Hi everyone, I am new with matlab and am having problems with a spectral analysis problem i'm trying to do. I need to perform spectral analysis of a signal consisting of 1000Hz, 1000.1Hz and 999.9Hz i.e., x=cos(2*pi*1000*t)+cos(2*pi*1000.1*t)+cos(2*pi*999.9*t) so that all the three peaks are seen. This is to be done using a windowing function like blackmann-harris/guassian. I wrote the m-file to obtain peak for only one frequency. I'm totally stumned with how to obtained all three frequency peaks. Here's my m-file I'm working on. Any ideas on what to choose for the value of L, N and Fs ???? Any help would be great, since i've no idea on how to proceed. The m-file below gives me a peak at 999.9 Hz only and nothing at 1000 and 1000.1 Hz. Fs = 5000; % sampling frequency Ts = 1/Fs; % sampling period L = 25; % number of samples N = 1024*4; % number of points for FFT f1 = 1000 % analog frquency in Hz f2=1000.1 f3=999.9 A1 = 1.7; t = (0:L-1)*Ts; % array of sampled time from 0 to Ts*(L-1) x = A1*cos(2*pi*f1*t)+A1*cos(2*pi*f2*t)+A1*cos(2*pi*f3*t); % sampled signal X = fft(x,N); % take DFT of padded signal XX = fftshift(X) %center spectrum bin_inc = Fs/N, %compute the increment between discrete frequency bins f =[-N/2:(N/2-1)]*bin_inc; % create an array of frequencies figure plot(f, abs(XX)); % plot the magnitude annotated with frequency title('Rectangular') xlabel('frequency Hz') ylabel('magnitude') zzR = max(abs(XX)) ampR = zzR/N*2 % now use windows to process the data prior to performing FFT wb = window(@blackmanharris,L); xb = x.*wb'; % blackman window XB =fftshift(fft(xb,N)); % plot FFT figure plot(f, abs(XB)) title('Blackman-Harris'); xlabel('frequency Hz') ylabel('magnitude') zzB = max(abs(XB)) ampB = zzB/N*2 Thanks a lot in advance, waiting for reply. -Farah
Spectral Analysis using MATLAB
Started by ●August 18, 2006
Reply by ●August 18, 20062006-08-18
ampspectrum=abs(fft(your_time_sequence,2*the_length_of_your_time_sequence)) if N is the length of your sequence and your sample freq. is f then f[n]=((fs/2)*(n-1))/N where n is between 1 and N ------- <farah727rash@gmail.com> skrev i en meddelelse news:1155903928.266355.12150@i3g2000cwc.googlegroups.com...> Hi everyone, > I am new with matlab and am having problems with a spectral analysis > problem i'm trying to do. I need to perform spectral analysis of a > signal consisting of 1000Hz, 1000.1Hz and 999.9Hz i.e., > x=cos(2*pi*1000*t)+cos(2*pi*1000.1*t)+cos(2*pi*999.9*t) so that all the > three peaks are seen. This is to be done using a windowing function > like blackmann-harris/guassian. > > I wrote the m-file to obtain peak for only one frequency. I'm totally > stumned with how to obtained all three frequency peaks. Here's my > m-file I'm working on. Any ideas on what to choose for the value of L, > N and Fs ???? Any help would be great, since i've no idea on how to > proceed. The m-file below gives me a peak at 999.9 Hz only and nothing > at 1000 and 1000.1 Hz. > > Fs = 5000; % sampling frequency > Ts = 1/Fs; % sampling period > L = 25; % number of samples > N = 1024*4; % number of points for FFT > f1 = 1000 % analog frquency in Hz > f2=1000.1 > f3=999.9 > A1 = 1.7; > > t = (0:L-1)*Ts; % array of sampled time from 0 to Ts*(L-1) > x = A1*cos(2*pi*f1*t)+A1*cos(2*pi*f2*t)+A1*cos(2*pi*f3*t); % sampled > signal > X = fft(x,N); % take DFT of padded signal > XX = fftshift(X) %center spectrum > bin_inc = Fs/N, %compute the increment between discrete frequency > bins > f =[-N/2:(N/2-1)]*bin_inc; % create an array of frequencies > figure > plot(f, abs(XX)); % plot the magnitude annotated with frequency > title('Rectangular') > xlabel('frequency Hz') > ylabel('magnitude') > zzR = max(abs(XX)) > ampR = zzR/N*2 > > % now use windows to process the data prior to performing FFT > wb = window(@blackmanharris,L); > xb = x.*wb'; % blackman window > XB =fftshift(fft(xb,N)); > > % plot FFT > figure > plot(f, abs(XB)) > title('Blackman-Harris'); > xlabel('frequency Hz') > ylabel('magnitude') > zzB = max(abs(XB)) > ampB = zzB/N*2 > > Thanks a lot in advance, waiting for reply. > -Farah >
You are not using enough points for the required resolution. You have the answer on your code: bin_inc = Fs/N, %compute the increment between discrete frequency if bin_inc is set to 0.1 Hz than the number of points should be bin_inc=0.1; alpha=1.5; L = alpha*Fs/bin_inc; % number of samples Where alpha is just a constant to give a slightly bigger number of poinst (because the FFT bins might not be *exactly* centered in the frequencies you want to detect. This is the case for the rectangular window, which has the best resolution. For the blackman window you will have to increase the number of points even further... (ie, alpha = 2.5). Obs: You can reduce the sampling frequency to save on the number of points (ie Fs=3 kHz). Also , make sure you zoom in the plot since the peaks are very close together, but you are plotting the whole spectral range.
You are not using enough points for the required resolution. You have the answer on your code: bin_inc = Fs/N, %compute the increment between discrete frequency if bin_inc is set to 0.1 Hz than the number of points should be bin_inc=0.1; alpha=1.5; L = alpha*Fs/bin_inc; % number of samples N=L; Where alpha is just a constant to give a slightly bigger number of poinst (because the FFT bins might not be *exactly* centered in the frequencies you want to detect. This is the case for the rectangular window, which has the best resolution. For the blackman window you will have to increase the number of points even further... (ie, alpha = 2.5). Obs: You can reduce the sampling frequency to save on the number of points (ie Fs=3 kHz). Also , make sure you zoom in the plot since the peaks are very close together, but you are plotting the whole spectral range.
Hey lkaro, thanks a lot. Though i did not use alpha for this part, i just set Fs around 2020Hz and bin_inc as 0.05 since separation between the frequencies is 0.1 using which i calculated N and L. The problem later i was having was that i forgot the zooming in part cos of which i wasnt able to see the discrete peaks clearly. I am thinkning of just plotting the frequencies in the range of -1010:1010 which would save me having to zoom in. thanks for your help. Ikaro wrote:> You are not using enough points for the required resolution. > You have the answer on your code: > > bin_inc = Fs/N, %compute the increment between discrete frequency > > > if bin_inc is set to 0.1 Hz than the number of points should be > > > bin_inc=0.1; > alpha=1.5; > L = alpha*Fs/bin_inc; % number of samples > N=L; > > Where alpha is just a constant to give a slightly bigger number of > poinst (because the FFT bins might not be *exactly* centered in the > frequencies you want to detect. > > > This is the case for the rectangular window, which has the best > resolution. For the blackman window you will have to increase the > number of points even further... (ie, alpha = 2.5). > > > Obs: You can reduce the sampling frequency to save on the number of > points (ie Fs=3 kHz). Also , make sure you zoom in the plot since the > peaks are very close together, but you are plotting the whole spectral > range.
