Multiple pass moving average filter
Started by Unknown August 18, 2006
I'm working with a multiple pass moving average filter.  I would like
to communicate with someone who is using or very familiar with
methods of treating the ends and reducing lag via assumption of
missing values, etc.
Alternatively any comments or referral to sources on this issue
would be highly appreciated.
You can include the multiple passes into your filter (via multiple self-convolution of the filter kernel), and then apply only one single pass. OTOH, this doesn't allow you to filter as many passes as are required until the filtered signal satisfies some criterion.
> I would like > to communicate with someone who is using or very familiar with > methods of treating the ends and reducing lag via assumption of > missing values, etc. > > Alternatively any comments or referral to sources on this issue > would be highly appreciated.
Perhaps you have to describe your application in more detail. You can, for example, modify your moving average filter to have minimum phase response given some magntiude response to improve the "promptness". Or is your application aimed at extrapolation? Regards, Andor
Thank you for your response.
> You can include the multiple passes into your filter (via multiple > self-convolution of the filter kernel), and then apply only one single > pass. OTOH, this doesn't allow you to filter as many passes as are > required until the filtered signal satisfies some criterion.
I'm using an odd number so that I always have a center points and I'm using 3 passes to reduce more noise from the data. My application is a form of graduation -- where my data is probabilities. I have searched various methods used in actuarial science and have not seen much useful for real time data involving time sensitive risk as opposed to historical data. I use the same programming language as many actuaries and have tested several methods used within the field that are slower and not as effective as simple and exponential smoothing. Your suggestion of including the multiple passes into your filter (via multiple self-convolution of the filter kernel) sounds very interesting. How would I do that?
> > I would like > > to communicate with someone who is using or very familiar with > > methods of treating the ends and reducing lag via assumption of > > missing values, etc. > > > > Alternatively any comments or referral to sources on this issue > > would be highly appreciated.
I have augmented an existing multiple moving average method to suit my purpose. It is fast and provides desirable historical results. Adjustments will have to be made to treatment of the ends and how I sequentially select the middle point to improve real time results. I am not a dsp person so this raises several questions in my mine about the reliability of mulitiple mov ave filters. Therefore I tried to replicate the results with simple exponential smoothing. I found that my testing all coefficients on over a 100 samples with 450 elements each that it would allow me to obtain a 93 percent correlation with the multiple moving average filter. Still the standard deviation in using multiple moving average was significantly better and the modification I made to it produced much more "effective promptness". I do not need to extrapolate the probabilites. I need to communicate with someone with which I can proof my modification and/or revise them so the final design is consistent with sound dsp theory and usage. Your comment below is exactly the tasks I'm seeking to complete and verify that it is done correctly.
> Perhaps you have to describe your application in more detail. You can, > for example, modify your moving average filter to have minimum phase > response given some magntiude response to improve the "promptness". Or > is your application aimed at extrapolation? > > Regards, > Andor
On 18 Aug 2006 18:33:24 -0700, edwards2107@comcast.net wrote:
>I'm working with a multiple pass moving average filter. I would like >to communicate with someone who is using or very familiar with >methods of treating the ends and reducing lag via assumption of >missing values, etc. > >Alternatively any comments or referral to sources on this issue >would be highly appreciated.
Newbie: That would be like the sinc3 filters used in industrial ADCs (CIC?)? Tony (remove the "_" to reply by email)
Newport wrote:
> > > I'm working with a multiple pass moving average filter. > > Thank you for your response. > > > You can include the multiple passes into your filter (via multiple > > self-convolution of the filter kernel), and then apply only one single > > pass. OTOH, this doesn't allow you to filter as many passes as are > > required until the filtered signal satisfies some criterion. > > I'm using an odd number so that I always have a center points and > I'm using 3 passes to reduce more noise from the data. My > application is a form of graduation -- where my data is probabilities.
Interesting. I guess this poses special limitations on the "filter type". I enclose this in quoation marks, because if the probability space is finite, you cannot actually process your distribution with a filter because convolution increases the length of the sequence. For example, you have a distribution on the numbers {1, 2, 3}. FIR filtering via convolution will, in general also return non-zero values for {4, 5, ... N-4}, where N is the length of the filter kernel. Truncating the output to the space {1, 2, 3} is not linear convolution.
> > I have searched various methods used in actuarial science and have > not seen much useful for real time data involving time sensitive risk > as opposed to historical data. I use the same programming language > as many actuaries and have tested several methods used within the > field that are slower and not as effective as simple and exponential > smoothing.
If I remember correctly, exponential smoothing is a first order IIR lowpass filter of the type y_n = alpha y_{n-1} + beta x_n, alpha + beta = 1, where x_n is the input and y_n the output sequence. To comment on its effectivity for smoothing, one would need to know the application. There is nothing special about this filter which would make it stand out in a class of filters (except its ease of implementation).
> > Your suggestion of including the multiple passes into your filter (via > multiple self-convolution of the filter kernel) sounds very > interesting. > How would I do that?
Simple, just use the fact that convolution is associative. For example, if your input data is x_n and your finite filter kernel is h (the moving average filter) , then h * (h * (h * x_n) ) ) = (h * h * h) * x_n, where * denotes the convolution operator. If H is the frequency resposne of h, then multiple convolution with h just means that you take powers in the frequency domain, ie. (h * h * h) * x_n < = > H^3 X, where X is the Fourier transformed of x_n. Iterated convolution is usually an inefficient way to design filters. You can get the performance of H^3 with less filter taps. A similar techniques called filter sharpening is to apply 3 H^2 - 2 H^3, which improves both stopband and passband ripple. This was, for exmaple, discussed here: http://groups.google.com/group/comp.dsp/browse_frm/thread/87fbcc126c66fef6/063924123abe3460?#063924123abe3460 An example of iterated convolution: if h is the linear average, ie h = 1/m [1 1 .... 1] (m entries), then the z-transform H of h is equal to H(z) = (1 - z^m) / (1 - z), which means that the frequency response has m-1 zeros, spaced at the m-th unit roots not equal to 1. Such a filter is good for removing periodic signals with period Fs / m and no DC content, where Fs is the sampling frequency. Repeated application of h will increase the order of the zeros, effectively making this a lowpass filter with stopband starting from Fs / m. It is however a very poor design for such a lowpass filter, because the passband is not very flat - for the same filter order, you can get much better performance. Hence iteration, or sharpening, or not widely used for signal processing (at least where I come from).
> > > > I would like > > > to communicate with someone who is using or very familiar with > > > methods of treating the ends and reducing lag via assumption of > > > missing values, etc. > > > > > > Alternatively any comments or referral to sources on this issue > > > would be highly appreciated. > > I have augmented an existing multiple moving average method to > suit my purpose. It is fast and provides desirable historical results. > Adjustments will have to be made to treatment of the ends and > how I sequentially select the middle point to improve real time > results. I am not a dsp person so this raises several questions > in my mine about the reliability of mulitiple mov ave filters. > > Therefore I tried to replicate the results with simple exponential > smoothing. I found that my testing all coefficients on over a > 100 samples with 450 elements each that it would allow me > to obtain a 93 percent correlation with the multiple moving average > filter. Still the standard deviation in using multiple moving average > was significantly better and the modification I made to it produced > much more "effective promptness". > > I do not need to extrapolate the probabilites. I need to communicate > with someone with which I can proof my modification and/or revise > them so the final design is consistent with sound dsp theory and usage. > > Your comment below is exactly the tasks I'm seeking to complete > and verify that it is done correctly.
You can, for example, read about transforming linear-phase filters (such as the simple linear average) to minimum-phase filters here: http://www.dspguru.com/howto/tech/minph.htm Another option is some DSP book, an incomplete list thereof you can find here: http://www.dspguru.com/info/books/favor.htm FWIW, Andor
Thanks for your response.
I looked up info and sinc3 filters and what I've seen appears to be
implemented with dsp hardware.  I'm totally open to any solution
that I can use that will work as well as multi-pass moving average
as long as it works fast in real time.
Are there other methods equivalent to the sinc3 that can be
implemented with software?  Since I'm looking for a way to do
aggressive smoothing of probabilities in real time along with
getting fast response to jumps that may occur -- a computer
program would appear to be much simple and easier to use than
hardware.
However, I will follow up on any source you provide that might help
lead to a solution if you can break down the benefits in terms
someone outside the dsp field can understand.
Tony wrote:
> On 18 Aug 2006 18:33:24 -0700, edwards2107@comcast.net wrote: > > >I'm working with a multiple pass moving average filter. I would like > >to communicate with someone who is using or very familiar with > >methods of treating the ends and reducing lag via assumption of > >missing values, etc. > > > >Alternatively any comments or referral to sources on this issue > >would be highly appreciated. > > Newbie: That would be like the sinc3 filters used in industrial ADCs > (CIC?)? > > Tony (remove the "_" to reply by email)
Hi Andor,
Thanks for the useful information in your detailed reply.  I will use
the sources you provided to gain more details on your suggestions.
Andor wrote:
> Newport wrote: > > > > I'm working with a multiple pass moving average filter. > > > > Thank you for your response. > > > > > You can include the multiple passes into your filter (via multiple > > > self-convolution of the filter kernel), and then apply only one single > > > pass. OTOH, this doesn't allow you to filter as many passes as are > > > required until the filtered signal satisfies some criterion. > > > > I'm using an odd number so that I always have a center points and > > I'm using 3 passes to reduce more noise from the data. My > > application is a form of graduation -- where my data is probabilities. > > Interesting. I guess this poses special limitations on the "filter > type". I enclose this in quoation marks, because if the probability > space is finite, you cannot actually process your distribution with a > filter because convolution increases the length of the sequence. For > example, you have a distribution on the numbers {1, 2, 3}. FIR > filtering via convolution will, in general also return non-zero values > for {4, 5, ... N-4}, where N is the length of the filter kernel. > Truncating the output to the space {1, 2, 3} is not linear convolution. > > > > > I have searched various methods used in actuarial science and have > > not seen much useful for real time data involving time sensitive risk > > as opposed to historical data. I use the same programming language > > as many actuaries and have tested several methods used within the > > field that are slower and not as effective as simple and exponential > > smoothing. > > If I remember correctly, exponential smoothing is a first order IIR > lowpass filter of the type > > y_n = alpha y_{n-1} + beta x_n, alpha + beta = 1, > > where x_n is the input and y_n the output sequence. To comment on its > effectivity for smoothing, one would need to know the application. > There is nothing special about this filter which would make it stand > out in a class of filters (except its ease of implementation). > > > > > Your suggestion of including the multiple passes into your filter (via > > multiple self-convolution of the filter kernel) sounds very > > interesting. > > How would I do that? > > Simple, just use the fact that convolution is associative. For example, > if your input data is x_n and your finite filter kernel is h (the > moving average filter) , then > > h * (h * (h * x_n) ) ) = (h * h * h) * x_n, > > where * denotes the convolution operator. If H is the frequency > resposne of h, then multiple convolution with h just means that you > take powers in the frequency domain, ie. > > (h * h * h) * x_n < = > H^3 X, > > where X is the Fourier transformed of x_n. Iterated convolution is > usually an inefficient way to design filters. You can get the > performance of H^3 with less filter taps. A similar techniques called > filter sharpening is to apply 3 H^2 - 2 H^3, which improves both > stopband and passband ripple. This was, for exmaple, discussed here: > > http://groups.google.com/group/comp.dsp/browse_frm/thread/87fbcc126c66fef6/063924123abe3460?#063924123abe3460 > > An example of iterated convolution: if h is the linear average, ie h = > 1/m [1 1 .... 1] (m entries), then the z-transform H of h is equal to > > H(z) = (1 - z^m) / (1 - z), > > which means that the frequency response has m-1 zeros, spaced at the > m-th unit roots not equal to 1. Such a filter is good for removing > periodic signals with period Fs / m and no DC content, where Fs is the > sampling frequency. Repeated application of h will increase the order > of the zeros, effectively making this a lowpass filter with stopband > starting from Fs / m. It is however a very poor design for such a > lowpass filter, because the passband is not very flat - for the same > filter order, you can get much better performance. Hence iteration, or > sharpening, or not widely used for signal processing (at least where I > come from). > > > > > > I would like > > > > to communicate with someone who is using or very familiar with > > > > methods of treating the ends and reducing lag via assumption of > > > > missing values, etc. > > > > > > > > Alternatively any comments or referral to sources on this issue > > > > would be highly appreciated. > > > > I have augmented an existing multiple moving average method to > > suit my purpose. It is fast and provides desirable historical results. > > Adjustments will have to be made to treatment of the ends and > > how I sequentially select the middle point to improve real time > > results. I am not a dsp person so this raises several questions > > in my mine about the reliability of mulitiple mov ave filters. > > > > Therefore I tried to replicate the results with simple exponential > > smoothing. I found that my testing all coefficients on over a > > 100 samples with 450 elements each that it would allow me > > to obtain a 93 percent correlation with the multiple moving average > > filter. Still the standard deviation in using multiple moving average > > was significantly better and the modification I made to it produced > > much more "effective promptness". > > > > I do not need to extrapolate the probabilites. I need to communicate > > with someone with which I can proof my modification and/or revise > > them so the final design is consistent with sound dsp theory and usage. > > > > Your comment below is exactly the tasks I'm seeking to complete > > and verify that it is done correctly. > > You can, for example, read about transforming linear-phase filters > (such as the simple linear average) to minimum-phase filters here: > > http://www.dspguru.com/howto/tech/minph.htm > > Another option is some DSP book, an incomplete list thereof you can > find here: > > http://www.dspguru.com/info/books/favor.htm > > FWIW, > Andor
Newport wrote:
> Thanks for your response. > > I looked up info and sinc3 filters and what I've seen appears to be > implemented with dsp hardware. I'm totally open to any solution > that I can use that will work as well as multi-pass moving average > as long as it works fast in real time. > > Are there other methods equivalent to the sinc3 that can be > implemented with software? Since I'm looking for a way to do > aggressive smoothing of probabilities in real time along with > getting fast response to jumps that may occur -- a computer > program would appear to be much simple and easier to use than > hardware. > > However, I will follow up on any source you provide that might help > lead to a solution if you can break down the benefits in terms > someone outside the dsp field can understand. > > > Tony wrote: > >>On 18 Aug 2006 18:33:24 -0700, edwards2107@comcast.net wrote: >> >> >>>I'm working with a multiple pass moving average filter. I would like >>>to communicate with someone who is using or very familiar with >>>methods of treating the ends and reducing lag via assumption of >>>missing values, etc. >>> >>>Alternatively any comments or referral to sources on this issue >>>would be highly appreciated. >> >>Newbie: That would be like the sinc3 filters used in industrial ADCs >>(CIC?)? >> >>Tony (remove the "_" to reply by email) > >
The moving average filter is also known as a boxcar filter: all the coefficients are unity. When you do multiple passes, it is the same as passing the data through 3 consecutive boxcar filters. Knowing that, you can convolve the impulse responses of the boxcar filters to arrive at a single filter that does the same thing. Convolution is basically sliding one filter's coefficients past the other and computing the sum of products for each alignment. If your moving average is 5 samples, the response is [1 1 1 1 1] convolving that with itself gives you the response of two passes, which would be [1 2 3 4 5 4 3 2 1], and the convolving that again with {1 1 1 1 1 ] yields an FIR filter with coefficients: [1 3 6 10 15 18 19 18 15 10 6 3 1] the software implementation the would perform the convolution of that filter with the most recent 13 samples: y(k) = sum( x(k)*filt(k) ) for k=0 to 12.
Ray Andraka <ray@andraka.com> wrote in news:jaKGg.5726$SZ3.1767@dukeread04:
actually, [1 1 1 1 1]/5, otherwise you'll end up with a gain of 15 with three passes. -- Scott Reverse name to reply
Newport wrote:
>>>I'm working with a multiple pass moving average filter. > > > Thank you for your response. > >
-- snip --
-- snip -- Am I correct in my assumption that you are coming at this from the actuarial world, rather than the signals and systems world? If you are trying to estimate some constant value whose measurement is corrupted by noise, or the state of some variable whose evolution is driven by a random process (and whose measurement is corrupted by noise), then you may want to investigate Kalman filtering. If you can state your problem in terms of linear systems evolving in response to Gaussian random variables, and if your cost functions are quadratic, then you can find closed-form optimal solutions in the Kalman filter. Given that it's been around for nearly 50 years now, there are extensions to the Kalman filter to take care of cases where the random processes aren't Gaussian, the cost functions aren't quadratic, or the systems aren't linear. Kalman filter theory isn't easy, but it can save you a lot of fumbling in the dark testing half-baked filtering attempts*. I'm currently reading Dan Simon's "Optimal State Estimation: Kalman, H-infinity, and Nonlinear Approaches", John Wiley & Sons, 2006. It seems like a good text to me -- it matches what I know of detection & estimation theory, it presents all the necessary math, but it does so with an eye toward _using_ the math rather than just playing with all the pretty notation. I recommend it highly. * On the other hand, if you have exactly one problem to solve and a half-baked filter will get you close enough you can optimize for design time and just go for it. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
