples taken in the first minute. AMEX, here I come! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
