calculating the coefficients of a butterworth iir filter
Started by dilpreet06 August 4, 2006
Hallo everyone!
I wanted to ask your advice on the following problem:
i have to generate a butterworth iir bandpass filter with cutoff
frequencies of 0.008 and 0.05 Hertz. This will be used in filtering a time
signal sampled at 1 Hz (so the sampling frequency is high enough to work
with the time signal)
My initial problem is to calculate the coefficients. Ive thought of a few
ways to calculate them which could be (if im not wrong):
my input parameters are : Filter Order and Gain. The programming language
used is c++ with it++ as a signal processing library.
   1. generate a frequency vector (size : Filter Order + 1) running from 0
to  1.0 and a corresponding Magnitude vector and calculate the coefficients
using the Yule Walker equations. this however is a bit inaccurate because i
have to modify the magnitude vector using trial and error.
   2. taking the coefficients from a table, which is easy and would work,
but others have calculated these, so I would like to learn it.
  3. Billinear transform. But this appears somewhat complicated for a
filter of higher order and looking at my extremely narrow passband, i
wonder if this is the right way. :-/
ive looked at the sourcecode for some java applets on the net that
calculate filter coefficients, but found it quite hard to follow.
so my question is: what would be an effective method for calculating the
butterworth filter coefficients especially in c++?
many thanks for your replies in advance!
dilpreet
dilpreet06 skrev:
> Hallo everyone! > > I wanted to ask your advice on the following problem: > > i have to generate a butterworth iir bandpass filter with cutoff > frequencies of 0.008 and 0.05 Hertz. This will be used in filtering a time > signal sampled at 1 Hz (so the sampling frequency is high enough to work > with the time signal) > > My initial problem is to calculate the coefficients. Ive thought of a few > ways to calculate them which could be (if im not wrong): > > my input parameters are : Filter Order and Gain.
The most effective input comprise sampling frequency, stop band(s) and pass-band(s) cut-off frequencies, stop band attenuation and passband ripple. The gain is merely a sacling factor and the filter order is computed along the way based on the above spec.
> The programming language > used is c++ with it++ as a signal processing library. > > 1. generate a frequency vector (size : Filter Order + 1) running from 0 > to 1.0 and a corresponding Magnitude vector and calculate the coefficients > using the Yule Walker equations. this however is a bit inaccurate because i > have to modify the magnitude vector using trial and error.
It is possible to design filters that way, but you are asking specifically for Butterworth IIRs. There are far more efficient ways to design those.
> 2. taking the coefficients from a table, which is easy and would work, > but others have calculated these, so I would like to learn it.
Use this approach if you need immediate results. If you have more time on your hands, find a decent text on filter design that contains the recipe for how to do this. One such text is suggested below.
> 3. Billinear transform. But this appears somewhat complicated for a > filter of higher order and looking at my extremely narrow passband, i > wonder if this is the right way. :-/
This is the way to go, if you wnat to learn. The key is to see that higher-order IIRs are implemented as a sequence of 2-pole primitives, the "biquads." You only have to work out the bilinear transform for orders 1 and 2. When you design your 73-order IIR filter you represent it as 36 biquads and one 1st order section, and apply the 1st and 2nd order BLTs to each of those.
> ive looked at the sourcecode for some java applets on the net that > calculate filter coefficients, but found it quite hard to follow.
Don't bother. You have to dig deep into the textbook literature to find these recipes. No one have written textbooks on these matters for more than 30 years. The one recent book I know of, that contains the recipes, is http://www.amazon.com/gp/product/0071454241/sr=8-1/qid=1154767557/ref=sr_1_1/103-3640117-4140620?ie=UTF8 It contains recipes for Butterworths, Chebychevs and elliptic filters, among others. It also contain frequency tranforms and shows how to apply pre-warping to fine-tune the designs. This is a new version of some text that first was written in the 60s. It is good on filter design recipes, but some details in the notation are at odds with what has emerged as the standard in DSP these days. Usually, the coefficients in the numerator polynomial in transfer functions H(w) are designated b_i, and the coefficients in the denominator polynomial are denoted as a_i. In this book, they are the oposite. Not a big deal, but maybe worth keeping a note of if you read other DSP texts as well, and want to compare approaches.
> so my question is: what would be an effective method for calculating the > butterworth filter coefficients especially in c++?
It depends on what you mean by "effective". Designing the filter is not very computationally expensive; they are done with in a matter of milliseconds. The main problem in this application is to keep track of all the details while preserving the sanity of whoever maintains the code. Starting with the spec as indicated above (normalized corner frequencies and attenuations/ripple), one has to do a lot of tasks that are trivial per se, but that need to be fitted into a rather complex picture: - Transform the spec to an LP prototype. This step depends on if one wants an LP, HP BP or BS filter. - Pre-warp the prototype parameters from discrete-time to continuous time. - Compute the order of the filter. This step depends on type of filter (Butterworth, Chebyshev, Elliptic). - Compute the coefficients on the biquads.This step depends on type of filter (Butterworth, Chebyshev, Elliptic). - Apply the BLT to the biquads - Transform the dicrete-time prototype filter to the desired discrete-time filter. This step depends on if one wants an LP, HP BP or BS filter. In some of these stages one might want to use polynomial root solvers to separate 4-pole sections into two biquads. There is lots of book-keeping to be done here. Implement this wrong and you immediately have a maintenance night-mare on your hands. I used this very task as an oportunity to program "real" OO code with C++. I managed to keep track of all these details without using a single "case switch" statement. Everything is taken care of only using classes and argument type matching on method calls. It can be done, but the starting point needs to be that you understand the nuts'n bolts of designing filters. If you want to learn how do design filters, design both a Butterworth and a Chebyshev filter according to the spec above (and a LP spec and a HP spec), so you get a feel for what is similar and what is different. Don't get mixed up with program organization until you have done that; the computational routines are almost trivial. When you get a sense for the big picture, start playing around with ways of merging all this into a C++/Java setting. At this stage you ought to have all the computational details available, so you can focus your attention to program organization. Rune
Rune, thanks for the depthful and carefully explained thread!
You've more or less confirmed what i suspected earlier. I shall use the
tables for now, but try out the biquad and billinear transform in the
future when i have more time.
Ive seen some of your (and other peoples') replies to other threads here.
Thanks for sharing your wealth of info with others. Knowledge is power.
Peace.
dilpreet06 wrote:
> Knowledge is power.
Others here would counter: "Imagination is more important than knowledge". :-)
Y're welcome.
> You've more or less confirmed what i suspected earlier. I shall use the > tables for now, but try out the biquad and billinear transform in the > future when i have more time.
That's the trick, isn't it: Use the right approach at the right time. Get results when needed, expand your knowledge base when you have the oportunity.
> Ive seen some of your (and other peoples') replies to other threads here. > Thanks for sharing your wealth of info with others.
I've learned more DSP here on comp.dsp in the last few years, than during a decade in universities and R&D organizations. My experience is that one haven't learned the material well until one is able to explain it to others in their own terms.
> Knowledge is power.
Opinions may be divided on the matter... Rune
