I am using a butterworth filter on a 1843200 point signal, sampled at 2048/second: n = 2; Wn = [lo hi]/(samplerate/2); [buttercoeffsB,buttercoeffsA] = butter(n,Wn); to bandpass a signal: filtereddata = filter(buttercoeffs(1,:),buttercoeffs(2,:),data); When lo and hi equal .2 and 80, or .3 and 60, the filtering works fine. But, if I try .2 and 60, or .3 and 80, only part of the filtered data is produced, and the rest of the filtered data is NaN. Clearly I don't have a deep enough understanding of filtering. Any comments about why this happens or how to get around it would be much appreciated. Many thanks.....
Why does low highpass in fir filter cause NaN?
Started by ●August 20, 2006
Reply by ●August 20, 20062006-08-20
charlesblackstone1@hotmail.com wrote:> I am using a butterworth filter on a 1843200 point signal, sampled at > 2048/second: > > n = 2; > Wn = [lo hi]/(samplerate/2); > [buttercoeffsB,buttercoeffsA] = butter(n,Wn); > > to bandpass a signal: > > filtereddata = filter(buttercoeffs(1,:),buttercoeffs(2,:),data); > > > When lo and hi equal .2 and 80, or .3 and 60, the filtering works fine. > But, if I try .2 and 60, or .3 and 80, only part of the filtered data > is produced, and the rest of the filtered data is NaN. > > Clearly I don't have a deep enough understanding of filtering. Any > comments about why this happens or how to get around it would be much > appreciated. > > Many thanks..... >Perhaps letting us know what the filter coefficients are would help -- not everyone here uses MatLab to generate filters. Even having not used MatLab for a long time, I can tell you that the 'filter' function as you're using it implements an infinite impulse response filter, _not_ a FIR filter. That's an important difference to keep straight. I would suspect that some internal state of your filter is unstable, and you get real numbers until that state exceeds the size of MatLab's floating point representation, at which point you start getting NaNs. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●August 21, 20062006-08-21
On 20 Aug 2006 01:51:06 -0700, charlesblackstone1@hotmail.com wrote:>I am using a butterworth filter on a 1843200 point signal, sampled at >2048/second: > > n = 2; > Wn = [lo hi]/(samplerate/2); > [buttercoeffsB,buttercoeffsA] = butter(n,Wn); > >to bandpass a signal: > > filtereddata = filter(buttercoeffs(1,:),buttercoeffs(2,:),data); > > >When lo and hi equal .2 and 80, or .3 and 60, the filtering works fine. >But, if I try .2 and 60, or .3 and 80, only part of the filtered data >is produced, and the rest of the filtered data is NaN. > >Clearly I don't have a deep enough understanding of filtering. Any >comments about why this happens or how to get around it would be much >appreciated. > >Many thanks.....Hello Charles, are you sure your filter is working properly when lo = 0.2 and hi = 80? With a sample rate of 2048 Hz, I question whether a fourth-order IIR filter can achieve the incredibly low frequency of 0.2 Hz for the beginning of your passband. When I apply your coefficients to MATLAB's freqz() command and plot the filter's mag response I see a truly strange response. I'm guessing that your "lo" value is pushing MATLAB's algorithms beyond the parameter range where they operate properly. Do you really need the beginning of the passband to be 0.2 Hz? (It seems to me you're trying to implement some sort of super-duper "DC cancelation" filter.) Regards, [-Rick-]
