OK, I have an extremely silly (almost embarrasing) problem with Code Composer 3.1. I'm going through some of the dsp/bios tutorials, and the first one has me opening the hello1 (hellobios) project and profiling it. Well, it tells me to check the appropriate box and then open the ranges tab, highlight the puts function and drag it over to the Ranges listing in the tab. Unfortunately, it does not let me drag it over there, nor does it allow me to select define a range in the profiler window and just define it via the line number in the hello.c file. Does anyone have any idea what I'm doing wrong. It's starting to be annoying stuck at what is essentially an IDE issue rather than a real technical one. Thanks.
Silly problem with Code Composer 3.1
Started by ●August 3, 2006
Reply by ●August 4, 20062006-08-04
salaughter@gmail.com wrote:> OK, I have an extremely silly (almost embarrasing) problem with Code > Composer 3.1. I'm going through some of the dsp/bios tutorials, and > the first one has me opening the hello1 (hellobios) project and > profiling it. Well, it tells me to check the appropriate box and then > open the ranges tab, highlight the puts function and drag it over to > the Ranges listing in the tab. Unfortunately, it does not let me drag > it over there, nor does it allow me to select define a range in the > profiler window and just define it via the line number in the hello.c > file. Does anyone have any idea what I'm doing wrong.Not sure from this distance. Sorry.> It's starting > to be annoying stuck at what is essentially an IDE issue rather than a > real technical one.As you gain experience with the IDE, you will find that your level of annoyance does not decrease. It is buggy and poorly designed in countless ways. On the other hand, it has some nice features like the ability to graph data right there in the IDE. Cheers! --M
