Friends, since nobody picked up my "exercise to the reader" in another thread, or challenged me to its validity, I'll repost it as a riddle: Consider the functions u1(t) = t step(t), y1(t) = (t+1)^3 step(t+1), u2(t) = 3 (t-1) step(t-1), and y2(t) = 9 step(t). Give an example of a linear system that transforms u1 to y1 and u2 to y2! Regards, Andor
SP riddle
Started by ●August 29, 2006
Reply by ●August 29, 20062006-08-29
> Consider the functions > > u1(t) = t step(t), > y1(t) = (t+1)^3 step(t+1), > u2(t) = 3 (t-1) step(t-1), and > y2(t) = 9 step(t). > > Give an example of a linear system that transforms u1 to y1 and u2 to > y2! >H(s)= -exp(-s)*Ei(s)+1/s+1/s^2+2/s^3
Hans S=F8rensen wrote:> > Consider the functions > > > > u1(t) =3D t step(t), > > y1(t) =3D (t+1)^3 step(t+1), > > u2(t) =3D 3 (t-1) step(t-1), and > > y2(t) =3D 9 step(t). > > > > Give an example of a linear system that transforms u1 to y1 and u2 to > > y2! > > > > > > H(s)=3D -exp(-s)*Ei(s)+1/s+1/s^2+2/s^3Hello Hans, thanks for participating! However, note that the system in question, while linear, is clearly not time-invariant, as can be derived from the equations. Thus it does not have a well-defined transfer function (or impulse response)... Regards, Andor
Reply by ●August 31, 20062006-08-31
>thanks for participating! However, note that the system in question, >while linear, is clearly not time-invariant, as can be derived from the >equations. Thus it does not have a well-defined transfer function (or >impulse response)... > >Regards, >Andor > >Andor, I spent some time thinking about this problem last night. I didn't get an answer but I don't want to see this thread die. My first idea was to look at analyzing the inputs and ouptputs in the frequency domain using LaPlace transforms. However, I found that this was a dead end because Laplace (one sided at least?) works under the assumption that you are analyzing an LTI system, which is not the case as you pointed out. So, I thought that considering a two sided LaPlace Transform, being more a more general approach, might mititgate this restriction. However, I got the impression from your post that we would not be able to express this system in closed form, that using any analytic technique would be a dead end. Plus, it was bedtime so I was pretty tired :) I don't make the habbit of following a path just because someone says it's the correct way so can you justify your reasoning for the following statement?>The system in question, >while linear, is clearly not time-invariant, as can be derived from the >equations. Thus it does not have a well-defined transfer function (or >impulse response)...If this is so, then how do you expect to get an answer without any "well-defined" way of talking about it? My intuition says that there is no linear system that will represent system 1 and there is a linear system that will represent system 2. Thank you for posting this riddle. I'm having fun thinking about it.
bmh161 wrote:> >thanks for participating! However, note that the system in question, > >while linear, is clearly not time-invariant, as can be derived from the > >equations. Thus it does not have a well-defined transfer function (or > >impulse response)... > > > >Regards, > >Andor > > > > > > Andor, I spent some time thinking about this problem last night. I didn't > get an answer but I don't want to see this thread die.Ok :-).> > My first idea was to look at analyzing the inputs and ouptputs in the > frequency domain using LaPlace transforms. However, I found that this was > a dead end because Laplace (one sided at least?) works under the assumption > that you are analyzing an LTI system, which is not the case as you pointed > out.Indeed.> > So, I thought that considering a two sided LaPlace Transform, being more a > more general approach, might mititgate this restriction. However, I got > the impression from your post that we would not be able to express this > system in closed form, that using any analytic technique would be a dead > end. Plus, it was bedtime so I was pretty tired :) > > I don't make the habbit of following a path just because someone says it's > the correct way so can you justify your reasoning for the following > statement? > > >The system in question, > >while linear, is clearly not time-invariant, as can be derived from the > >equations. Thus it does not have a well-defined transfer function (or > >impulse response)...Looking back at the definitions of input and output, you'll notice that u2(t) = 3 u1(t-1). If the system were LTI, this would mean that y2(t) = 3 y1(t-1), which is not true, so the system cannot be LTI. This does not imply, however, that the system cannot be linear!> > If this is so, then how do you expect to get an answer without any > "well-defined" way of talking about it?Linearity is a well defined concept (for example here: http://en.wikipedia.org/wiki/Linear_system). One can only use transfer functions if the systems in question are LTI.> My intuition says that there is no linear system that will represent > system 1 and there is a linear system that will represent system 2.Remember, we are looking for one single system that transforms both u1 -> y1 and u2 -> y2.> > Thank you for posting this riddle. I'm having fun thinking about it.To help you along a bit, here are some hints: - Integration is linear, ie. transforming u(t) -> y(t) = int_c^t u(tau) dtau, for any starting constant c is a linear system. - Sampling is linear, ie. transforming u(t) -> y(t) = u(t_0), for any sampling time t_0 is a linear system. - Linear combinations of linear systems are also linear systems. - Concatenating two linear systems (series connection) also results in a linear system. Have fun! Regards, Andor
Reply by ●September 3, 20062006-09-03
Is no news good news? Here is another hint: We are looking for a linear system H with y1 = H u1 and y2 = H u2. One way to go about this is to partition H into two systems, H = H1 + H2, such that y1 = H1 u1, 0 = H1 u2, and y2 = H2 u2, 0 = H2 u1. Regards, Andor
Reply by ●September 4, 20062006-09-04
Andor wrote:> Here is another hint:Before I had no clue but that makes it grunt work ;)> We are looking for a linear system H with > y1 = H u1 > and > y2 = H u2. > > One way to go about this is to partition H into two systems, > H = H1 + H2and H1{x} = T1{x - u2}, H2{x} = T2{x - u1} where T1, T2 are LTI systems whose transfer functions, imposing> y1 = H1 u1, > y2 = H2 u2,pop out as T1(s) = 6e^s / (s^2(1 - 3e^-s)), T2(s) = 9s / (3e^-s - 1). That makes the easiest-checked form of the overall system Y(s) = (6e^s/s^2 (X(s) - 3e^-s/s^2) + 9(1/s - X(s)s)) / (1 - 3e^-s). Martin -- Be the change you're trying to create. --Mahatma Gandhi
Martin Eisenberg wrote:> Andor wrote: > > > Here is another hint: > > Before I had no clue but that makes it grunt work ;) > > > We are looking for a linear system H with > > y1 = H u1 > > and > > y2 = H u2. > > > > One way to go about this is to partition H into two systems, > > H = H1 + H2 > > and H1{x} = T1{x - u2}, H2{x} = T2{x - u1} where T1, T2 are LTI > systems whose transfer functions, imposing > > > y1 = H1 u1, > > y2 = H2 u2, > > pop out as > T1(s) = 6e^s / (s^2(1 - 3e^-s)), > T2(s) = 9s / (3e^-s - 1).Nice try :-). However, your system is not linear - do you see why? Regards, Andor
Andor wrote:> Martin Eisenberg wrote: >> Andor wrote: >> >> > Here is another hint: >> >> Before I had no clue but that makes it grunt work ;)Some day I'm really gonna pay for this kind of confidence...>> > We are looking for a linear system H with >> > y1 = H u1 >> > and >> > y2 = H u2. >> > >> > One way to go about this is to partition H into two systems, >> > H = H1 + H2 >> >> and H1{x} = T1{x - u2}, H2{x} = T2{x - u1} where T1, T2 are LTI> Nice try :-). However, your system is not linear - do you see why?I do, taking me back to my baseline state: The ansatz implies H{2 u1} - 2 y1 = T1{u2} + T2{u1} != 0 in general. Martin -- Quidquid latine scriptum sit, altum viditur.
