I have two 16-bit wav files and am using Microsoft DirectSound to play and mix the files. I'm able to "mix" the two audio files by simply adding the wav data values together. I have a problem however, when attempting to "fade" from one audio file to the other. Algorithm is listed below: Get two bytes of WAV data from the "right file" Put second byte into uint (32 bit) and bit-shift 8 bits to the left Put first byte into temp uint value rightValue (uint) = first uint value | second uint value repeat above steps for the "left file" // this works for the most part, however there's a bit of distortion // which dithering doesn't seem to fix add values together // this doesn't work no matter how I try to do it // faderValue ranges from +100 to -100 uint (32 bit) addedValue = rightValue * (faderValue * .01) + leftValue * (AbsoluteValue(faderValue) * .01) add random 1-bit dither value to the value This results in mass distortion, barely able to make out either of the audio files at all. Additionally, I've tried to normalize the data values in order to hopefully get some of the lower frequency values out to avoid the distortion, but to no avail. I realize that the multiplication, rounding, etc. aren't necessarily good for digital audio, but I've got to think there's a way to do this with 16 bit files. Or, are 16 bit files just not precise enough to do this sort of thing? Thanks in advance. T
How to fade audio
Started by ●August 7, 2006
Reply by ●August 7, 20062006-08-07
terrel_b@yahoo.com wrote:> // this doesn't work no matter how I try to do it > // faderValue ranges from +100 to -100 > uint (32 bit) addedValue = rightValue * (faderValue * .01) + > leftValue * (AbsoluteValue(faderValue) * .01)The weights for the two files should be nonnegative and add up to 1 at any moment. Exactly how to get there depends on what the fader value means to the user. Martin -- Quidquid latine scriptum sit, altum viditur.
terrel_b@yahoo.com wrote:> > I have two 16-bit wav files and am using Microsoft DirectSound > to play and mix the files. I'm able to "mix" the two audio files > by simply adding the wav data values together. I have a problem > however, when attempting to "fade" from one audio file to the > other. Algorithm is listed below: > > Get two bytes of WAV data from the "right file" > Put second byte into uint (32 bit) and bit-shift 8 bits to the > left Put first byte into temp uint value > rightValue (uint) = first uint value | second uint valueIndependent of my other reply, the words in a 16-bit wave file are twos-complement signed! Martin -- Quidquid latine scriptum sit, altum viditur.
