Hi I hope someone in this group can help me. I have a basic understanding of electronics and uC, but my knowledge is - to say the least - a bit rusty. A friend of mine asked me to help build a circuit, so now I ask here:-) Wanted: I need to produce a 100kHz sine wave with an amplitude in the range [2 5] V. I'm not sure about the resolution, but I guess (!) it should be 10 or 12 bits. This is used as input to a substance via two electrodes, and I need to measure on this substance using two other electrodes and do a fft on the measurements. The current design uses a uC (atmel something) and a AD5933 which then produces the result for use in the uC. But now we are looking for a simpler way in which we hopefully can use just one chip. Needless to say it should be small and low power! Can anyone give a hint to what chip to use for this or other guidelines? Any help is greatly appreciated. Best, John Doe
dsp/fft. Help with simple design
Started by ●August 5, 2006
Reply by ●August 5, 20062006-08-05
tilnews@gmail.com wrote:> Hi > I hope someone in this group can help me. I have a basic understanding > of electronics and uC, but my knowledge is - to say the least - a bit > rusty. > A friend of mine asked me to help build a circuit, so now I ask here:-) > > Wanted: I need to produce a 100kHz sine wave with an amplitude in the > range [2 5] V. I'm not sure about the resolution, but I guess (!) it > should be 10 or 12 bits. This is used as input to a substance via two > electrodes, and I need to measure on this substance using two other > electrodes and do a fft on the measurements. > The current design uses a uC (atmel something) and a AD5933 which then > produces the result for use in the uC. But now we are looking for a > simpler way in which we hopefully can use just one chip. Needless to > say it should be small and low power!You won't find any uC (internal A2D) fast enough to match the AD5933. What's wrong with the 2 chips design?> > Can anyone give a hint to what chip to use for this or other > guidelines? Any help is greatly appreciated. > Best, > John Doe
tilnews@gmail.com wrote:> Hi > I hope someone in this group can help me. I have a basic understanding > of electronics and uC, but my knowledge is - to say the least - a bit > rusty. > A friend of mine asked me to help build a circuit, so now I ask here:-) > > Wanted: I need to produce a 100kHz sine wave with an amplitude in the > range [2 5] V. I'm not sure about the resolution, but I guess (!) it > should be 10 or 12 bits. This is used as input to a substance via two > electrodes, and I need to measure on this substance using two other > electrodes and do a fft on the measurements. > The current design uses a uC (atmel something) and a AD5933 which then > produces the result for use in the uC. But now we are looking for a > simpler way in which we hopefully can use just one chip. Needless to > say it should be small and low power! > > Can anyone give a hint to what chip to use for this or other > guidelines? Any help is greatly appreciated.I'll bet you can do with just the AD5399 and a i00Hz crystal oscillator. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> tilnews@gmail.com wrote: > > Hi > > I hope someone in this group can help me. I have a basic understanding > > of electronics and uC, but my knowledge is - to say the least - a bit > > rusty. > > A friend of mine asked me to help build a circuit, so now I ask here:-) > > > > Wanted: I need to produce a 100kHz sine wave with an amplitude in the > > range [2 5] V. I'm not sure about the resolution, but I guess (!) it > > should be 10 or 12 bits. This is used as input to a substance via two > > electrodes, and I need to measure on this substance using two other > > electrodes and do a fft on the measurements. > > The current design uses a uC (atmel something) and a AD5933 which then > > produces the result for use in the uC. But now we are looking for a > > simpler way in which we hopefully can use just one chip. Needless to > > say it should be small and low power! > > > > Can anyone give a hint to what chip to use for this or other > > guidelines? Any help is greatly appreciated. > > I'll bet you can do with just the AD5399 and a i00Hz crystal oscillator.Yes, a three chips solution: AD5933, AD5399 and XC3S1000 should work.> > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
Reply by ●August 6, 20062006-08-06
linnix wrote:> You won't find any uC (internal A2D) fast enough to match the AD5933. > What's wrong with the 2 chips design? >The speed is not the most important issue, overall size is. It doesn't need to be "real time" fft. It is okay, if we just send a sine for a few ms and then use a few seconds processing the result.
tilnews@gmail.com writes:> [...] > Can anyone give a hint to what chip to use for this or other > guidelines? Any help is greatly appreciated.Hi John, How about something like TI's MSP430F155? It has on-board 12-bit ADC and DAC, is very low-power, and enough MIPS to do the simple DSP tasks you ask for. -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Randy Yates wrote:> tilnews@gmail.com writes: > > [...] > > Can anyone give a hint to what chip to use for this or other > > guidelines? Any help is greatly appreciated. > > Hi John, > > How about something like TI's MSP430F155? It has on-board 12-bit ADC and DAC, > is very low-power, and enough MIPS to do the simple DSP tasks you ask for.That looks very interesting. I'll give that one a check. Thanks
tilnews@gmail.com wrote:> Randy Yates wrote: > > tilnews@gmail.com writes: > > > [...] > > > Can anyone give a hint to what chip to use for this or other > > > guidelines? Any help is greatly appreciated. > > > > Hi John, > > > > How about something like TI's MSP430F155? It has on-board 12-bit ADC and DAC, > > is very low-power, and enough MIPS to do the simple DSP tasks you ask for. > > That looks very interesting. I'll give that one a check. > ThanksBe aware that it can probably do a few hundred KSPS at best, not MSPS.
"linnix" <me@linnix.info-for.us> writes:> tilnews@gmail.com wrote: >> Randy Yates wrote: >> > tilnews@gmail.com writes: >> > > [...] >> > > Can anyone give a hint to what chip to use for this or other >> > > guidelines? Any help is greatly appreciated. >> > >> > Hi John, >> > >> > How about something like TI's MSP430F155? It has on-board 12-bit ADC and DAC, >> > is very low-power, and enough MIPS to do the simple DSP tasks you ask for. >> >> That looks very interesting. I'll give that one a check. >> Thanks > > Be aware that it can probably do a few hundred KSPS at best, not MSPS.It's an 8 MHz part - you can probably get 1 MSPS out of it, if you're just outputting to a DAC and collecting input from a ADC. Note that it has DMA, so you won't waste cycles transferring data. -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
Reply by ●August 12, 20062006-08-12
linnix wrote:> > tilnews@gmail.com wrote: >> Randy Yates wrote: >> > tilnews@gmail.com writes: >> > > [...] >> > > Can anyone give a hint to what chip to use for this or other >> > > guidelines? Any help is greatly appreciated. >> > >> > Hi John, >> > >> > How about something like TI's MSP430F155? It has on-board 12-bit ADC >> > and DAC, is very low-power, and enough MIPS to do the simple DSP tasks >> > you ask for. >> >> That looks very interesting. I'll give that one a check. >> Thanks > > Be aware that it can probably do a few hundred KSPS at best, not MSPS.I went and checked out the data sheet, do not count on more than about 250 k samples / second. Try a real DSP of the TMS320c5000 series. -- JosephKK Gegen dummheit kampfen die Gotter Selbst, vergebens. --Schiller
