hi all im a bit new to the ccs, can some one explain to me how i can use the dsplib to program in the ccs?? if you can tell me where i can find a sample code or somthing... any help at all?? thanks in advance vai
using dsplib +c6711dsk
Started by ●June 17, 2004
Reply by ●June 20, 20042004-06-20
"vai" <vaiy1@email.com> wrote:>hi all > >im a bit new to the ccs, > >can some one explain to me how i can use the dsplib to program in the >ccs??dsplib should be a collection of routines that TI produced, that you can use for performing dsp.> >if you can tell me where i can find a sample code or somthing...if it is the same dsplib I used, these are sample code.> >any help at all?? >I'd recommend reading all documentation that TI has provided. Plus go to www.ti.com, and find more that they have. If you then have specific questions, ask them, and maybe someone here can help. You can find some other discussion groups here: http://dspvillage.ti.com/docs/dspvillagehome.jhtml Robert www.gldsp.com ( modify address for return email ) www.numbersusa.com www.americanpatrol.com
