Hi all, Can I change the Y-scale to small value to indicate the 0-5V input not codes values (+/- 32K) in FFT output where in output signal can be changed using Q-value. Thank you a lot
A Fixed-Point Introduction by Example
Handling Spectral Inversion in Baseband Processing
Understanding the Phasing Method of Single Sideband Modulation
An Interesting Fourier Transform 1/f Noise
Before you can participate to the *related sites forums, you need to login or create an account.
