Hi i am trying to implement 16QAM modulation with effect of transponder nonlinearity i got transponder power input and output values and i have to pass my modulated signal through this nonlinear channel but am not getting how to perform this function . so if anyone here has done such sort of work i.e. implemented a satellite nonlinear channel with any modulation scheme please let me know how to do it. thanking you in advance.
satellite transponder nonlinearity effect on QAM
Started by ●August 18, 2006
Reply by ●August 18, 20062006-08-18
>Hi i am trying to implement 16QAM modulation with effect of transponder >nonlinearity i got transponder power input and output values and i haveto>pass my modulated signal through this nonlinear channel but am notgetting>how to perform this function . so if anyone here has done such sort of >work i.e. implemented a satellite nonlinear channel with any modulation >scheme please let me know how to do it. thanking you in advance. > > >sorry to describe before that all of this i am implementing using matlabcommunication tool box... so contribution from anyone will be appreciated... thanking you once again>
juniar wrote:> >Hi i am trying to implement 16QAM modulation with effect of transponder > >nonlinearity i got transponder power input and output values and i have > to > >pass my modulated signal through this nonlinear channel but am not > getting > >how to perform this function . so if anyone here has done such sort of > >work i.e. implemented a satellite nonlinear channel with any modulation > >scheme please let me know how to do it. thanking you in advance. > > > > > >sorry to describe before that all of this i am implementing using matlab > communication tool box... so contribution from anyone will be > appreciated... thanking you once again > >Can you model the amplifier AM-AM and AM-PM curves using polynomials (polyfit)? Then you could pass a polar version of your signal through the polynomials. John
Reply by ●August 19, 20062006-08-19
> >juniar wrote: >> >Hi i am trying to implement 16QAM modulation with effect oftransponder>> >nonlinearity i got transponder power input and output values and ihave>> to >> >pass my modulated signal through this nonlinear channel but am not >> getting >> >how to perform this function . so if anyone here has done such sortof>> >work i.e. implemented a satellite nonlinear channel with anymodulation>> >scheme please let me know how to do it. thanking you in advance. >> > >> > >> >sorry to describe before that all of this i am implementing usingmatlab>> communication tool box... so contribution from anyone will be >> appreciated... thanking you once again >> >thanks john but i have done that using polyfit function i have generated the graphs but the actual thing that i mentioned is that i could not get the values of the alpha and beta coefficients for the AM/AM and AM/PM so that i could sort out this problem.... or can u explain how u mean to pass polar version of signal through the polinomial the other thing is i tried to get the magnitude of the signal using abs function but still cant find the way to pass it through polynomial to get its effect.... can u please refer me to some reference where such an implementation is described or if u can give me some lines of code to do that.... that would be really very helpfull.... thanking you mate.....> >Can you model the amplifier AM-AM and AM-PM curves using polynomials >(polyfit)? Then you could pass a polar version of your signal through >the polynomials. > >John > >
>>> > > >Can you model the amplifier AM-AM and AM-PM curves using polynomials >(polyfit)? Then you could pass a polar version of your signal through >the polynomials. > >Johni have modeled this using these lines of codes.... power_In=[0.0022 0.0025 0.0028 0.0032 0.0035 0.0039 0.0045 0.0050 0.0056 0.0063 0.0071 0.0079 0.0089 0.0099 0.011 0.013 0.014 0.016 0.018 0.019 0.022 0.025 0.028 0.032 0.035 0.039 0.045 0.050 0.056 0.063 0.071 0.079 0.089 0.099 0.112 0.126 0.141 0.158 0.178 0.199 0.224 0.251]; power_Out=[3.12 3.51 3.94 4.42 4.95 5.56 6.24 6.99 7.85 8.81 9.89 11.09 12.45 13.96 15.67 17.58 19.70 22.08 24.69 27.61 30.83 34.39 38.33 42.56 47.15 52.06 57.08 62.30 67.38 72.28 76.65 80.45 83.56 85.80 87.39 87.90 86.99 84.92 82.22 78.98 74.98 55.72]; co=polyfit(power_In,power_Out,5) new=polyval(co,power_In) plot(power_In,power_Out,'*',power_In,new,':') in above lines of codes power_In and power_Out are satellite transponder powers respectively... and i have generated a polynomial using polyfit with upto 5 polynomials.... but if i have my signal in a variable called signal with complex number.... how i can pass this signal through this polynomial.... and allso i got my signal's power by using abs function wich gives the magnitude. please help me finding the way to pass the signal through this ploynomial ... or infact this transponder model.... thanks....
values for phase change in degrees are also here... phase_Ch=[0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.05 0.36 0.78 1.30 1.95 2.70 3.60 4.65 5.90 7.35 9.05 10.99 13.22 15.81 18.69 21.83 25.17 28.66 32.15 35.52 38.97 42.37 45.76 48.96 51.78 54.26 56.51]
Reply by ●August 23, 20062006-08-23
hello John.... I am waiting for your reply mate... I am still not getting how to pass polar version of my signal through the polynomial...it would be great help from you if u give me some example or refer to any link where it has been explained that how to do this.... please do help me....i really need to find out solution to this problem. thanking you once again in advance, bye
"juniar" <umarmahmud@hotmail.com> wrote in message news:9dWdnfu-M4aFunHZnZ2dnUVZ_oCdnZ2d@giganews.com...> hello John.... > I am waiting for your reply mate... I am still not getting how to pass > polar version of my signal through the polynomial...it would be great help > from you if u give me some example or refer to any link where it has been > explained that how to do this.... > please do help me....i really need to find out solution to this problem. > thanking you once again in advance, > byeHi Juniar - it will help if you polyfit to a set of points describing an odd function. You seem to have input amplitudes spaced in 1 dB steps, correctly translated to linear but you need to invert the order and make them negative then stick them on the front of the data points you already have - now when you do polyfit you should get 0th , 2nd and 5th harmonic very near zero indicating that you can ignore them, the only things you are interested in are 1st , 3rd and 5th harmonics. Now when you do your plot to find out how good the fit is - using only 1st 3rd and 5th order coefficients from polyfit it should be a bit closer. Now you have the output amplitudes - all you should need to do is figure out how to determine what the additional phase shift is for each input power level, add the appropriate phase shift to the input phase to determine what the phase of your output sample is. Best of Luck - Mike
>Hi i am trying to implement 16QAM modulation with effect of transponder >nonlinearity i got transponder power input and output values and i haveto>pass my modulated signal through this nonlinear channel but am notgetting>how to perform this function . so if anyone here has done such sort of >work i.e. implemented a satellite nonlinear channel with any modulation >scheme please let me know how to do it. thanking you in advance. > > > >If you have the inputs and output of the nonlinear system, then all you need to do is solve a system identification problem using a Volterra series. I have done this before using both LMS and block-least squares to solve for the Volterra coefficients. Warning: Volterra models can become prohibitively large if the non-linearity has a long memory.
