Greetings. The GSM AMR output has only 0xff81 and 0x007f only. Why is it not that one can compress the stream further that sends the number of ff81 and number of 7f in the encoder output stream. as in: ff81 ff81 007f 007f 007f 007f 007f 007f 007f can be: ff81 02 007f 07 ... or some other flag to represent ff81 and 007f One can compress the output further remarkably and will require to put a small "stream regenerator". I have not seen the GSM AMR output with any other content apart from the above two values. Why is it so ? Thanks, Akshay
GSM AMR output
Started by ●August 6, 2006
Reply by ●August 6, 20062006-08-06
Self correction on realisation. !! there are 253 bytes ouput of ff81/007f hence to achieve the 12.65kbps link you send the sign bits to the other end. even the flag/count pain is not required. Am I correct here. Thanks, Akshay Akshay Mishra wrote:> Greetings. > > The GSM AMR output has only 0xff81 and 0x007f only. Why is it not that > one can compress the stream further that sends the number of ff81 and > number of 7f in the encoder output stream. > as in: > ff81 ff81 007f 007f 007f 007f 007f 007f 007f > can be: ff81 02 007f 07 ... or some other flag to represent ff81 and > 007f > One can compress the output further remarkably and will require to put > a small "stream regenerator". > I have not seen the GSM AMR output with any other content apart from > the above two values. Why is it so ? > > Thanks, > Akshay
