Hi, I am trying to use the Reed-Solomon encoder in the Matlab Communications toolbox ( command rsenc). For example if you are trying to a (7,3) R-S encoder. When you use rsenc the inputs and outputs have are alphabets in the respective Galois fields ( GF(8) in this example). Is there a way to convert the input and output formats such that we can input a binary string and get a binary string of the encoder. I know there exists a block in the Simulink blockset for this purpose - but i don't want to use simulink. i want the simulation entirely in matlab with the comm toolbox.
Reed-Solomon encoder in Matlab
Started by ●August 7, 2006
Reply by ●August 7, 20062006-08-07
ramsay wrote:> Hi, > > I am trying to use the Reed-Solomon encoder in the Matlab Communications > toolbox ( command rsenc). For example if you are trying to a (7,3) R-S > encoder. When you use rsenc the inputs and outputs have are alphabets in > the respective Galois fields ( GF(8) in this example). Is there a way to > convert the input and output formats such that we can input a binary > string and get a binary string of the encoder. I know there exists a block > in the Simulink blockset for this purpose - but i don't want to use > simulink. i want the simulation entirely in matlab with the comm toolbox.Try this : binary_in=['110';'010';'101'] dec_in=bin2dec(fliplr(binary_in)) msg_in=gf(dec_in,3) msg_coded=rsenc(msg_in,7,3,rsgenpoly(7,3,[],1)) msg_coded=rsenc(msg_in',7,3,rsgenpoly(7,3,[],1)) msg_coded_dec=msg_coded.x msg_coded_bin=fliplr(dec2bin(msg_coded_dec')) Nezhate from moscow!
> >ramsay wrote: >> Hi, >> >> I am trying to use the Reed-Solomon encoder in the MatlabCommunications>> toolbox ( command rsenc). For example if you are trying to a (7,3) R-S >> encoder. When you use rsenc the inputs and outputs have are alphabetsin>> the respective Galois fields ( GF(8) in this example). Is there a wayto>> convert the input and output formats such that we can input a binary >> string and get a binary string of the encoder. I know there exists ablock>> in the Simulink blockset for this purpose - but i don't want to use >> simulink. i want the simulation entirely in matlab with the commtoolbox.> >Try this : >binary_in=['110';'010';'101'] >dec_in=bin2dec(fliplr(binary_in)) >msg_in=gf(dec_in,3) >msg_coded=rsenc(msg_in,7,3,rsgenpoly(7,3,[],1)) >msg_coded=rsenc(msg_in',7,3,rsgenpoly(7,3,[],1)) >msg_coded_dec=msg_coded.x >msg_coded_bin=fliplr(dec2bin(msg_coded_dec')) > >Nezhate from moscow! > >Wow ! I like that. Thanks for the answer.
Reply by ●October 8, 20132013-10-08
On Tuesday, August 8, 2006 1:57:25 AM UTC+5:30, ramsay wrote:> Hi, > > I am trying to use the Reed-Solomon encoder in the Matlab Communications > toolbox ( command rsenc). For example if you are trying to a (7,3) R-S > encoder. When you use rsenc the inputs and outputs have are alphabets in > the respective Galois fields ( GF(8) in this example). Is there a way to > convert the input and output formats such that we can input a binary > string and get a binary string of the encoder. I know there exists a block > in the Simulink blockset for this purpose - but i don't want to use > simulink. i want the simulation entirely in matlab with the comm toolbox.hi i need matlab code for rs solomon encoder without using rsenc command
On Tuesday, August 8, 2006 3:13:34 AM UTC+5:30, MN wrote:> ramsay wrote: > > Hi, > > > > I am trying to use the Reed-Solomon encoder in the Matlab Communications > > toolbox ( command rsenc). For example if you are trying to a (7,3) R-S > > encoder. When you use rsenc the inputs and outputs have are alphabets in > > the respective Galois fields ( GF(8) in this example). Is there a way to > > convert the input and output formats such that we can input a binary > > string and get a binary string of the encoder. I know there exists a block > > in the Simulink blockset for this purpose - but i don't want to use > > simulink. i want the simulation entirely in matlab with the comm toolbox. > > Try this : > binary_in=['110';'010';'101'] > dec_in=bin2dec(fliplr(binary_in)) > msg_in=gf(dec_in,3) > msg_coded=rsenc(msg_in,7,3,rsgenpoly(7,3,[],1)) > msg_coded=rsenc(msg_in',7,3,rsgenpoly(7,3,[],1)) > msg_coded_dec=msg_coded.x > msg_coded_bin=fliplr(dec2bin(msg_coded_dec')) > > Nezhate from moscow!i need matlab code for rs solomon encoder without using rsenc command
On 8.10.13 7:17 , priyankareddyj921@gmail.com wrote:> On Tuesday, August 8, 2006 1:57:25 AM UTC+5:30, ramsay wrote: >> Hi, >> >> I am trying to use the Reed-Solomon encoder in the Matlab Communications >> toolbox ( command rsenc). For example if you are trying to a (7,3) R-S >> encoder. When you use rsenc the inputs and outputs have are alphabets in >> the respective Galois fields ( GF(8) in this example). Is there a way to >> convert the input and output formats such that we can input a binary >> string and get a binary string of the encoder. I know there exists a block >> in the Simulink blockset for this purpose - but i don't want to use >> simulink. i want the simulation entirely in matlab with the comm toolbox. > > hi > i need matlab code for rs solomon encoder without using rsenc commandTime to turn in homeworks in Bangalore? -- -T.
