Career in DSP
Started by migo ●September 7, 2006
Hi,
I've been writing embedded telecomm software for a few years and I'm now
thinking of going back to get an MSEE in order to do digital signal
processing professionally. What advice would a seasoned engineer give
someone thinking about a career in this field?
Thanks in advance!
George
migo wrote:
> Hi, > I've been writing embedded telecomm software for a few years and I'm now > thinking of going back to get an MSEE in order to do digital signal > processing professionally. What advice would a seasoned engineer give > someone thinking about a career in this field? > Thanks in advance! > George
Depends on why you are doing it. If it is to increase your technical knowledge, then by all means pursue it. If you are expecting to get a "better" job, forget it. I speak from having done exactly what you are thinking about. The MSEE was worth it from a personal development standpoint but absolutely worthless in trying to secure a better job. I finally tossed in the EE towel. I spent an additional 4 years of evenings and weekends and holidays to obtain an MSCS. This has proved to be a much better investment in terms of career paths, potential, and compensation. Good luck.
nobody wrote:
> migo wrote: >> Hi, >> I've been writing embedded telecomm software for a few years and I'm now >> thinking of going back to get an MSEE in order to do digital signal >> processing professionally. What advice would a seasoned engineer give >> someone thinking about a career in this field? >> Thanks in advance! >> George > > Depends on why you are doing it. If it is to increase your technical > knowledge, then by all means pursue it. If you are expecting to get a > "better" job, forget it. > > I speak from having done exactly what you are thinking about. The MSEE > was worth it from a personal development standpoint but absolutely > worthless in trying to secure a better job. > > I finally tossed in the EE towel. I spent an additional 4 years of > evenings and weekends and holidays to obtain an MSCS. This has proved > to be a much better investment in terms of career paths, potential, and > compensation.
Is that how you ended up being a nobody? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
nobody wrote:
> migo wrote: > > > I've been writing embedded telecomm software for a few years and I'm now > > thinking of going back to get an MSEE in order to do digital signal > > processing professionally. What advice would a seasoned engineer give > > someone thinking about a career in this field? > > Depends on why you are doing it. If it is to increase your technical > knowledge, then by all means pursue it. If you are expecting to get a > "better" job, forget it. > > I speak from having done exactly what you are thinking about. The MSEE > was worth it from a personal development standpoint but absolutely > worthless in trying to secure a better job.
"better" means a variety of things. maybe the OP wants a more interesting job. maybe the OP is willing to move somewhere else and/or take a pay cut for it. dunno if there is still money in DSP in telcom and wireless, but i s'pose what makes the most money is what the market most wants to see done. maybe not. i dunno. sometimes DSP is very interesting stuff, but work is work. DSP coding and even the more elegant mathematical algorithmic "composition" has tedious moments in it. r b-j
i would suggest you to follow what you want to take up. Do MSEE, it
would be better to have knowledge of all related things and then may be
who knows, with existing embedded software and knowledge through MSEE
you can set up some company. This is what happened with rajeev,
MAGMA-DA and other great people, they put up their brain where nobody
have ever ventured..(for this practical knowledge and where to put that
practical knowledge is obtained through the educational and overall
knowledge obtained through MSEE)
so, even NOBODY, i should call him great as he suggested right thing.
regards
particle
Jerry Avins wrote:
> nobody wrote: > > migo wrote: > >> Hi, > >> I've been writing embedded telecomm software for a few years and I'm n=
ow
> >> thinking of going back to get an MSEE in order to do digital signal > >> processing professionally. What advice would a seasoned engineer give > >> someone thinking about a career in this field? > >> Thanks in advance! > >> George > > > > Depends on why you are doing it. If it is to increase your technical > > knowledge, then by all means pursue it. If you are expecting to get a > > "better" job, forget it. > > > > I speak from having done exactly what you are thinking about. The MSEE > > was worth it from a personal development standpoint but absolutely > > worthless in trying to secure a better job. > > > > I finally tossed in the EE towel. I spent an additional 4 years of > > evenings and weekends and holidays to obtain an MSCS. This has proved > > to be a much better investment in terms of career paths, potential, and > > compensation. > > Is that how you ended up being a nobody? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF
No smart guy. A "screen name" is irrelevant. Whether it be "stray dawg" or "nobody". If you read my post carefully, you will see that I suggest that the guy get an MSEE because he wants to study the material. I also suggest that he pursue other avenues if he is just looking to make more money or move up the ladder. An MBA, MSCS, or IT degree are much more saleable in terms of salary than an MSEE. EE's stay EE's because they love engineering, not because of the money or the work environment. I have been one for over 30 years. In order to stay in the field I have had to change with technology and the times. That is what real engineers do. In this day and age, much of engineering is related to CS. A BSCS or MSCS degree greatly enhances an EE in a number of ways. Not the least of which is broading and lengthing an EE's career. =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
nobody wrote:
>>>I finally tossed in the EE towel. I spent an additional 4 years of >>>evenings and weekends and holidays to obtain an MSCS. This has proved >>>to be a much better investment in terms of career paths, potential, and >>>compensation. >> >>Is that how you ended up being a nobody? >> > No smart guy. A "screen name" is irrelevant. Whether it be "stray > dawg" or "nobody".
No wonder. Slaves are afraid that their masters can recognize them.
> > EE's stay EE's because they love engineering, not because of the money > or the work environment. I have been one for over 30 years.
An engineer is no more then a tool. Somewhat similar to the power screwdriver. However the screwdrivers are usually free from many bad habits that the engineers do have. I feel sorry to those who are over 30 however they still didn't realize that.
> In order > to stay in the field I have had to change with technology and the > times. That is what real engineers do.
But you didn't change your philosophy. VLV
Vladimir Vassilevsky wrote:
> > > nobody wrote: > >>>> I finally tossed in the EE towel. I spent an additional 4 years of >>>> evenings and weekends and holidays to obtain an MSCS. This has proved >>>> to be a much better investment in terms of career paths, potential, and >>>> compensation. >>> >>> Is that how you ended up being a nobody? >>> >> No smart guy. A "screen name" is irrelevant. Whether it be "stray >> dawg" or "nobody". > > No wonder. Slaves are afraid that their masters can recognize them. > >> >> EE's stay EE's because they love engineering, not because of the money >> or the work environment. I have been one for over 30 years. > > An engineer is no more then a tool. Somewhat similar to the power > screwdriver. However the screwdrivers are usually free from many bad > habits that the engineers do have. I feel sorry to those who are over 30 > however they still didn't realize that. > > >> In order to stay in the field I have had to change with technology >> and the >> times. That is what real engineers do. > > But you didn't change your philosophy. > > > VLV
Vladimir, Your message seems to be addressed to me, but there is evidently a missing message. Perhaps "nobody" deleted his response to me (which you quote but that I don't see) when he realized that my remark was -- for better or worse -- intended to be humor. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"nobody" <rock_sci@hotmail.com> writes:
> [...] > A "screen name" is irrelevant.
If I cannot ascertain someone's identity, then anything they have to say is likewise irrelevent. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
"Randy Yates" <yates@ieee.org> wrote in message
news:m33bb2ns8l.fsf@ieee.org...
> "nobody" <rock_sci@hotmail.com> writes: >> [...] >> A "screen name" is irrelevant. > > If I cannot ascertain someone's identity, then anything they have to > say is likewise irrelevent.
An interesting point of view. What do you mean, though, by "cannot ascertain" ? For instance, I post here rather infrequently. I don't bother to mask my identity, but does anyone here *know* me? Is my opinion somehow more relevant because there seems to be a "real name" associated with it? Best wishes, --Phil Martel
> -- > % Randy Yates % "Maybe one day I'll feel her cold > embrace, > %% Fuquay-Varina, NC % and kiss her > interface, > %%% 919-577-9882 % til then, I'll leave her > alone." > %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO > http://home.earthlink.net/~yatescr
