dsp/fft. Help with simple design
Started by Unknown ●August 5, 2006
tilnews@gmail.com wrote:
> Hi > I hope someone in this group can help me. I have a basic understanding > of electronics and uC, but my knowledge is - to say the least - a bit > rusty. > A friend of mine asked me to help build a circuit, so now I ask here:-) > > Wanted: I need to produce a 100kHz sine wave with an amplitude in the > range [2 5] V. I'm not sure about the resolution, but I guess (!) it > should be 10 or 12 bits. This is used as input to a substance via two > electrodes, and I need to measure on this substance using two other > electrodes and do a fft on the measurements. > The current design uses a uC (atmel something) and a AD5933 which then > produces the result for use in the uC. But now we are looking for a > simpler way in which we hopefully can use just one chip. Needless to > say it should be small and low power! > > Can anyone give a hint to what chip to use for this or other > guidelines? Any help is greatly appreciated. > Best, > John Doe
Try the analog devices microcontroller ADUC70XX http://www.analog.com/en/subCat/0,2879,762%255F%255F0%255F%255F0%255F,00.html lower price then MSP430 ($5), with much better analog (1 MHz 12 bit A/D same as the AD5933, and 12 bit DAC) and a much better processor (32 bit 40MHZ ARM), a FFT is no problem with chip, they come in small 6x6 mm packages too, down side is it takes more power then the MSP430, (11mA At 5Mhz, 40mA at 40Mhz), but if you can afford the power this would be a better choice
> You won't find any uC (internal A2D) fast enough to match the AD5933. >
sure you can, the Analog Devices ADUC70XX uC has a better A/D then the AD5933
On 2006-08-13, steve <bungalow_steve@yahoo.com> wrote:
> > Try the analog devices microcontroller ADUC70XX > > http://www.analog.com/en/subCat/0,2879,762%255F%255F0%255F%255F0%255F,00.html > > lower price then MSP430 ($5), with much better analog (1 MHz 12 bit A/D > same as the AD5933, and 12 bit DAC) and a much better processor (32 bit > 40MHZ ARM)
And even though the package is prototype-unfriendly, there's a $30 "mini kit" which has the ADuC7020 on a 40 pin DIP sized board. I found it while looking for discrete DACs for a microcontroller project. The Analog part really takes the analog parts (sorry) much more seriously than a typical microcontroller. They don't multiplex the ADC and DAC pins with GPIOs. The ADC performance is way beyond typical micros. -- Ben Jackson AD7GD <ben@ben.com> http://www.ben.com/
Ben Jackson <ben@ben.com> writes:
> On 2006-08-13, steve <bungalow_steve@yahoo.com> wrote: >> >> Try the analog devices microcontroller ADUC70XX >> >> http://www.analog.com/en/subCat/0,2879,762%255F%255F0%255F%255F0%255F,00.html >> >> lower price then MSP430 ($5), with much better analog (1 MHz 12 bit A/D >> same as the AD5933, and 12 bit DAC) and a much better processor (32 bit >> 40MHZ ARM) > > And even though the package is prototype-unfriendly, there's a $30 "mini > kit" which has the ADuC7020 on a 40 pin DIP sized board. I found it while > looking for discrete DACs for a microcontroller project. The Analog part > really takes the analog parts (sorry) much more seriously than a typical > microcontroller. They don't multiplex the ADC and DAC pins with GPIOs. > The ADC performance is way beyond typical micros.
Hey Ben, These look like really cool parts. Thanks for bringing them to my (our) attention. -- % Randy Yates % "So now it's getting late, %% Fuquay-Varina, NC % and those who hesitate %%% 919-577-9882 % got no one..." %%%% <yates@ieee.org> % 'Waterfall', *Face The Music*, ELO http://home.earthlink.net/~yatescr
Ben Jackson wrote:
> On 2006-08-13, steve <bungalow_steve@yahoo.com> wrote: > > > > Try the analog devices microcontroller ADUC70XX > > > > http://www.analog.com/en/subCat/0,2879,762%255F%255F0%255F%255F0%255F,00.html > > > > lower price then MSP430 ($5), with much better analog (1 MHz 12 bit A/D > > same as the AD5933, and 12 bit DAC) and a much better processor (32 bit > > 40MHZ ARM) > > And even though the package is prototype-unfriendly, there's a $30 "mini > kit" which has the ADuC7020 on a 40 pin DIP sized board. I found it while > looking for discrete DACs for a microcontroller project.
sparkfun.com also has them in DIP sized boards http://www.sparkfun.com/commerce/product_info.php?products_id=471 The Analog part
Yes, the ADuCs are basically A/D's with processors added on, while most micros add the A/D's on as a afterthough. All the ADuC's A/D characteristics are spec at full processor speed, including noise, the MSP430 datasheets don't even specify noise or even input bandwidth of it's A/D, well at least I couldn't find them, the MSP430 is still a nice chip though, very low power.
> > -- > Ben Jackson AD7GD > <ben@ben.com> > http://www.ben.com/
